Page 1 of 8 123 ... LastLast
Results 1 to 40 of 291
    Veteran Member Three Rings s4nicetry's Avatar
    Nov 29 2007
    Calgary / Vancouver
    What brake pads should I use? - Just kidding (New Pad Choice)
    I thought I'd add another set of pads to our short list of options for the 4.0T "S" cars, the bonus is they are really cheap as well. I was one of those people that couldn't stand the squealing when coming to a stop and the insane amounts of dust produced by the stockers. It was time to shop for something else. I have been a huge fan of Akebono for a long time, have used them on many of my other street cars over the years and was very disappointed to find out they didn't make fronts for our S's. Seeing how I have no intention in taking this boat to the track I wanted a ceramic pad with low dusting, no noise and functioned as close to the stockers as possible.
    My first thought was EBC redstuff, but I did have a bad experience with them years ago and while that doesn't mean anything for the S6, I have heard a couple of complaints and with their high price I decided to keep looking. Disk Italia's seem to be liked but here in Canada getting my hands on a set was a pain and the cheap Wearever pads are nearly impossible to get my hands on as well so the search continued. Snooping around I came across Powerstop Evolution Z16 ceramics. Searching the interweb they seem to have great reviews on many forums including Corvette and BMW forums which complained about noisy, heavy dusting oem brakes like us and seemed to be very satisfied with these Z16 pads. So I said screw it and decided to get myself a set to try out.
    Well it's been a month or two now, I've got about 1,000km(ish) on the car and so far am very impressed! Quality seemed great, they came with the weights mounted on the fronts like OEM, the wear sensors fit perfectly, and the backing plate was identical to oem. One install note I'd like to mention is I bought the car from the dealer in Feb. and it did come with new pads and rotors so my plan was to pry off the anti vibration dampers and reuse them. Well to my surprise when I removed the first front caliper there was no anti vibration dampers installed! I was pissed but was already elbows deep into the job so I decided to take pictures for the dealer to complain and carry on with the install. I just used some synthetic anti rattle like any other brake set install and put it all back together.
    They have a bedding procedure for the pads which I went out and performed immediately and so far the brakes are fantastic. I constantly try to get them to squeal by using diffent braking methods. Light, medium, aggressive, cold weather, warm weather, nothing, silent. Brake dust is 80-90% reduced I'd say, the difference is night and day and driving wise these pads perform great as well. Very oem in feel, almost too grabby for my taste. I perfer a more progressive pedal though without the harsh initial grab like Akebono's have always been for me, but I know a lot of people prefer the hard initial grab that stock pads have.
    That's all I got for now, I will keep on trying to get these to squeal so I can go and raise shit at the dealer for not using the anti-vibration shims like they should have, but so far so good and I couldn't be happier with my choice. A cheap pad that does essentially everything I want it to on the street. This should be another good option for people and hopefully this review will help those still on the fence.
    Established Member Two Rings Swirv's Avatar
    Jun 09 2018
    2017 Audi S6
    CSRA, GA
    Quote Originally Posted by s4nicetry View Post
    Well it's been a month or two now, I've got about 1,000km(ish) on the car and so far am very impressed! Quality seemed great, they came with the weights mounted on the fronts like OEM, the wear sensors fit perfectly, and the backing plate was identical to oem. One install note I'd like to mention is I bought the car from the dealer in Feb. with ext. warranty still remaining for six months. I figured that would be enough time to figure out if the car was a lemon or not and so far zero issues. Now they did come with new pads and rotors so my plan was to pry off the anti vibration dampers and reuse them. Well to my surprise when I removed the first front caliper there was no anti vibration dampers installed! I was pissed but was already elbows deep into the job so I decided to take pictures for the dealer to complain and carry on with the install. I just used some synthetic anti rattle like any other brake set install and put it all back together.
    Great review/find! Thanks for the feedback and I’ll be following the thread to see your future feedback.
    Sent from my iPhone using Tapatalk Pro
    2017 S6 | White Ext. | Arras Red Int. | S6 Sport Pkg. | Black Optics Pkg. | Driver's Assit. Pkg.
    Veteran Member Three Rings MolonLabe300's Avatar
    Aug 16 2017
    Chattanooga
    Thanks for this post! I am going to try these out.
    Sent from my Pixel 2 XL using Audizine mobile app
    13 S6 SRM +4mm, Flex Fuel lines with ethanol sensor, Milltek turbo back, SRM Red Long intakes, NGK race plugs, AMG coolant pump. Merc HX, DS1 OTS stage 4, SRM TCU
    Veteran Member Four Rings ntsantos's Avatar
    Dec 06 2015
    San Ramon, CA
    I just checked compatibility for an S8. At $35 a pair, they'd be worth trying. Especially if they have the grab you're describing. Nice post.
    Sent from my SM-G960U1 using Audizine mobile app
    Jun 09 2017
    Signature
    GTA
    I use these pads for my Golf R's upgraded BBK and like you say, they do have really nice initial grab and they don't produce alot of dust at all.. I previously had EBC yellows and the dust is drastically lower with the Powerstop Z16 Ceramic pads..
    My only negative is that on extremely hard braking from high speed, these pads will fade. I have slotted and drilled rotors, was very surprised they fade like this. For my BBK, I also upgraded the brake fluid to RB600 at the same time, so it is a pad issue and nothing else..
    For normal and even short sprints driving on the street, they have never faded, squealed, or given any issues. With the nice initial bite, it gives you confidence in braking (until they fade, if they do). Not sure if the additional weight our cars have will have any impact on the fade issue. To sum it up, these are a really good street pad, just not sure if I would hit the track with them. I've been using these pads for roughly 20k kms.
    Of course my experience on a different car may not carry over to this platform, just though I would share my experience..
    Current Line-Up:
    2008 911 Turbo Cabriolet Manual
    2012 VW Golf R - APR in-house build Stage 4
    2002 Audi TT 225 Quattro Roadster - Big Turbo
    1995 Camaro Z28 6 Speed - Just Bolt-Ons
    Gone: 2015 Audi S6 - Stage 3 / 2015 Audi S4 - Stage 2 / 2012 Subaru Sti Hatch
    Jun 09 2018
    2017 Audi S6
    CSRA, GA
    Quote Originally Posted by 15 Phantom S6 View Post
    What do you mean by "Fade"?
    Jun 09 2017
    Signature
    GTA
    Quote Originally Posted by Swirv View Post
    Pressing the brake pedal hard and it sorta feels like there is grease in between the pad and rotor requiring more distance to stop... Again, has only ever happened with really high speed stops or multiple hard braking stops in succession..
    Current Line-Up:
    Nov 29 2007
    Calgary / Vancouver
    Thanks for posting, it's good to hear others experience with this pad as well. I haven't experienced any fade yet but I've only had a number of medium to hard slow downs so far from 180km/h(ish)
    somewhere around there and they were fine, no noticable fade. Again I certainly wouldn't track these pads, especially not on this boat but so far as a street set up they are doing great.
    As a final note it's been pretty cold around here these days so that might factor in for my resistance to fade so far. It's going to warm up a lot though this week so I might hit the mountains for a little canyon carving this coming weekend and see how they do.
    Dec 06 2015
    San Ramon, CA
    I just installed these pads. I've only put about 50 miles so far. They definitely do grab like OEM, it's hard to believe for a ceramic pad. I need t ok really clean my wheels after break in, then I can report back on dust. Highly recommend so far, and as long as they're low dust as ceramic pads should be. Great share OP.
    Oct 02 2005
    The Moon
    Can you be more specific on what speeds you experienced fade at? Starting deceleration speed, speed at which fade happened and what you eventually slowed to?
    Everyone has different views of fast, so it's why I ask.
    Thanks for your insight!
    Jun 09 2017
    Signature
    GTA
    Quote Originally Posted by p3u View Post
    Just want to state again that my experience is on a different platform, but I'e had fade from these pads in 2 different scenarios..
    First, I've had fade when ripping it auto-cross style for a period of time, so max acceleration, hard brake to slow down, make turn, max acceleration and repeat. After a few of those, I will experience fade.. No super speeds in those situations, just lots of on and off from max acceleration..
    The high speed fade I experienced a coupe of times was from about 200-230km/hr (120mph-140mph) to almost a stop. By the time I'v slowed down to about 50km/h or so I start feeling the fade.. I first had it happen when doing logs. I would run 4th gear to redline and then mash the brakes hard to bring the car back to legal speed.. Speeds are not crazy fast at the top of 4th, but doing it repeatedly gets them to fade..
    I'm not 100% sure, but it also felt like it was just starting to happen when braking at the end of the drag strip, but I could be wrong because I don't really hammer the brakes, but with my moderate braking, it felt like once I got to the end of the braking zone and need to turn, the brakes felt like they were starting to fade. I'm trapping 118mph-120mph, so roughly the same or a little slower than the speeds on the street where I experience it.
    The brake pads in my golf are probably half the size of the S6 brake pads, not sure if would make any difference (positive or negative)
    I don't want to sway people away from this pad, the experience on the C7 platform with it's monster rotors and pads may be different. I haven't changed them on my golf because I like the "grabby-ness" of them and the low dust. For 95% of my driving, I'm very happy with its performance.. I don't drive drive like a maniac all the time, so it's not like it happens frequently, and for the times it did happen, I was still in full control..
    Current Line-Up:
    Nov 29 2007
    Calgary / Vancouver
    Quote Originally Posted by ntsantos View Post
    Cool, I'm glad your liking them as well. Currently I'm around 2,000km on them and have yet to hear a single squeak, and again that's without those anti-vibration pads, I am impressed. While there is still some dust for sure, it is sooooo much better then the stockers. I haven't experienced any fade to date like "15 Phantom S6" had on his other platform with these pads but I haven't really pushed them to see how far they'll go yet. I was playing in the mountains a bit the other weekend but temps were pretty chilly so I wasn't pushing it too hard. I definitely got the brakes up to temperature and experienced no fade though. As a street pad these are great, I'm very happy with my choice.
    Junior Member One Ring F430viperS7's Avatar
    Dec 12 2016
    Ferrari 458 Spyder, Viper, RX7-R1
    Orlando Florida
    Thanks for the info. Just bought these pads. Will report back after I install.
    Dec 06 2015
    San Ramon, CA
    So after a few hundred miles later, and almost fully broken in...holy sh*t do these grab. And still no dust. This may be the unicorn pad. Maybe not for track purposes as there are other dedicated track options, but for everyday use, these are the real deal.
    Jan 10 2017
    CA
    Thanks all. Keep up the feedback. I switched to the wearevers but these sound intriguing. May try them out in a year or so
    2016 Daytona Gray S7. Black optics + sport pkg. Stage 3, eurocode stuff, cosmetic stuff.
    Senior Member Three Rings jsilas's Avatar
    Dec 29 2015
    2016 S6, 2021 SQ5, 2016 R1M, 2004 R1
    WA, PNW
    Subbed. The brake squeal is driving me absolutely mad.
    2016 S6 | Mythos / Black | Prestige | Sport | Carbon | Black Optic | Bang & Olufsen | Driver Assistance | OEM RS7 Turbos | APR Stage III ECU/TCU | CoD delete | APR DPs | SRM Intakes | CETE AVC | CETE ASC V2 | H&R Sway Bars | VIM | CarPlay | Opti-Coat Pro+ | XPEL Ultimate PPF | XPEL ceramic tint
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    yup the noise and dust i can not take anymore. i might have to order these asap and put them on. op can u post a link as to where you got them?
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Nov 29 2007
    Calgary / Vancouver
    Quote Originally Posted by ichi d View Post
    Here you go...
    https://www.tdotperformance.ca/
    Oct 20 2016
    Los Angeles/CA
    4 years and 28k miles - going to try these as well. appreciate the post OP!
    2022 RS6 Daytona Gray
    May 10 2013
    Toronto,ON
    thanks
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Yep, these are even cheaper than the Wearever Gold pads I and others have installed. Reason for that is that they're ceramic, which yes means low dust, but which generally also means poorer performance at higher pad temperatures, such as those seen in enthusiastic street driving and on track. This is likely also why some users have experienced brake fade.
    The Wearever Golds for the C7 are semi-metallic like the OEM pads, and retain the OEM pads' brake feel but without all the dust. They also maintain their performance under heavy use, with mine surviving a track day at Road America with no issues.
    The cool thing about the PowerStops though is that they're yet ANOTHER reason not to waste money on "branded" ceramic pads such as Disc Italia or EBC Redstuffs as long as you never intend to use them on track.
    Amazon carries them, too: https://www.amazon.com/Power-16-1575...13%3Aaudi%3As6
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Veteran Member Four Rings digdah's Avatar
    Dec 11 2017
    DFW
    Interesting. I am honestly disappointed with my EBC Redstuff and maybe after replacing my motor mounts I might replace the brakes with these.
    Oct 20 2016
    Los Angeles/CA
    Quote Originally Posted by zcd2.7t View Post
    Actually got a great deal on the Wearever's for $75 total - will try those out, and keep the Power Stop on standby. Like the idea of keeping it semi-metallic similar to OEM. Thanks!
    Jan 19 2010
    MI/CA
    Quote Originally Posted by snohman View Post
    ...Thanks!
    NP
    Veteran Member Three Rings R3.'s Avatar
    Nov 03 2016
    Dallas,TX
    Having these installed right now. So sick of the dust !
    2016 S6
    2013 A6 3.0T Sold
    Nov 03 2016
    Dallas,TX
    New pads are missing these attachments points for the pistons. Did you’re have that issue ???
    2016 S6
    2013 A6 3.0T Sold
    Jan 10 2017
    CA
    If you’re talking about the shims, they’re an expensive add on part from audi. I and many others have used a razor to get them off of the old pads (they’re just stuck on with glue) and re use them with the new. Getting them removed without damaging them was the biggest hassle in the pad swap for me.
    Nov 03 2016
    Dallas,TX
    Quote Originally Posted by kpriv View Post
    Yeah they are just going to reuse them.
    2016 S6
    2013 A6 3.0T Sold
    Nov 29 2007
    Calgary / Vancouver
    Quote Originally Posted by R3. View Post
    Those are the anti vibration dampers I was talking about. Those don't come with pads they are from the factory and quite expensive. If you can carefully peel them off the old pads and put them back in the calipers pistons. That was my plan to re use them but when I removed the pads on my car they didn't even have those dampers period, the dealer just didn't bother to install them before they sold the car to me. Pisses me off but so far even without these the new brakes haven't made a squeak so I'm not going to worry about it, for now.
    Nov 03 2016
    Dallas,TX
    Cool, I just had them reuse them. 100 miles later .... NO DUST. feels good man, feels good.
    2016 S6
    2013 A6 3.0T Sold
    Established Member Two Rings frigga's Avatar
    May 24 2013
    Great thread, thanks for sharing your experience with these pads, OP.
    Question:
    1. Did you change your rotors at the time you swapped out the pads? What km did you swap the pads out (just curious).
    2. How difficult was it to pry off the backing plates (vibration plates) from the stocks? Do the EBC Redstuffs include the plates, maybe that's why it's so expensive?
    2014 S7 | Diamond Stitched Sport Seats | Phantom Black |
    Nov 29 2007
    Calgary / Vancouver
    Quote Originally Posted by frigga View Post
    Question:
    1) I didn't do the rotors as the dealer did new pads/rotors right before I bought the car. It had 6,000 - 7,000km on the brakes before I changed pads. No real discernable lip on the rotors yet, still very good shape.
    2) I didn't have any vibration pads to remove. Dealer didn't replace them when they did the brakes. I believe most were getting them off with a razor blade. I don't think EBC or anyone is selling the dampers with their pads. The dampers alone are ~$350CAD if you need a new set. It was Sunday when I did my brakes, everything was closed so I said screw it and just installed the pads without. I'm not going to tell you not to bother with them, but so far going without has caused me zero issues. Unless something changes, I'm just going to leave it alone.
    May 24 2013
    Much appreciated! I'm pulling my wheels off next weekend to see the condition of the rotors and see if I can swing changing my pads.
    Anyone else looking to buy pads, TdotPerformance has a deal on right now - not much, but you save like $20.
    Jun 09 2017
    Signature
    GTA
    Just as an FYI, Powerstop makes 4 different types of pads for our cars. They make a Z16, Z17, Z23 and Z26. The Z23 & Z26 claim to have their "Low Dust Brake Technology"...
    Z16 & Z17 are ceramic Pads. I believe the Z16 and Z17 are the same (I could be wrong), just one comes with hardware (not sure if that means the shims that are so expensive from Audi)
    Z23 are "Carbon infused ceramic brake pads" and are marketed as a pad upgrade for the daily driver and claim to have their "Low Dust Brake Technology"
    Z26 are "Street Performance Carbon ceramic brake pads" and are marketed as a pad upgrade for performance / muscle cars and claim to have their "Low Dust Brake Technology"
    https://www.powerstop.com/products/#...0brake%20discs > then hit the "Pads" icon at the top of the page..
    I couldn't find the Z23 or Z26 from any of the dealers listed in their site so I emailed them. They said the Z23 & Z26 are a new application and would be available in the next 90 days.
    I think these are also good alternatives to the current pads out there.. I'm gonna try the Z26 once it's available..
    Current Line-Up:
    Nov 29 2007
    Calgary / Vancouver
    Good info, I saw those options as well but couldn't find anyone with anything other then the Z16's. Z17 is Z16's with hardware, pretty sure it wouldn't include vibration dampers though. On other cars it was new rattle clips and a new mounting bolt or something if necessary. The Z23 and Z26 did sound good but I couldn't find them anywhere either. I would love to hear how good they are though. If you could gain some trackability and maintain low dust and no noise I'd be all over it.
    Feb 12 2018
    just purchased z16.
    now i've read somewhere that we only need one brake pad sensor for front, or is it one each side (driver,passenger)?
    and what brand or part number are you guys using?
    May 24 2013
    Just purchased the z16 too. Waiting on shipping because there is a back order. Looking forward to throwing these on and cleaning the damn wheels less.
    Sent from my SM-G930T using Tapatalk
    May 10 2013
    Toronto,ON
    im about to do the same. dust is just driving me nuts.
    Senior Member Two Rings slobdogg's Avatar
    Sep 24 2018
    Fairfax, VA
    I just got my S7 last month. I couldn't believe the amount of dust. So quickly it looks like I don't care about my cars appearance.
    2016 S7 Daytona Gray Pearl
    Dec 06 2015
    San Ramon, CA
    I'm just about at the 1 month mark and close to a thousand miles later, still no dust.
