Hey! Figured I could make a separate post for this now that I've started, and boy do I have some discoveries!
So the turbo went on Friday, loss of power and lots of smoke under boost/engine load. Attached pictures below might confirm some issue with the turbo and not necessarily the head gasget?
To my knowledge the valve gasget has been replaced before. I noticed the heat shielding next to the turbo and intake is really beat up, along with a bolt missing from the exhaust manifold (part number?)
Also, CEL came up after the supposed turbo went out.
Secondly, taking the airbox/intake out, I noticed the inside of the tubing before the turbo/after the MAF is wet with a LOT of oil. (see attached pictures. Section of plastic around and before MAF is dry as a bone.)IMG_20181022_162629.jpegIMG_20181022_162608.jpegScreenshot_2018-10-22-07-14-00.jpeg
Sent from my ZTE B2017G using Audizine mobile app
