Results 1 to 33 of 33
    Oct 20 2018
    Socal
    lowering a B7 A4
    Hello, I am currently driving a 2008 a4 s-line, I want to lower it and get different wheels and was wondering what wheel and suspension combos others have used, i'm leaning towards lowering springs because of financials, I want to see what's being done out there, pictures are welcomed by the way all work will be done by me
    Veteran Member Four Rings dalmation53's Avatar
    Aug 19 2013
    Miami
    Did you even search? This has been discussed 133849274748384 times.
    Sent from my G3313 using Audizine mobile app
    Ivan
    Quote Originally Posted by dalmation53 View Post
    At least that many times...
    https://www.audizine.com/forum/showt...-Stance-Thread
    https://forums.vwvortex.com/showthre...-Fitment-guide
    https://www.audizine.com/forum/showt...4-Wheel-Thread
    2008 B7 2.0T Quattro 6MT
    Sold:
    2013 VW CC R-Line
    2005 B6 1.8T Quattro 6MT
    RIP:
    2002 B6 1.8T - April 2019
    2004 B6 3.0 - August 2018
    Oct 20 2018
    Socal
    yes I did but decided to ask and get some fresh answers
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Quote Originally Posted by tassospel View Post
    Nothing has changed.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    I highly suggest a cup kit (matched shocks and springs) over a "budget" coil over kit.
    Vogtland, H&R, Stasis (if you can find them), etc
    I have personally run ST coilovers, Vogtland cup kit, and a new old stock Statis kit. Both cup kits outperformed the STs, both on the street and on the local road course.
    Perfect stance IMO.
    2019 SQ5 Prestige
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Grab chainsaw cut on black line. Cars low.
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    To add, I would not just swap the springs on your tired, 10+ year old stock shocks to save a buck. This holds doubly true if you’re paying a shop to install them. Do it right or do it twice is what they say.
    You can’t go wrong with a solid cup kit, but something like ST coilovers are great too, not pricey, and are adjustable so you can dial in your height how you want it. I ran those before I bagged my car, and I would pick up a set again in a heartbeat. There’s a used set right now on the classifieds too I believe
    2007 Porsche Cayman | 5MT
    Jun 23 2008
    Eurocollective has $299 coilovers. :)
    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    Quote Originally Posted by texasboy21 View Post
    ^this, I went with vogtland kit, 35mm drop from stock base non sline, cheaper, like the stance and comfortable ride, AND I’m prefer German made parts.
    Established Member Two Rings rbjeepthing's Avatar
    Oct 03 2018
    08 A4 Avant, 95 YJ, 01 Duramax, 18 JK
    Innisfil, Ontario, Canada
    Quote Originally Posted by Dondbg View Post
    What are your wheel specs?
    Aug 19 2013
    Miami
    I went with jom coils. $400 shipped made in germany. Couldn't be happier
    Ivan
    Mar 12 2016
    The land of Kiwis
    Quote Originally Posted by rbjeepthing View Post
    18,8.5,45P wrapped with 235/40.
    Established Member Two Rings Snowboardguy989's Avatar
    Feb 02 2011
    F350 Dually, Volvo xc90 V8
    OKC
    Sts are the go to budget. You can gucci them up with hyperco rear springs. Or Eurocollective just introduced a set for 299
    -JHM stage 2 - Borla exhaust - 034 RSB - ST coils w/ hyperco springs - JHM Stage 2 clutch - 034 motor & trans mounts - JHM extra short shifter - APR HPFP-
    - TP - evolution thord skidplate - Devils own W/M - more stuff -
    hood RACECAR™ spec-rear diff mount
    Established Member Two Rings almorris93's Avatar
    Mar 23 2017
    E90 335xi
    Ann Arbor, MI
    Koni STR.T with Eibach lowering springs cup kit from ECS. $500.
    On OEM VW 18’s running an effective (with 10mm spacers in front and 15mm spacers in the rear) ET38 in front and ET33 in the rear. I believe my wheels are 18”x8”
    Oct 20 2018
    Socal
    thank you, your setup looks great!
    Oct 20 2018
    Socal
    Thank you
    Veteran Member Three Rings B7TitaniumA4's Avatar
    Mar 26 2016
    Montgomery County, PA
    Tein S.tech Springs (pulls the front down further than the rear)
    Koni St.r shocks
    adjustable upper control arms (front)
    20x9 with 225/35/20
    20x10.5 with 255/30/20 (rear fenders rolls a bit for clearance)
    this is aggressive.... and i have some rubbing on heavy bumps....
    Oct 31 2017
    SC
    Quote Originally Posted by canadianA4B7 View Post
    How did you link the vogtland cup kit? Any thoughts on how it compares the their coilovers or their Gt coilovers?
    Oct 31 2017
    SC
    Quote Originally Posted by DownhillA4 View Post
    Know anyone with them or reviews on them, seems interesting. Are the Chinese repackaged?
    May 20 2017
    New Hampshire
    Quote Originally Posted by Browsky View Post
    If they can intro them at 300 bucks and still make a profit, I think we both know the answer to that 😉
    Veteran Member Four Rings A4_PimP's Avatar
    Jan 18 2012
    Waterdown/Ontario/Canada
    Quote Originally Posted by Ashtonts View Post
    To add, I would not just swap the springs on your tired, 10+ year old stock shocks to save a buck. This holds doubly true if you’re paying a shop to install them. Do it right or do it twice is what they say...
    +1
    When you put lowering springs on the stock struts the struts will wear out quicker because there is not as much suspension travel. If you wait to change the struts the springs will have most of the weight of the car on it. So by the time you're going to replace the struts the springs will be flattened out and need to be replaced. Replacing all those parts plus paying for installation will probably add up to the cost of the coilovers. Just my thoughts.
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    What can you tell me about the cup kit? Is that swapping the B5 rear perches to get about an inch of drop in the rear?
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    May 20 2017
    New Hampshire
    Quote Originally Posted by mgfranz View Post
    Cup kit=lowering spring and shock combo. It has nothing to do with perches.
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by EvolutionArmory View Post
    More please, I thought using the B5 cups with stock components will lower the rear about an inch. I already am running the H & R sport springs and I love them, but I have that dreaded "rake" that I would love to get rid of.
    May 20 2017
    New Hampshire
    B5 spring pearches will lower the front more, not the rear.
    And believe it or not, your car is probably level. The fender arches are what make the front look higher.
    Apr 01 2007
    houston texas
    THIS.
    The fenders are different shapes front to rear. Instead of measuring from the ground to the fender, measure from the center of the wheel to the top of the fender.
    2019 SQ5 Prestige
    Apr 01 2007
    houston texas
    I loved the Vogtland set up. I dont think you can beat it in terms of price, handling, and comfort by anything that its 3x-4x as expensive.
    Ive had ST coil overs, with and without the upgraded Hyperco springs. They are garage. Ride poorly, handle poorly, and (as with any coil over) a PITA to set - I mean is anyone really corner balancing a car if youre running $700 coilovers..........
    2019 SQ5 Prestige
    Oct 03 2018
    Oct 31 2017
    SC
    Did you feel like the rear springs were too soft on the vogtland cup kit? I know some cheaper kits the tears tend to sag and vogtland has a stiffer rear spring combo on their gt coilover set
    Apr 01 2007
    houston texas
    Absolutely not. The Vogtland cup kit isnt a "budget" coilover that can be compared to a Riceland, JOM, etc. Its QUALITY german made part that comes with a lifetime warranty.
    The GT coils probably have a stiffer spring as the dampeners are different from the shocks/struts with the cup kit.
    I put 50K miles on the Vogtland kit before I parted my car and sold them to someone in Canada. They are still on the road today. It was just as good on mile 49,999 as it was on mile 1.
    2019 SQ5 Prestige
    May 20 2017
    New Hampshire
    Don’t buy cheap 3-400 coilovers if you care anything about how your car actually rides. I can almost guarantee that even B4 Bilstein sport shocks and HR springs will ride better and your cost is only about 500 bucks.
    A quality spring and shock kit will out perform most of the budget coilovers and I say most because I don’t like speaking in absolutes. If all you care about is being low and don’t care if they last a couple years or not or how they ride, cheap coilovers might be fine.
    I would never buy cheap coilovers when there there are so many proven spring and shock combos out there. Plus, who ever adjusts their coilovers once the set them anyway? 😀
    Oct 23 2015
    Australia
    Vogtland are great example of German excellence,go for the GT as the standard springs are way too soft.I ended up putting hypercoils in the rear,made lower adapters out of HDPE breadboard.NOTE many shocks mist oil early in their life,this is normal and stops after a while...
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
