Results 1 to 19 of 19
    Veteran Member Four Rings Hockenheim's Avatar
    Jul 09 2007
    Phoenix
    Anyone done the OEM resonator delete on a 2.0T?
    How did you like it? Better sound?
    Apr 03 2018
    2018 S3, 2013 VW CC
    Resonator Delte
    Quote Originally Posted by Hockenheim View Post
    I did mine over the weekend. I have water condensation leaking at start up. I screwed up on the install by not cutting the pipe clean. It left about a little over 1/8 of an inch off in an angle. I tightened the clamp as much as I can and still water leaks. But I guess it's normal for water leaks around the clamps.
    As far as the sound, it definitely increases the growl. At first since I got used to the quietness of our S3, but after the install was not sure if I liked the deep tone increase. But now, I'm loving it. Definitely sounds better than stock. No drones at all and you can hardly hear it on the freeway not unless you punch it. At low RPM's you definitely hear the deep tone. I think our cars should sound like this from the lot.
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    Did it..cheap mod and much better sound. Not too loud as long as you don't get an aftermarket down pipe..
    Sent from my ONEPLUS A3000 using Tapatalk
    Established Member Two Rings ava the a4's Avatar
    Mar 13 2018
    Newport News, Virginia
    I did a muffler delete on mine and i love it, i think it would sound louder than a res delete but not too crazy, my A4 is straight piped and it’s pretty loud. The A3 has a great tone tho and you can hear the shifts really well.
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Quote Originally Posted by ava the a4 View Post
    Thats what I did on my bug and it sounded great. Res delete doesn't do too much, still sounds like crap but saves a couple pounds. I should have gone muffler delete.
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Established Member Two Rings PINGERS's Avatar
    Oct 17 2018
    Cape Coral, FL
    If you go aftermarket downpipe or plan on it - I would leave your resonator. Otherwise, expect major drone and rasp.
    CTS Catless Downpipe | ECS Kohlefaser Luft-Technik Intake | APR Turbo Inlet | JB4 Map 6 | E85 3 Gallons | BMS Intercooler | CTS S3 Catback | Bilstein B14s
    Jul 09 2007
    Phoenix
    Just to confirm, you guys did this on an S3 or A3? I have A3 2.0T quattro
    Veteran Member Four Rings HBird's Avatar
    Jul 18 2015
    2019 Ranger, 2023 4Runner
    Snohomish, WA
    Did an OEM res delete on my S3 and I thought it was really nice. When I added a DP it got a little raspy, but still not terrible. There is some drone, but again it's not too bad IMO. FWIW I don't think any MQB car sounds great with any exhaust setup, they're going to be raspy sounding compared to other VAG 2.0Ts.
    - Hunter
    I got me a Ferd now
    Sep 09 2018
    Suffolk County NY
    My S3 already had it when I picked it up. It sounds great - better than my partner's S4 too. So, yeah I like it :)
    Jul 09 2007
    Phoenix
    My dealer is telling me they can't order this, anyone got another source?
    Dec 10 2004
    R8_LS400
    Dallas, TX
    ecstuning.com
    Apr 03 2018
    2018 S3, 2013 VW CC
    Resonator Delete OEM
    Here you go..
    https://www.shopdap.com/8v5-071-904.html
    Sep 21 2015
    Orange County
    I did a resonator delete and wasn't happy. It was too quiet, very close to stock. Ended up getting the exhaust removed the same day. Sounds a lot better, DSG is noticeable, however it's kinda droney.
    Oct 13 2018
    B8.5 Allroad
    Istanbul/Turkey
    Just get a pipe welded at an exhaust shop IMHO no need to pay for that 200$. Any type of resonator delete will cause drone around 3000 rpm. It sounds good but nowadays I'm considering a downpipe and install the resonator back.
    Jan 07 2018
    Stapleton, CO
    I had Castillo’s exhaust shop weld a 3in pipe from my downpipe into my stock muffler for $102. Works great and I wouldn’t consider much(yes still some) drone to be happening.
    I have a catless Downpipe as well with my setup. I was mainly looking for that touch of extra flow and sound but keep the stock muffler so I seem OEM all around.
    Jul 20 2009
    2001 A4 Stage 3+
    Spokane, WA
    Like it a lot on my S3. No drone. No leaks at the clamp - gotta get a straight cut, man! And the extra cost for OEM is worth it to avoid any warranty hassles with the dealer.
    Established Member Two Rings smirk's Avatar
    Oct 12 2018
    San mateo, ca US
    Did this today, and so far I'm loving it! Local audi/vw tuner shop quoted me $360 for the part and 1.5 hour install. Thought that was outrageous so I bought the ECS tuning's delete for $123, rented a lift for $35 dollars, and got this done in ~30 min. The shop even supplied me all the necessary tools including the pipe cutter free of charge.
    Things I notice:
    It's much louder around the power band and is peak volume between 3-4k.
    I can cruise the highway and it's still quiet.
    DSG Farts much louder
    Driving the car is a more visceral experience.
    Also I should note I have the exhaust flaps set to always open via OBDeleven.
    Jul 08 2017
    2008 B7 RS4 - Misano Red
    Muscat, Oman
    I was really thinking of doing this. Then I thought I wouldn't want to cut the pipe, so I went for a downpipe and I do not feel any difference in sound.
    Veteran Member Four Rings Grey3's Avatar
    Mar 14 2018
    B8 S4, mk6 Jetta, 2 mustangs
    Sherrills Ford NC
    Any insight on how a 1.8 t sounds w resonator delete? Supposedly it's a different kit than the 2.0t
    Sent from my phone using Tapatalk
