Originally Posted by
chris86vw
There is no bulb alignment it is either in or not unless it was forced into place incorrectly.
Do you have a current pick of the light against the wall like the one you took previously?
Current lights are stock projectors with clear lens and the upgraded morimoto bulbs? (can you just updated us on exactly what you have for hardware. )
You found aftermarket ballasts did you confirm they were the same? The output in the old pick was huge, but that could have been different age bulbs but also it is possible that the weird aftermarket ballasts one was a 35watt and one was 55 watt.
Sure, I can get a pic on the garage again tonight or tomorrow morning. The other ballast was the Hella OEM ballast not aftermarket but here is what I dide.
Got condensation in the passenger headlight last fall (not sure if it is related to anything)
December the passenger headlight took a crap ^pic above, light basically went amber.
I opened up both headlights, cleaned the lenses and reflectors.
Swapped the old bulbs for Morimoto XB35 5500k bulbs. I didn't force anything so alignment should be proper.
Resealed the headlights
Did not end up swapping the projector glass for the clear lenses,
Did not take out and inspect the projector.
Now the driver side appears to be working fantastic while the passenger side pattern is weird/off.
Here is an edited version of the pic above showing the difference.
