I'm debating between these two gearbox oils for use in the RS5 (S-Tronic, DL501).
-Both meet Audi's standard for the DL501 gearbox.
-Redline is full PAO/Ester stock (Group IV and Group V)
-Motul is a synthetic blend
-Redline is about $6 more expensive per quart than Motul ($50 more in total cost)
-Redline is made in the U.S.
Specs
Redline 100% synthetic
VIS @ 212F=8.1
VIS @104F=40.7
Viscosity Index=177
Pour Point -50F
Flash Point ?
Motul Semi-Synthetic blend https://s3-eu-west-1.amazonaws.com/m...pdf?1510939252
VIS@212F=7.3
VIS@104F=33.8
Viscosity Index=189
Pour Point -49
Flash Point 385F
Adding others...
Rowe ATF DCT II Full synthetic
Viscosity @ 104F 32.8
Viscosity @ 212F 6.6
Viscosity Index 175
Flash point 366.8F
Pour point -40
Amsoil 100% synthetic https://www.amsoil.com/lit/databulletins/g3431.pdf
Amsoil
VIS @ 104F=38.8
VIS @212F=7.7
Viscosity Index=177
Flash point=446F
Pour Point -72.4
Pentosin FFL-4 ***Not confirmed to work with the S-Tronic yet*** http://www.pentosin.net/specsheets/pentosin_ffl-4.pdf
Viscosity at 104F 36.3
Viscosity at 212F 7.0
Viscosity Index 173
Pour Point -51°C/-59.8°F
Flash Point 224°C/435.2°F
Liqui-Molly 8100 DCT Fully synthetic https://pim.liqui-moly.de/pidoc/P000...00-31.0-us.pdf
Viscosity @ 104F 33.0
Viscosity @ 212F 6.85
Viscosity Index 174
Flash Point 392F
Pour Point -54F
Castrol Transmax Dual Full synthetic https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/8CA4D9C7A952E6C98025803C004AFC36/$File/BPXE-AEX992.pdf
Viscosity @ 104F 35.5
Viscosity @ 212F 7.2
Viscosity Index 166
Flash Point 446F
Pour Point -97F
Millers Millermatic ATF DCT-DSG Full synthetic https://www.google.com/url?sa=t&rct=...Kr-npFR_9Na03X
Viscosity @ 104F
Viscosity @ 212F
Viscosity Index 1
Flash Point
Pour Point
Torco DCT 100% synthetic
Viscosity @ 104F 7.0
Viscosity @ 212F 33.9
Viscosity Index ???
Flash Point -54C
Pour Point 383F
I will most likely not see extended periods of cold temperatures below freezing. Plus the car is garage stored overnight and it's insulated. I most likely won't track the car at a place like COTA (never say never!) but it will go to the drag strip periodically and most likely be run on a dyno.
They're both "thin" oils and should remove heat more efficiently than a more viscous fluid. I do not know what the specs are for the OEM-specified, Audi-branded transmission fluid (ATF side).
The Redline fluid is more viscous and should "protect better" but also has a lower VI (viscosity index) meaning it's viscosity is more greatly affected by temperature than the Motul (the higher the number the better).
The Motul, at operating temperature (212F) will most likely loose less power to frictional and pumping losses than Redline. Given that both meet Audi's standard, I'm thinking wear protection wouldn't really come into play. I don't plan on extending the change intervals.
I see a lot of GT-R guys running Redline for their track-driven cars. Both are spec'd for a ton of different brands including Ferrari (and the aforementioned R35 GTR).
I know the Motul is GL-4 rated. My understanding is that GL-4 is designed for cars with brass synchros. No rating on Redline.
Anything I'm overlooking or not understanding correctly? Wondering if the full synthetic is the way to go. My only hesitation is that Motul may protect just as well, cost less and produce a few hp more due to it's lower viscosity at operating temps. Probably splitting hairs but facts and even opinions appreciated.
