Results 1 to 4 of 4
    Dec 14 2014
    Washington
    VCDS fault codes after a few mods
    In the past week, I have installed:
    • New crank pulley
    • Mercracing hx
    • Short shifter
    • Lowering spring
    • Flashed to dual pulley tune
    I'm getting a ton of fault codes. I dont have a CEL and everything seems to be running fine. I cleared the codes and will check in a few days, but do any of these look like they need immediate attention?
    Code:
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    1B-Active Steering -- Status: Malfunction 0010
    22-AWD -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CCBA)       Labels:. 06E-907-551-CAK.clb
       Part No SW: 8K0 907 551 D    HW: 8K0 907 551 A
       Component: 3.0T SIMOS84  H06 0003
       Revision: --H06---
       Coding: 0104000A180F0128
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
       ROD: EV_ECM30TFS0218K0907551D.rod
       VCID: 323DE631D4AEB9B7581-8066
    No fault code found.
    Readiness: 1110 1101
    Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
       Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 AN
       Component: ESP8 quattro  H04 0010
       Revision: --------    Serial number: --------------
       Coding: 282D1A
       VCID: 7AAD0E114CDE81F7D01-802E
    5 Faults Found:
    00283 - ABS Wheel Speed Sensor; Front Left  (G47)
                012 - Electrical Fault in Circuit - Intermittent - MIL ON
                 Freeze Frame:
                        Fault Status: 10101100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 20:19:19
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x0320
                        Hex Value: 0x0006
                        Hex Value: 0xB09B
                        Hex Value: 0x00FF
    00285 - ABS Wheel Speed Sensor; Front Right (G45)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 20:19:19
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x0320
                        Hex Value: 0x0007
                        Hex Value: 0xB09B
                        Hex Value: 0x00FF
    01324 - Control Module for All Wheel Drive (J492)
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 4
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 21:14:26
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x03A2
                        Hex Value: 0x0028
                        Hex Value: 0x5091
                        Hex Value: 0x00FF
    00473 - Control Module for Elect. Park/Hand Brake (J540)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 21:14:30
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x03A2
                        Hex Value: 0x0032
                        Hex Value: 0x0292
                        Hex Value: 0x00FF
    01314 - Engine Control Module
                004 - No Signal/Communication - Intermittent
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:40
                 Freeze Frame:
                        Hex Value: 0x0000
                        Hex Value: 0x00A2
                        Hex Value: 0x002B
                        Hex Value: 0xB995
                        Hex Value: 0x00FF
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
       Component: BCM2 1.1      H02 0321
       Revision: 00002001
       Coding: 0F0100
       VCID: 78A9141972D293E7A65-802C
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Component: J764 ELV MLB  H36 0042
       Serial number: 0209000038862005
    1 Fault Found:
    01330 - Central Control Module for Central Convenience (J393)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:41
    Address 08: Auto HVAC (J255)       Labels:. 8Tx-820-043-3Z.clb
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0160
       Revision: C1000000    Serial number: 01120620090226
       Coding: 66102000
       VCID: 00597CF92A02DB279E5-8054
    1 Fault Found:
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:39
    Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H25 0380
       Revision: 10025001    Serial number: 00000000398422
       Coding: 26001035063CAF313E00080300003D0D0F9C924800010161000000
       VCID: 3C21C809066A7FC782D-8068
       Subsystem 1 - Part No SW: 8K1 955 119 A    HW: 8T1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 150609  H06 0070
       Serial number: SWF09060155547
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 10503010
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000000506090170
       Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
       Component: HOMELINK  H01 0010
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:00
    01316 - ABS Control Module
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 20:19:00
    Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
       Part No SW: 8K0 919 475 H    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0050
       Revision: 11001001    Serial number: 39940916007797
       Coding: 30000D
       VCID: 3E25C20110766DD7AC9-806A
    Address 14: Susp. Elect. (J250)       Labels: None
       Part No SW: 8K0 907 364 A    HW: 8K0 907 364
       Component: DAEMPFUNGS-SG H08 0050
       Revision: 00000000    Serial number: 28050901190002
       Coding: 050181
       VCID: 313FE93DD12882AF21B-8064
    5 Faults Found:
    00142 - Left Front Dampening Adjustment Valve (N336)
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 21:14:25
                 Freeze Frame:
                        Bin. Bits: 00000000 00100000
    03264 - Functionalty Shut Off
                000 -  -  - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 21:14:25
                 Freeze Frame:
                        Error Code: 8
    03155 - Functionality limited due to Initialization
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 147
                        Time Indication: 0
                 Freeze Frame:
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000000 00000001
    00776 - Level Control System Sensor; Left Front (G78)
                003 - Mechanical Failure - Intermittent
                 Freeze Frame:
                        Fault Status: 00100011
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 21:15:23
                 Freeze Frame:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:41
                 Freeze Frame:
                        Bin. Bits: 00000000 00000011
    Address 15: Airbags (J234)       Labels:* 8K0-959-655.clb
       Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
       Component: AirbagVW-AU10 H37 0520
       Serial number: 003EGD022P5.
       Coding: 303836354230303030304A55304C384B3053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003010
       ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
       VCID: 42DDB6F1640E0937C81-8016
       Seat occupied recognition:
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R09000040P4
       Crash sensor for side airbag: driver side:
       Serial number: 6334MSME493078105
       Crash sensor for side airbag: front passenger side:
       Serial number: 6344MSME49040C609
       Crash sensor for side airbag: rear: driver side:
       Serial number: 6352QSME412F0C1CO
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 6362QSME333043341
       Crash sensor for front airbag: driver side:
       Serial number: 63732SME722E4B2EC
       Crash sensor for front airbag: front passenger side:
       Serial number: 63832SME6C2E0F26E
    Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H16 0014
       Revision: --------    Serial number: 90304IF4000G8
       Coding: 000016
       Component: E221 - MFL  H02 0003
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 21:14:24
    Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
       Part No SW: 8K0 920 980 Q    HW: 8K0 920 980 Q
       Component: KOMBIINSTR.   H04 0253
       Revision: 00100000    Serial number: BY0310C69
       Coding: 831D0900B300D705020000
       VCID: 40D9BCF96A821B27DE5-8014
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:41
    Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
       Part No SW: 8T0 907 468 AA    HW: 8T0 907 468 L
       Component: GW-BEM 5CAN-M H10 0101
       Revision: FB800054    Serial number: 5400F095268157
       Coding: 00C303
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0160
       Serial number: 1907EA38190509
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:41
                 Freeze Frame:
                        Bin. Bits:    10111
                        Voltage: 11.70 V
                        Count: 6
                        Bin. Bits:    10110
                        Time: 25.40 s
    Address 1B: Active Steering (J792)       Labels: None
       Part No SW: 8K0 907 144 D    HW: 8K0 907 144 D
       Component: DYNAMIKLENK.  H06 0570
       Revision: 50001005    Serial number: --------------
       Coding: 8C0000
       Shop #: WSC 06324 000 00000
       VCID: 3039EC39DA228BA72E5-8064
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:40
                 Freeze Frame:
                        Count: 52
                        Count: 1
                        Hex Value: 0x0275
                        Hex Value: 0x0602
                        Hex Value: 0xFEFF
                        Hex Value: 0x0000
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163     HW: 8K0 907 163
       Component: 4 Wheel Drive H09 0004
       Serial number: 000206090001074
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
       ROD: EV_AllWheelDiffeQSPCAN.rod
       VCID: 6D87354D0D10264F453-8038
    4 Faults Found:
    0087 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [008] - -
              [ESP - Steuergerät Bitte Fehlerspeicher auslesen  ----------    ---  ----------  Funktionseinschränkung durch Unterspannung DTC_CAN_ESP_WHEEL_VL]
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 52255 km
                        Date: 2018.10.08
                        Time: 21:14:26
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [008] - -
              [ESP - Steuergerät nicht verfügbar DRC_CAN_ESP_01_SYS_ST]
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52255 km
                        Date: 2018.10.08
                        Time: 21:14:26
    0221 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
              [Motorsteuergerät keine Kommunikation DTC_CAN_MOTOR_01_NO_COM]
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Date: 2018.10.09
                        Time: 19:38:40
    0297 - No Communication with Engine Control Module (SAE ECM/PCM)
              U0100 00 [008] - -
              [Motorsteuergerät keine Kommunikation DTC_CAN_MOTOR_03_NO_COM]
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Date: 2018.10.09
                        Time: 19:38:40
    Address 36: Seat Mem. Drvr (J136)       Labels:. 8T0-959-760.clb
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0073
       Revision: AA000000    Serial number: 00001001283680
       Coding: 00581B00000000000000
       VCID: 3B23CB15036478FF8B7-806E
    Address 3C: Lane Change        Labels: None
       Part No SW: 8K0 907 566 H    HW: 4L0 907 566 B
       Component: J0769_SWA_MasterH01 0010
       Revision: 00H01000    Serial number: 6PZ 009 014-82
       Coding: 0000001
       VCID: 3C21C8090A6A7FC782D-8068
       Subsystem 1 - Part No: 8K0 907 568 H
       Component: J0770_SWA_Slave_H01 0010
       Subsystem 2 - Serial number: 6PZ 009 014-92
       Subsystem 3 - Serial number: 5F08.06.0900H010003C320323˙
       Subsystem 4 - Serial number: 320323˙
    Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
       Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
       Component: TSG FA        H11 0306
       Revision:             Serial number: 0000008950466
       Coding: 011C13204E00410001
       VCID: 45D7ADED75A03E0FED3-8010
    Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
       Revision: 00002001    Serial number: 0118700834
       Coding: 01060E38007A444500B0010000000000
       Shop #: WSC 06342 000 00000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000143959
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H03 1301
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS037  H06 0041
    3 Faults Found:
    02616 - Fuel Tank Cap; Unlock
                009 - Open or Short to Ground
                 Freeze Frame:
                        Fault Status: 01101001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 100
                        Mileage: 52057 km
                        Time Indication: 0
                        Date: 2018.10.03
                        Time: 11:40:19
    02615 - Fuel Tank Cap; Lock
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 101
                        Mileage: 52087 km
                        Time Indication: 0
                        Date: 2018.10.03
                        Time: 12:16:28
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:40
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOM.clb
       Part No SW: 8T0 035 223 AK    HW: 8T0 035 223 AK
       Component: DSP Prem      H08 0170
       Revision: 00008001    Serial number: 34881004449503
       VCID: 77AB17257FCC9C9FAFF-8022
    Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
       Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
       Component: TSG BF        H11 0306
       Revision:             Serial number: 0000008957167
       VCID: 44D1B0E97E9A0707FAD-8010
    Address 53: Parking Brake (J540)       Labels: 8K0-907-801-V1.clb
       Part No SW: 8K0 907 801 H    HW: 8K0 907 801 H
       Component: EPB Audi B8   H09 0090
       Revision: 00000003    Serial number: 00000000393454
       Shop #: WSC 00000 000 00000
       VCID: 3431E0292E3AB7874AD-8060
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:40
                 Freeze Frame:
                        Voltage: 12.00 V
                        Count: 64
                        Speed: 0.0 km/h
                        Hex Value: 0x0263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 147
                        Mileage: 52255 km
                        Time Indication: 0
                        Date: 2018.10.08
                        Time: 21:14:30
                 Freeze Frame:
                        Voltage: 11.80 V
                        Count: 62
                        Speed: 0.0 km/h
                        Hex Value: 0x0263
                        Hex Value: 0x0001
                        Hex Value: 0x1010
    Address 55: Headlight Range        Labels: 8K0-907-357.clb
       Part No: 8K0 907 357 B
       Component: Dynamische LWR  H01 0030
       Revision: 00000001    Serial number:
       Coding: 0000005
       VCID: 3431E029223AB7874AD-8060
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 19:38:40
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4F0 035 082 A    HW: 4F0 035 082
       Component: Radio U SIRIU H45 0021
       Revision: AB001007    Serial number: 335F-097516583
       Coding: 020000010000000001
       VCID: 1D67258DBDB016CF953-8048
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
       Component: H-BN-NA       H41 0042
       Revision: --------    Serial number: 490FV097509043
       Coding: 010200000206A1EF55001F0E000000030000
       VCID: 3635DA213846A597749-8062
       Subsystem 1 - Part No: 8R0 060 884 F
       Component: NAR 2009/2010  5304
       Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
       Component: DU7 High  H43 0306
       Serial number: 9356FI091013900
       Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000303781
       Subsystem 4 - Part No: 8R0 906 961 A
       Component: CD-Database  1293
    1 Fault Found:
    03278 - Functionality Limited due to Missing Messages
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 148
                        Mileage: 52268 km
                        Time Indication: 0
                        Date: 2018.10.09
                        Time: 20:01:47
                 Freeze Frame:
                        Bin. Bits: 00010000 00000000
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Did you have your battery unplugged at any moment?
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    Senior Member Two Rings Tom Sawyer's Avatar
    Apr 01 2007
    TN
    I have a feeling they won't come back; all the tune info I've read says you need to clear codes after applying a tune as it throws a ton of codes while the ECU is in flash mode and communications are interrupted with other modules.
    2020 SQ5 Prestige, Quantum Gray, S Package, Nappa, BO, DA
    Gone but not forgotten: 2000 B5 S4, 2004 B6 S4, 2003 RS6, 2016 S4 P+ DSG
    Dec 14 2014
    Washington
    Quote Originally Posted by stereojorge View Post
    The battery was never unplugged.
    Quote Originally Posted by Tom Sawyer View Post
    Thats what I am hoping. I know the suspension stuff will most likely go away because I believe the car was on for a couple minutes while the sensors were disconnected during the install. There are just a few things that say it was unable to connect to certain modules that has me a little worried.
