Page 1 of 13 12311 ... LastLast
Results 1 to 40 of 481
    Jul 14 2017
    2008 RS4, 2013 Honda Odyssey
    Candler, NC
    2008 RS4 Rear Turbo Build (56k Warning)
    Hi everyone! I joined the forum last year just prior to buying my first Audi, a completely stock 2008 RS4 with 65k miles in beautiful shape. It was a dream come true and I didn't waste any time making it "mine".
    Jul 14 2017
    Candler, NC
    The first changes I made included a 034 Rear sway bar with adjustable end links, KW V3 coilovers, 034 density front control arms, ECS short throw shifter, Goodridge brake lines, and an ECS H-pipe to add a bit of sound while I planned some much bigger changes.
    Jul 14 2017
    Candler, NC
    Now the fun begins! Since I am the Aftermarket Program Manager for BorgWarner Turbo Systems, I have access to some neat hardware and I took advantage of an opportunity to do some testing. With a 72mm S400SX-E and two 48V pre-production eBoosters, this build is all about a flat torque curve and not much more. My target is ~500 ft-lbs from as early in the rpm range as possible (~1800 rpm target) thru 8250 rpm. The early torque development will be knock limited, so I'll ramp the eBoosters in as quickly as good combustion will allow.
    Jul 14 2017
    Candler, NC
    The work begins with reshaping sheet metal in the trunk area. The reworked area will make room for the S400 on the left and the twin eBoosters on the right. The exhaust plan is a quick merge from the stock headers to a single 2.5" SS exhaust on the left of the tunnel. This will transition to a brief 2.5" oval section before a 90 deg bend into the turbine housing. The turbine outlet will face forward and split left to a valved 3" dia outlet and right to a 3" muffled outlet. The charge plumbing will head back up front on the right of the tunnel.
    Trunk area work to be completed in future post...
    May 29 2012
    Evergreen, CO
    Sub'd to watch this ambitious build.
    Nice dag and bike, too.
    2025 RS6 Avant Performance
    2020 SQ5
    2018 RS3
    2015 B8.5 S4
    2007 RS4 Phantom Black
    2007 RS4 Mugello Blue
    Jul 14 2017
    Candler, NC
    To document the before and after, I put the car on a local Dynojet to get a baseline. It's been about 15k miles since the last carbon clean so I'd consider this pretty solid results for a stock daily driver. She has 80k miles on her now.
    Jul 14 2017
    Candler, NC
    The eBooster control plan is to use a RaceCapture Track unit to read all ECU data thru the CAN bus, then command the eBoosters via the 2nd RaceCapture CAN bus based on the control logic I create using Lua scripting. To monitor things and access the RaceCapture data, I installed a Xtrons Android 8.0 head unit. This decision went against my preference for OE fit and finish, but it fit well and required only a little work to make it perform great. I ultimately decided to not use the Xtrons RCA outputs to send sound to the factory amplifiers due to the noise, and instead I added some PAC line out converters with integrated ground loop isolators to keep the signal clean. This worked great and things really sound good!
    Jul 14 2017
    Candler, NC
    Here is a cardboard mock up of the new shape for the trunk area. I'm thinking the top area will have a sheetmetal perimeter and a machined aluminum cover that bolts down to the perimeter. This will allow easy access to the top of the turbo and eBoosters while keeping the trunk area sealed off and a clean setup. The stock trunk carpet will remain to keep the OE look and function.
    Senior Member Three Rings PigDiesel54's Avatar
    Jan 18 2013
    Wow can't wait to see the outcome. Some of the photos you posted have broken links.
    Sent from my SM-N950U using Audizine mobile app
    2006 Brilliant Red B7 S4 Avant 6MT
    2001 Cactus Green B5 S4 Avant 6MT - RIP
    2006 Brilliant Red B7 A4 Sedan 2.0T TIP - SOLD
    Jul 14 2017
    Candler, NC
    It seems like some of the embedded pics dont show on my phone but show just fine thru my PC. I use the same process to embed all photos: Copied image link from Google Photos, shortened link using goo.gl, then used the "Insert Image" link in the forum to [IMG] it....hmmm
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    I see no pics, and I certainly want to lol
    Jan 18 2013
    I've never had a problem using imgur on AZ
    Veteran Member Three Rings ginch's Avatar
    Jun 30 2011
    calgary, alberta
    Cant see pics and really want to!
    2008 Avus silver RS4
    1996 993 C4S
    2017 Tacoma TRD Sport, Quadcab shorty, 6 speed, Wife's daily!
    Gone
    2016 Reflex silver Golf R, 6 speed
    2008 Phantom black RS4
    B7 S4 Avant
    1993 964 C2
    2004 Reflex silver .:R32
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Party time Eric. I'll come visit to help 😁
    Nov 03 2011
    All Over!
    I can’t see any photos either...
    ...and I too really want to.
    1986 Type 85 Audi 90 quattro
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    I saw the pictures when I first opened the thread, and now they're not working :(
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Eric,
    You can just use the attachments feature on this forum. When you go into edit or reply to a post you can go advanced, click the paperclip symbol or the button below the body text box and click manage attachments. Then upload...
    Veteran Member Three Rings JorisRS6's Avatar
    Jun 06 2017
    2003 RS6
    Norwich Canada
    Cant see pics either. Only the video
    Jul 14 2017
    Candler, NC
    Pics should be fixed now...I hope Flikr works better than Google Photos
    Veteran Member Four Rings eurojunkjon's Avatar
    Mar 12 2017
    2013 S4
    Burlington, wi
    I can see them now.
    Can’t wait to see this thing finished
    Established Member Two Rings Mal's Avatar
    Jul 29 2012
    WV
    This is an awesome build! A stock RS4 captures my attention, a boosted RS4 even more so.
    2004 S4 Avant
    Nov 12 2015
    Oregon
    Subbed!!!!
    Sent from my SM-N920V using Tapatalk
    My build log
    Veteran Member Four Rings b6bydesign04's Avatar
    Nov 14 2005
    Charlotte, NC
    Oh my, this should be great. I'd love to see this car in person once it's finished too, we really need to setup a fall mountain run in Asheville considering how many RS4's we have in NC now.
    -Sean
    '06 Lexus GX470 | Dobinsons | fifteen52 | BFGoodrich | Prinsu | Gobi | Orangeboxx | RSG
    '11 BMW E90 M3 | ESS S/C | Recaro | M Performance | iPE | BC Racing | BPM | Volk | Coby
    F.T.W.L.T.B.D.W.I.C.T.W.
    Dec 15 2009
    Vancouver
    Wow, looking forward to seeing the build progress
    Nov 10 2017
    Can't wait to see this!
    Veteran Member Three Rings my_RS4's Avatar
    Apr 15 2016
    Beach Cruiser
    Venice
    IG @myRS4 | 2007 RS4 | Phantom Black | Ti Converted | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed + Citied + CC'd | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | JHM Lighweight Flywheeled | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by EricZ View Post
    why use a line-level converter with ground-loop isolator rather than an isolator on the RCAs themselves? Was there a different in sound quality going that route? I tested an XTRONS unit briefly around a year ago, but there was so much noise (GL and otherwise) that it didn't seem like a GLO would be sufficient to resolve the issue (esp when headlights turned on)
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Jul 14 2017
    Candler, NC
    Quote Originally Posted by Matt Devo View Post
    I tried some PAC GLIs on the RCA outs but they also cut out some of the low frequencies too, so it lost some bass. Also, the overall sound quality from the RCAs was not that great. I did go thru the logical steps and the line level converters was a last resort, but ended up being what I should have done from the beginning. It really sounds awesome now!
    2008 RS4 Build
    BorgWarner S400SX-E 72mm + twin 48V eBoosters
    TiAL WG & BOV
    Cascadia Motion 48V Battery & BMS
    Control System: Teensy 4.1 + Two Arduino Megas + RaceCapture Track MK2
    CM 850 Strapped twin disc clutch
    Liquid-air IC + WMI
    IE HPFPs, Walbro 525 LPFP + Torqbyte PM4
    KW V3s + 034 Rear sway
    620whp & 480 ft-lbs peak @ 12psi - more to come!
    Aug 09 2012
    Bay Area
    Does the head unit work with the navigation in the cluster as well or has that been disabled due to the aftermarket unit?
    Feb 17 2004
    Liberty Hill, TX
    appreciate the input, thanks!
    Quote Originally Posted by Kambesama View Post
    I'm not aware of any aftermarket units which send navigation directions to the cluster. It's not a technical limitation, since they send song info etc, it's just they haven't invested in the software to translate 3rd party map software directions into something usable on the cluster (which is non-trivial)
    Senior Member Two Rings bendilzerian's Avatar
    Jul 25 2018
    Texas
    Wow. Subbed.
    Established Member Two Rings Lesterine2004's Avatar
    Nov 20 2017
    Philadelphia
    sub-freaking-scribed!
    Jul 14 2017
    Candler, NC
    No, the nav in the cluster is disabled with the Xtrons unit. It does show radio, mp3, and cd info, but even that is somewhat limited. This is fine for me since I will ultimately use the cluster display for other information all together, but this is low on the priority list for the build.
    2008 RS4 Build
    TiAL WG & BOV
    Liquid-air IC + WMI
    Jul 14 2017
    Candler, NC
    5.5" 90 deg inlet arrived and it will fit, but I may swap to our "compact" compressor cover which has a smaller 5" inlet. Also, 3" vacuum activated exhaust valve arrived. This will control the left exhaust outlet with the "S" button, much like the factory mufflers are setup (more noise with "S" depressed).
    2008 RS4 Build
    TiAL WG & BOV
    Liquid-air IC + WMI
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Excited to see how this plays out. Nice buell as well
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Jul 14 2017
    Candler, NC
    Quote Originally Posted by melomandn View Post
    Thanks! That XB12R was a bike I built for someone else, but very similar to the one I just sold. I am now on a KTM Super Duke 1290 R and love it! Here is my old turbocharged XB and build site:
    www.streetfighterperformance.com
    2008 RS4 Build
    TiAL WG & BOV
    Liquid-air IC + WMI
    Jul 14 2009
    Pasadena
    this thread escalated quickly
    IG: @matthewee
    Junior Member Two Rings Jnaut's Avatar
    Jan 03 2012
    Q7 A4 and S4
    NC
    FF
    Apr 01 2015
    seekonk ma
    Veteran Member Four Rings ENVē's Avatar
    Nov 04 2010
    Yep, Ill be watching.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
