A few months ago I purchased the 034 Motorsports solid rear swaybar for my Q. When it was first installed, the handling improvement was quite noticeable and I was very happy. However, after I had a Magnaflow catback installed, a small portion of the Magnaflow pipe (3 inch vs. >2.5 inch oem) would hit the thicker than oem 034 sway bar and make a loud metal banging noise. I then went to a muffler shop and had them slightly move the pipe further away from the sway bar and all was well. Unfortunately, sometime last week I started hearing what sounded like loose exhaust pipes jiggling underneath the Q so I went back to the muffler shop to figure things out. Once on the lift we saw the bracket on the left side of the sway bar was completely missing, with only the bushing still barely holding on. 1) Do you think this was incorrect bolt torquing by my mechanic or rather the short period of time where the exhaust pipe was hitting the sway bar that caused the bracket to come loose and fall off? Finally, would only the 034 brackets fit on this sway bar? I ask because last Friday I emailed and called 034 about purchasing one bracket and set of bolts only but have not heard back yet.
Let me know your thoughts, thanks.
