Results 1 to 16 of 16
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Accurate measurement of gas tank level
    The gas gague does NOT read accurately. Watched it while filling up. Was not linear at all. Since I run a bunch of different ethanol blends, I need to know the tank level. Is there another way to check tank level?
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I have been gathering data on this over the last month or so for that very reason as well, blending fuel. I have been recording fuel levels, gallons of each fuel type to get a picture of how many gallons it takes at E, 1/8, 1/4, 1/2 and 3/4 tank. My numbers are pointing to my car having a 16.9 gallon tank which matches the manual. Here is what I have been able to put together based on my fueling stops for the different levels. Still working on E as I usually don't let it get down that far.
    Gallons to fill at
    3/4 4.225
    1/2 8.45
    1/4 12.675
    1/8 14.7875
    I have access to flex fuel which measures 51% ethanol at my local station. I have found that a 1.3 to 1 ration of 91 to flex fuel yields me a E28 blend that is 95 octane. You will need to know the actual ethanol rating of the fuel at your station. I use a fuel-it tester, simple tube that you add fuel and water to.
    hope this helps you
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    May 08 2018
    Berkeley, CA
    Quote Originally Posted by cspcrx View Post
    Gallons to fill at
    3/4 4.225
    1/2 8.45
    1/4 12.675
    1/8 14.7875
    hope this helps you
    Thanks. Exactly what I needed.
    Jan 04 2013
    Phoenix, az
    This is what I am finding with my car so you should really look to see how yours is. I thought I saw a YouTube video online of someone doing a VAG COM to change how their fuel gauge read.
    Glad that helps.
    May 08 2018
    Berkeley, CA
    So half full on the gague took 6.5 gallons to fill up. Guess I need a different calibration curve
    Jan 04 2013
    Phoenix, az
    That seems way off. So you gauge showed 1/2 tank and it only took 6.5gals to full. WOW Something is off there. since your running full E85 curious if things are getting gummed up have you run some of that Ethanol cleaner through it? I presume our cars have a float type fuel sensor. Have you ever noticed your gauge moving oddly or not at all?
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    Gallons to fill at
    3/4 4.225
    1/2 8.45
    1/4 12.675
    1/8 14.7875
    So, on 1/4 is 4.22 (4.225) gallons. That means, when it empties, it's 16.9. I tent to fill at 14 gallons on empty (red)... thinking that there is 2-3 gallons emergency reserve. Is this not true?
    3.725 gallons per 1/4 tank with 2 gallon emergency reserve, then it'll be 14.9 gallons. I remember on remote highway on this car with the empty fuel light on, fuel gauge pegged all the way down and drove at least 3 to 5 miles (can't remember exactly).
    Also excuse my math if it's wrong, I'm drunk.
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    May 08 2018
    Berkeley, CA
    We're supposed to have 2 gallons left when range hits 0.
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    You should never let the remaining fuel to get so low, the fuel also provides cooling for the fuel pump,& you do not want to get any crud in the fuel to get into fuel injection system.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Jan 04 2013
    Phoenix, az
    Yes the feeling is at E there is still about 2 gallons in the car. But as you can see from my data my gauge is not reading like that based on my fill ups. I think mine is closer to 1gallon.
    Veteran Member Three Rings u2nelson's Avatar
    Oct 08 2012
    Home of the CR-15 brace
    Palmdale CA, United States
    Gallons to fill at
    3/44.225
    1/28.45
    1/412.675
    1/814.7875
    hope this helps you
    Those numbers to fill indicate the gage is very accurate.
    2013 S5 6MT / Monsoon Grey / APR Stage 2+ / AWE Touring+Res DP / EC Alu-Kreuz / EC USS system sways and links / Bilstein PSS10 coilovers / SPC ADJ UCAs / Spacers H&R 5R / EC Adj Short Throw Shifter / EC TF intake / Apikol rear diff mount / O34 Trany mount insert / BC Forged RS41 19x9.5ET20/ Mich PS4S 265/35/19 / Gyrodisk 2pc rotors / CR-15 Upper Strut Tower Brace / [email protected]
    Jan 04 2013
    Phoenix, az
    Those numbers are based on 16.9 gal tank and mine has been tracking very closely to these numbers. As a result that is what I am using as a guide for my blends.
    May 08 2018
    Berkeley, CA
    Do b8 have a smaller gas tank? I've run my tank completely empty before and it only took 16.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    So a 6mt has a 16.9 gallon tank instead of 16.1? I always thought DSG and manuel were 16.1. I read the fuel level from OBD Fusion too but I don't think that's accurate either lol
    Sent from my SM-G965U using Audizine mobile app
    Jan 04 2013
    Phoenix, az
    16.9 is all I have seen listed
    May 08 2018
    Berkeley, CA
    So. I am fairly certain the gague represents 15 gallons. Took 14.3 gallons to fill at 10 miles of range.
