Page 1 of 3 123 LastLast
Results 1 to 40 of 88
    Jul 21 2004
    South Florida
    Aeroforce Technology Gauge with Podi...
    Thanks very much to forcefedjunkie for introducing me to this gauge. I contacted HS Tuning and had it sent out to me with some custom touches. It was 229 plus 20 in custom work.
    I also purchased the podi gauge pod from ecstuning.com for $40 and drilled out the back of the pod to get the aeroforce gauge to fit perfectly.
    This gauge is awesome so far. Its nicer than my p3 multi gauge in the other car.
    The first thing I noticed was that the gauge responds immediately when you turn the ignition on. I had been having trouble with one of my P3 gauges only responding about half of the time when you turn the key on.
    This gauge has all the parameters on it you would need. I like to keep two parameters on the main screen and I have set it up so that you can toggle between four different items on each of those two parameters. I took some photographs to better explain. To summarize you can monitor everything from boost 2 air fuel ratio to fuel pressure to transmission temperature to intake temperature to ignition angle and retard and it goes on and on and on.
    This gauge also allows performance parameters which I have not delved into much but I believe it would be things like 0 to 60 times and the like.
    In addition to that it does graphing functions in real time and it clears codes and reads codes
    the final function is that it allows you to cycle on and off the radiator fans when the ignition is not on. This will allow you to rapidly cool your intake temps while you're waiting in the staging Lane without having to turn the air conditioning or the engine on which is mandatory at many tracks.
    Mike
    2018 Audi S5
    Gone-
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Interesting Mike, it does all this thru only the obd2? Any pix of the rear of the pod?
    Sent from my SM-G965U using Tapatalk
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings deucescorner's Avatar
    Aug 26 2008
    None
    None
    How much? And where can you purchase it from?
    Jul 21 2004
    South Florida
    Yes only uses the obd2. Plug and play
    Sent from my SM-G935V using Tapatalk
    2018 Audi S5
    Gone-
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by deucescorner View Post
    Lol he literally said how much and where he got it.
    Veteran Member Three Rings AFR1485's Avatar
    Nov 24 2015
    Fiat 500
    Great post. I’ve been looking for a podi alternative
    Senior Member Three Rings EAFLO88's Avatar
    Dec 08 2016
    Texas
    Just read up on all the features of this compared to the P3 gauge. For the price, it’s unbeatable and seems like it can be installed in a few minutes. Thank you for sharing this with us all.
    Dec 03 2008
    2018 SQ5
    Looks like you can hook up 0-5v sensors to it, so can be used to display ethanol content too. Awesome.
    Oct 13 2009
    MN
    This is nitpicking but it would look a lot better with a black background instead of blue - the screen that is.
    2013 S4 - Glacier White - 6MT - Sport Diff - GIAC Stage 1 - Scorpion 2.5" Exhaust - Performance IE Intake - StopTech ST60
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by CrownSeven View Post
    You can flop the display negative so it's black with blue numbers
    Oct 13 2009
    MN
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    They also offer other colors, thanks posting your install
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Mar 31 2008
    eS-4
    CAL*SO
    Haha. I kept thinking it looks like a fancy apexi controller.
    I'm curious to see more color matched options..
    Right now I'm using my phone/torque pro and I can do everything this thing can...but I really want a podi boost gauge! Waay better than p3. (to me at least)
    Jul 21 2004
    South Florida
    Ive used phone apps and they are very slow with data capture like running 8 channels in vcds NOT in turbo mode. This direct wire gauge seems to be logging much faster which is important for things like timing, fuel pressure, knk where you want to getcas much data as possible
    Regarding the screen color yes that is what it is. I bought the black/white model so you see the negative screen image is going to look a slight bit blue but it does not look like it looks in the photo. The photo makes it looks much more blue for some reason. In person it looks more grey. I assume thats the same for all positive colors like you can also choose blue or red.
    Mike
    2018 Audi S5
    Gone-
    Veteran Member Three Rings dlo93's Avatar
    Jun 27 2012
    1998 Audi a4 1.8t, 2012 Volkswagen GTI
    Bridgewater, New Jersey
    Does anyone know if the p3 gauge is direct plug and play into obd2 as well?
    2014 phantom black s4//20% tints//Carbon imports low kick spoiler//APR Stage 2+ dual pulley ECU and TCU//APR CPS//Roc-Euro Intake//AWE touring with non-res downpipes//
    Jul 21 2004
    South Florida
    Yes it is
    2018 Audi S5
    Gone-
    Jun 27 2012
    Quote Originally Posted by bhvrdr View Post
    Yes it is
    Worth it for the price?
    Jul 21 2004
    South Florida
    Quote Originally Posted by dlo93 View Post
    I like the P3 gauge a lot. I've had 3 of them on different cars. The integration of the P3 blends very well into the interior of the car. I only have a couple minor critiques of it now comparing it to the aeroforce.
    1. The P3 doesnt always respond when turning the car on. I dont know why. Two of mine were 95% good at firing right up. This last one I have had is only about 50% for starting up when you start the car. So you literally have to shut down the car and start it up again to get the gauge to work.
    2. The P3 "actual boost" reading tends to be off by about 2-3psi. This is after they started reading off the supposedly correct channel of "actual boost" I'm not talking about their old sofware package where they measured only "specified boost" which was lazy and the wrong thing to do.
    3. The P3 is slightly light on channels you can measure. Its an OBD2 gauge so why limit the user to only a handful of channels?
    4. The price of the P3 is a tad high
    The aeroforce, so far, solves all of those issues. It fires up instantaneously. It reads a ton of channels that are all relevant and they do seem accurate as well. The gauge also does graphing, it will record data for you, it will read and erase codes, and it will control fans and 2 analog inputs. Its price is a relative bargain IMO. That said, the downside is that you do have to work on the factory integrated look more yourself. I can see trying to vent mount it would work well. I like the PODI pod so far but yes you can tell you have an aftermarket gauge on your dash.
    Mike
    2018 Audi S5
    Gone-
    Jun 27 2012
    Mike
    Great write up thanks... so including the you getting the S logo on the front it was about $289 total correct?
    Jul 21 2004
    South Florida
    I believe it should be $269. Its 249 plus 10 for the silver bezel and 10 for "custom work" Then its $40 for the PODI gauge pod.
    2018 Audi S5
    Gone-
    Jun 27 2012
    Ok, so a tad more overall than the p3.
    Jul 21 2004
    South Florida
    The p3 multi gauge is 389 without a vent. Its 579 with a vent. Plus you need to add 25 for track pack chip to monitor iat.
    2018 Audi S5
    Gone-
    Jan 04 2013
    Phoenix, az
    I was digging through the Arduino thread it and it looks like you could build one to connect to an flex fuel sensor. It would then send the signal to this gauge so you could display ethanol content as well.
    I have not seen one of those steering wheel pods in person but from your eyes view what does it look like, are any of the gauges covered? Also how is the gauge at night, does it dim automatically?
    Jul 21 2004
    South Florida
    From my seat position the gauge blocks from 0rpm to 200rpm in the left eye and from 0rpm to 600rpm in 5he right eye. Basically nothing
    2018 Audi S5
    Gone-
    Jan 04 2013
    Phoenix, az
    Thanks how is the lighting at night?
    Jul 21 2004
    South Florida
    No complaints. I keep it positive image so negative background and i can read it fine in the day and it doesn't annoy me at night. Its not autodim though
    2018 Audi S5
    Gone-
    Oct 30 2012
    Oxford, MS
    Could you describe the custom work that you had done? I'm think this is what I might put on my wish list for Christmas.
    Jul 21 2004
    South Florida
    Quote Originally Posted by chilort View Post
    I believe i paid 10 bucks for the silver bezel which really compliments the other gauges and 10 for the "insignia" which the company would prefer not to advertise due to any possible copyright issues.
    Btw the gauge really doesn't look as blue as the photos...
    2018 Audi S5
    Gone-
    Oct 30 2012
    Oxford, MS
    Got it. Thanks!
    Veteran Member Three Rings hellovaras's Avatar
    Oct 28 2018
    PNW
    Hey there I am interested in getting one of these. What has been your overall experience? Do you still have it? Any issues?
    2013 Monsoon Grey B8.5 S4 6MT | ECS CF Wing | ECS CF Front Lip | Canyon Run-15 Strut Brace | ECS Front Strut Tower Bar | Injen CAI | ECS Center X-Pipe | 034 Motorsports Rear Sway Bar | ECS Tuning Lower Control Arm Brace | Ziza Interior Light Kit | Luft-Technik Intake Air Scoop | ECS CF Antenna Cover | ECS CF Rear Diffuser | IE Stage 1 |Do Tinted Windows Count?
    Jul 21 2004
    South Florida
    Quote Originally Posted by hellovaras View Post
    I love it. Its been better than the multiple p3 gauges ive had. Its dead reliable.
    2018 Audi S5
    Gone-
    Oct 28 2018
    PNW
    Hey man, any pointers on installing the podi for the gauge? I am having a hard time and don’t want to ruin the gauge or the mount.
    I can’t get it to snap into place. Don’t want to force it.
    Does yours look like this? Thanks
    Jul 21 2004
    South Florida
    You have to hollow out the back
    2018 Audi S5
    Gone-
    Oct 28 2018
    PNW
    I am a moron. I was trying to attach the podi without first removing the plastic piece from the steering column!
    To me:
    “You should be ashamed of yourself and your whole family” - Shawn from Psych
    Jul 21 2004
    South Florida
    Lol we've all been there
    2018 Audi S5
    Gone-
    Established Member Two Rings S5Black's Avatar
    Mar 24 2019
    2014 Audi S5 S-Tronic, 2020 Jeep Grand Cherokee
    Nevada
    bhvrdr how does the podi attach? Thanks
    Jul 21 2004
    South Florida
    Quote Originally Posted by S5Black View Post
    It just replaces the top column trim piece.... snaps into place.
    2018 Audi S5
    Gone-
    Mar 24 2019
    Nevada
    Thanks.
    May 05 2018
    South Florida
    Do you have to do any additional wiring for the fan control? I think that alone is worth the purchase.
    Jul 21 2004
    South Florida
    Quote Originally Posted by killer_s4 View Post
    nope, its all handled through the OBDII
    2018 Audi S5
    Gone-
