This might be helpful for others as I was not able to find something quite like this and just put it together as part of my ongoing misfire diagnosis. Excel file with a table of these groups and blocks can be found here and is helpful for seeing what the output from each block might look like.
Hope it helps someone!
(do ctrl+f and enter search term)
- - - Updated - - -
Group 1: Block 1 - Engine Speed (G28) // Block 2 - Coolant Temp (G62) // Block 3 - Lambda Control Bank 1 // Block 4 - Lambda Control Bank 2
Group 2: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Injection Timing // Block 4 - Mass Air Flow Sensor (G70)
Group 3: Block 1 - Engine Speed (G28) // Block 2 - Mass Air Flow Sensor (G70) // Block 3 - Throttle Valve Angle // Block 4 - Ignition Timing Angle
Group 4: Block 1 - Engine Speed (G28) // Block 2 - Battery Voltage (Terminal 30) // Block 3 - Coolant Temp (G62) // Block 4 - Intake Air Temp (G42)
Group 5: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Vehicle Speed // Block 4 - Load Status
Group 6: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Intake Air Temp (G42) // Block 4 - Altitute Correction Factor
Group 9: Block 1 - Oil Level // Block 2 - Oil Warning Threshold // Block 3 - Fuel Consumption Signal // Block 4 - Fuel Consumption Equivalent
Group 10: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Throttle Valve Angle // Block 4 - Ignition Timing Angle
Group 11: Block 1 - Engine Speed (G28) // Block 2 - Coolant Temp (G62) // Block 3 - Intake Air Temp (G42) // Block 4 - Ignition Timing Angle
Group 14: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Misfire Counter // Block 4 - Misfire Recognition
Group 15: Block 1 - Misfire Counter Cylinder 1 // Block 2 - Misfire Counter Cylinder 2 // Block 3 - Misfire Counter Cylinder 3 // Block 4 - Misfire Recognition
Group 16: Block 1 - Misfire Counter Cylinder 4 // Block 2 - Misfire Counter Cylinder 5 // Block 3 - Misfire Counter Cylinder 6 // Block 4 - Misfire Recognition
Group 17: Block 1 - Misfire Counter Cylinder 7 // Block 2 - Misfire Counter Cylinder 8 // Block 3 - (blank) // Block 4 - Misfire Recognition
Group 18: Block 1 - Lower RPM Barrier // Block 2 - Upper RPM Barrier // Block 3 - Lower Load Barrier // Block 4 - Upper Load Barrier
Group 20: Block 1 - Timing Retardation Cylinder 1 // Block 2 - Timing Retardation Cylinder 2 // Block 3 - Timing Retardation Cylinder 3 // Block 4 - Timing Retardation Cylinder 4
Group 21: Block 1 - Timing Retardation Cylinder 5 // Block 2 - Timing Retardation Cylinder 6 // Block 3 - Timing Retardation Cylinder 7 // Block 4 - Timing Retardation Cylinder 8
Group 22: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Timing Retardation Cylinder 1 // Block 4 - Timing Retardation Cylinder 2
Group 23: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Timing Retardation Cylinder 3 // Block 4 - Timing Retardation Cylinder 4
Group 24: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Timing Retardation Cylinder 5 // Block 4 - Timing Retardation Cylinder 6
Group 25: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Timing Retardation Cylinder 7 // Block 4 - Timing Retardation Cylinder 8
Group 26: Block 1 - Knock Sensor Voltage Cylinder 1 // Block 2 - Knock Sensor Voltage Cylinder 2 // Block 3 - Knock Sensor Voltage Cylinder 3 // Block 4 - Knock Sensor Voltage Cylinder 4
Group 27: Block 1 - Knock Sensor Voltage Cylinder 5 // Block 2 - Knock Sensor Voltage Cylinder 6 // Block 3 - Knock Sensor Voltage Cylinder 7 // Block 4 - Knock Sensor Voltage Cylinder 8
Group 28: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Coolant Temp (G62) // Block 4 - Knock Sensor Test Result
Group 30: Block 1 - Bank 1 Sensor 1 // Block 2 - Bank 1 Sensor 2 // Block 3 - Bank 2 Sensor 1 // Block 4 - Bank 2 Sensor 2
Group 31: Block 1 - Lambda Control Bank 1 (actual) // Block 2 - Lambda Control Bank 1 (specified) // Block 3 - Lambda Control Bank 2 (actual) // Block 4 - Lambda Control Bank 2 (specified)
Group 32: Block 1 - Adaptation (Idle) - Bank 1 Sensor 1 // Block 2 - Adaptation (Partial) - Bank 1 Sensor 1 // Block 3 - Adaptation (Idle) - Bank 2 Sensor 1 // Block 4 - Adaptation (Partial) - Bank 2 Sensor 1
Group 33: Block 1 - Lambda Control Bank 1 Sensor 1 // Block 2 - Sensor Voltage Bank 1 Sensor 1 // Block 3 - Lambda Control Bank 2 Sensor 1 // Block 4 - Sensor Voltage Bank 2 Sensor 1
Group 34: Block 1 - Engine Speed (G28) // Block 2 - Catalytic Converter Bank 1 Temp // Block 3 - Dynamic Factor Bank 1 Sensor 1 // Block 4 - Result Lambda Aging
Group 35: Block 1 - Engine Speed (G28) // Block 2 - Catalytic Converter Bank 2 Temp // Block 3 - Dynamic Factor Bank 2 Sensor 1 // Block 4 - Result Lambda Aging
Group 36: Block 1 - Sensor Voltage Bank 1 Sensor 2 // Block 2 - Result Lambda Availability Bank 1 Sensor 2 // Block 3 - Sensor Voltage Bank 2 Sensor 2 // Block 4 - Result Lambda Availability Bank 2 Sensor 2
Group 37: Block 1 - Engine Load // Block 2 - Sensor Voltage Bank 1 Sensor 2 // Block 3 - Delta Lambda Bank 1 Sensor 2 Specification // Block 4 - Result Delta Lambda B1
Group 38: Block 1 - Engine Load // Block 2 - Sensor Voltage Bank 2 Sensor 2 // Block 3 - Delta Lambda Bank 2 Sensor 2 Specification // Block 4 - Result Delta Lambda B2
Group 39: Block 1 - Mass Air Flow Sensor (G70) // Block 2 - Sensor Voltage Bank 1 Sensor 2 // Block 3 - Sensor Voltage Bank 2 Sensor 2 // Block 4 - Result Sensor Exchange
Group 41: Block 1 - Resistance Bank 1 Sensor 1 // Block 2 - Heater Condition (Sensor 1) // Block 3 - Resistance Bank 1 Sensor 2 // Block 4 - Heater Condition (Sensor 2)
Group 42: Block 1 - Resistance Bank 2 Sensor 1 // Block 2 - Heater Condition (Sensor 1) // Block 3 - Resistance Bank 2 Sensor 2 // Block 4 - Heater Condition (Sensor 2)
Group 43: Block 1 - Engine Speed (G28) // Block 2 - Catalytic Converter Bank 1 Temp // Block 3 - Lambda Voltage Bank 1 Sensor 1 // Block 4 - Lambda Sensor Aging Test B1S2
Group 44: Block 1 - Engine Speed (G28) // Block 2 - Catalytic Converter Bank 2 Temp // Block 3 - Lambda Voltage Bank 2 Sensor 1 // Block 4 - Lambda Sensor Aging Test B2S2
Group 46: Block 1 - Engine Speed (G28) // Block 2 - Catalytic Converter Bank 1 Temp // Block 3 - Catalytic Conversion Bank 1 // Block 4 - Catalytic Conversion Test Bank 1
Group 47: Block 1 - Engine Speed (G28) // Block 2 - Catalytic Converter Bank 2 Temp // Block 3 - Catalytic Conversion Bank 2 // Block 4 - Catalytic Conversion Test Bank 2
Group 50: Block 1 - Engine Speed (actual) // Block 2 - Engine Speed (specified) // Block 3 - A/C Readiness // Block 4 - A/C Compressor
Group 51: Block 1 - Engine Speed (actual) // Block 2 - Engine Speed (specified) // Block 3 - Selected Gear // Block 4 - Battery Voltage (Terminal 30)
Group 53: Block 1 - Engine Speed (actual) // Block 2 - Engine Speed (specified) // Block 3 - Battery Voltage (Terminal 30) // Block 4 - Generator Load
Group 54: Block 1 - Engine Speed (G28) // Block 2 - Load Status // Block 3 - Accel. Pedal Pos. Sensor 1 (G79) // Block 4 - Throttle Valve Angle
Group 55: Block 1 - Engine Speed (G28) // Block 2 - Idle Regulator // Block 3 - Idle Stabilization Self-Adaptation // Block 4 - Operating Condition
Group 56: Block 1 - Engine Speed (actual) // Block 2 - Engine Speed (specified) // Block 3 - Idle Regulator // Block 4 - Operating Condition
Group 57: Block 1 - Engine Speed (actual) // Block 2 - Engine Speed (specified) // Block 3 - A/C Compressor // Block 4 - A/C Compressor Load
Group 58: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Engine Mount Right // Block 4 - Engine Mount Left
Group 60: Block 1 - Throttle Valve Sensor 1 (G187) // Block 2 - Throttle Valve Sensor 2 (G188) // Block 3 - Throttle Valve Steps Counter // Block 4 - Throttle Body Alignment Status
Group 61: Block 1 - Engine Speed (G28) // Block 2 - Battery Voltage (Terminal 30) // Block 3 - Throttle Valve Angle // Block 4 - Operating Condition
Group 62: Block 1 - Throttle Valve Sensor 1 (G187) // Block 2 - Throttle Valve Sensor 2 (G188) // Block 3 - Accel. Pedal Pos. Sensor 1 (G79) // Block 4 - Accel. Pedal Pos. Sensor 2 (G185)
Group 63: Block 1 - Accel. Pedal Pos. Sensor 1 (G79) // Block 2 - Kick-Down Alignment Value // Block 3 - Kick-Down Switch // Block 4 - Kick-Down Alignment Status
Group 64: Block 1 - Lower Adaptation Sensor 1 (G187) // Block 2 - Lower Adaptation Sensor 2 (G188) // Block 3 - Emergency Air Gap Sensor 1 (G187) // Block 4 - Emergency Air Gap Sensor 2 (G188)
Group 66: Block 1 - Vehicle Speed (current) // Block 2 - Siwtch Positions I // Block 3 - Vehicle Speed (specified) // Block 4 - Switch Positions II
Group 70: Block 1 - Evap. Emissions Sol. Valve (Open) // Block 2 - Lambda Control // Block 3 - Evap. Emissions Sol. Valve (Flow) // Block 4 - EVAP Valve Test
Group 71: Block 1 - Reed Contact Condition // Block 2 - Malfunction Message // Block 3 - Test Status // Block 4 - Leak Diagnostic Test Status
Group 77: Block 1 - Engine Speed (G28) // Block 2 - Mass Air Flow Sensor (G70) // Block 3 - Air Mass from Sec. Air Inj. Bank 1 // Block 4 - Secondary Air Injection Test B1
Group 78: Block 1 - Engine Speed (G28) // Block 2 - Mass Air Flow Sensor (G70) // Block 3 - Air Mass from Sec. Air Inj. Bank 2 // Block 4 - Secondary Air Injection Test B2
Group 80: Block 1 - Advanced Identification // Block 2 - (blank) // Block 3 - (blank) // Block 4 - (blank)
Group 81: Block 1 - Advanced Identification // Block 2 - (blank) // Block 3 - (blank) // Block 4 - (blank)
Group 82: Block 1 - Advanced Identification // Block 2 - (blank) // Block 3 - (blank) // Block 4 - (blank)
Group 85: Block 1 - Vehicle Mileage // Block 2 - IUMPR Record Counter // Block 3 - General Denominator // Block 4 - Ignition Cycle Counter
Group 86: Block 1 - Readiness Bits // Block 2 - Cycle Flags I // Block 3 - Cycle Flags II (Part 1) // Block 4 - Cycle Flags II (Part 2)
Group 87: Block 1 - Readiness Bits // Block 2 - Error Flags I // Block 3 - Error Flags II (Part 1) // Block 4 - Error Flags II (Part 2)
Group 88: Block 1 - Cycle Flags I // Block 2 - Cycle Flags II // Block 3 - Cycle Flags III // Block 4 - (blank)
Group 89: Block 1 - Distance Driven with MIL on // Block 2 - Tank Condition // Block 3 - (blank) // Block 4 - (blank)
Group 91: Block 1 - Engine Speed (G28) // Block 2 - Cam. Adjustment Intake Bank 1 // Block 3 - Cam. Adjustment Intake B1 (spec.) // Block 4 - Cam. Adjustment Intake B1 (act.)
Group 92: Block 1 - Engine Speed (G28) // Block 2 - Cam. Adjustment Intake Bank 2 // Block 3 - Cam. Adjustment Intake B2 (spec.) // Block 4 - Cam. Adjustment Intake B2 (act.)
Group 93: Block 1 - Phase Position Bank 1 Intake // Block 2 - Phase Position Bank 2 Intake // Block 3 - (blank) // Block 4 - (blank)
Group 94: Block 1 - Cam. Adjustment Intake B1 (act.) // Block 2 - Cam. Adjustment Intake B2 (act.) // Block 3 - Cam. Adj. Test Bank 1 Intake // Block 4 - Cam. Adj. Test Bank 2 Intake
Group 95: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Coolant Temp (G62) // Block 4 - Intake Manifold Change-Over
Group 99: Block 1 - Engine Speed (G28) // Block 2 - Coolant Temp (G62) // Block 3 - Lambda Control // Block 4 - Lambda Control Status
Group 100: Block 1 - Readiness Bits // Block 2 - Coolant Temp (G62) // Block 3 - Time since Engine Start // Block 4 - OBD-Status
Group 101: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Injection Timing // Block 4 - Mass Air Flow Sensor (G70)
Group 102: Block 1 - Engine Speed (G28) // Block 2 - Coolant Temp (G62) // Block 3 - Intake Air Temp (G42) // Block 4 - Injection Timing
Group 104: Block 1 - Engine Start Temperature // Block 2 - Temperature Adaptation Factor 1 // Block 3 - Temperature Adaptation Factor 2 // Block 4 - Temperature Adaptation Factor 3
Group 106: Block 1 - (blank) // Block 2 - Electric Fuel Pump 1/2 // Block 3 - (blank) // Block 4 - Fuel Pump Shut-Off Time
Group 107: Block 1 - Engine Speed (G28) // Block 2 - Lambda Control Bank 1 // Block 3 - Lambda Control Bank 2 // Block 4 - Result Lambda Control
Group 110: Block 1 - Engine Speed (G28) // Block 2 - Coolant Temp (G62) // Block 3 - Injection Timing // Block 4 - Throttle Valve Angle
Group 113: Block 1 - Engine Speed (G28) // Block 2 - Engine Load // Block 3 - Throttle Valve Angle // Block 4 - Athmospheric Pressure
Group 120: Block 1 - Engine Speed (G28) // Block 2 - Torque specified by ASR // Block 3 - Engine Torque (actual) // Block 4 - Traction Control Status
Group 122: Block 1 - Engine Speed (G28) // Block 2 - Torque specified by ASR // Block 3 - Engine Torque (actual) // Block 4 - Status
Group 125: Block 1 - Transmission Electronics (J217) // Block 2 - Brake Electronics (J104) // Block 3 - Instrument Cluster (J285) // Block 4 - Heating/Air Condition (J255)
Group 126: Block 1 - (blank) // Block 2 - Steering Angle Sensor (G85) // Block 3 - Airbag 1 // Block 4 - (blank)
Group 129: Block 1 - Oil Level Sensor // Block 2 - (blank) // Block 3 - (blank) // Block 4 - (blank)
Group 132: Block 1 - (blank) // Block 2 - (blank) // Block 3 - (blank) // Block 4 - Cooling Status
Group 134: Block 1 - Oil Temperature // Block 2 - Ambient Temperature // Block 3 - Intake Air Temp (G42) // Block 4 - Engine Outlet Temperature
Group 135: Block 1 - (blank) // Block 2 - Fan 1 Activation Duty Cycle // Block 3 - Fan 2 Activation Duty Cycle // Block 4 - (blank)
Group 136: Block 1 - (blank) // Block 2 - (blank) // Block 3 - Auxiliary Water Pump // Block 4 - Fan After Run
Group 137: Block 1 - A/C Readiness // Block 2 - A/C Compressor // Block 3 - A/C Refrigerant Pressure // Block 4 - Fan Request from A/C-System
Group 138: Block 1 - Engine Start Temperature // Block 2 - Mean Engine Air Mass // Block 3 - Median Vehicle Speed // Block 4 - Thermostat Test Result
Group 139: Block 1 - Engine Coolant Temperature Daig. // Block 2 - Actual Integral Mass Air Flow // Block 3 - Specified Integral Mass Air Flow // Block 4 - Thermostat Test Result
