Results 1 to 21 of 21
    Oct 07 2008
    Earth
    How much G's can you pull in acceleration?
    Here's mine.
    Unitronic stage 1+ ECU
    Unitronic stage 2 TCU
    APR intercoller
    IE intake
    Milltek Secondary delete
    Established Member Two Rings motopix's Avatar
    Sep 19 2017
    NoVA
    1g on launch on pirelli sotozeros. So you seem to be traction limited if that's the best you could get with all those upgrades.
    Oct 07 2008
    Earth
    Quote Originally Posted by motopix View Post
    What mods do you have and how many G's are you pulling? Most people on Dragy with far more mods are around 1.1 peak and those with stage 1's are around 1g.
    Sep 19 2017
    NoVA
    Quote Originally Posted by purekoryo View Post
    What mods do you have and how many G's are you pulling? Most people on drag with far more mods are around 1.1 peak and those with stage 1's are around 1g.
    All stock and pulled 1.0 on the tires listed on a cold day on a sketchy street. Maybe the stock G gauge is the problem.
    Jul 12 2018
    UK
    The weight advantage of driving the TTRS and a scrawny 5'5" frame must be worth alot as I consistently see 1.1g when using LC. I'm on the Bridgestone S001's that came on the car and my only mods are MSS Track Pack and a piper cross panel filter. I see 1.0g lateral and 1.1g under braking. Not sure how accurate that in-car meter is though.
    Junior Member Two Rings
    Feb 07 2018
    VA
    Yea, my best pull was 1.0, all stock. Note that the gauge only gives max G. What you should be more interested in is acceleration over time instead of max G. There is iOS app called Phyphox. Open that up, click on acceleration with g, and secure your iPhone to your car. Thatll be better than what the RS3 shows you.
    May 03 2018
    11th gen Honda Accord Hybrid EX-L
    Jax, FL
    Paid 66 G's ;P
    Nov 06 2017
    Vancouver
    All stock 1G for me too, .9 if it spins a bit.
    Jan 09 2018
    ny
    Still haven't found a place i feel safe enough to launch her...
    Do all you guys own your own dragstrips or something
    2018 RS3 [Daytona/Tech/Dynamic/RS design/Unitronic Stg 1+ ECU & Stg 2 TCU]
    Veteran Member Three Rings shivaswrath's Avatar
    Sep 21 2017
    NJ/CT
    I have never launched it...this is from Pocono raceway for track night in America BEFORE a tune.
    2017 RS3 | Xpel in the front & Feynlabs all around | WINCOS IR 30% F and 20% R | 245/35-19 Pirelli Sottozero Serie II for winters | I'm not modding this super amazing car so I'm going to list stupid $hit like RS3 All season mats and Blendmount for Escort Max
    Veteran Member Three Rings FuzzyHat's Avatar
    May 21 2010
    Chicago, Illinois
    Hit 1.1 on a launch at the drag strip. Pretty sure this was with my 11.17 run.
    2018 RS3 - Unitronic ECU - Unitronic TCU
    Established Member Two Rings Diversion's Avatar
    Aug 28 2017
    Jacksonville, FL
    Do you trust the stock boost gauge too? There's no way that the stock G force meter is any kind of reliable source.
    2017 Audi RS3 Ara Blue - Unitronic Stage 1+ ECU, Unitronic Stage 2 TCU
    Oct 07 2008
    Earth
    I bought a Dragy. I'll just stick with that. Haven't timed anything yet.
    Established Member Two Rings Krillien's Avatar
    Aug 16 2017
    Calgary, AB
    Always wanted to know, the g-meter looks different between certain folks' cars. Take Shivawrath's vs Fuzzyhats for example. Is that an MMI version difference?
    2018 Mythos Black Audi RS3 (SOLD)
    2019 Nardo Grey Audi RS3
    https://www.instagram.com/yyc_rs3/
    Sep 21 2017
    NJ/CT
    Quote Originally Posted by Krillien View Post
    Like location or the actual G?
    Nov 15 2017
    FL
    Stock other than Neuspeed 18x8.5 front, 18x8 rear with 245/40R18 BFG Rival S 1.5. peak accel 1.1, lateral 1.3 and decel 1.2.
    Aug 16 2017
    Calgary, AB
    Quote Originally Posted by shivaswrath View Post
    Not the location - but if you looked at yours the max G's are graphically represented by the brackets () on the graph, but Fuzzyhats is more like an area chart.
    Nov 06 2017
    Vancouver
    There are two meters. One on the right side is in the additional display menu, and is larger. The left side one is smaller.
    Aug 16 2017
    Calgary, AB
    Quote Originally Posted by Potatohead_RS3 View Post
    I'm not referring to the location of the g-meter (I know about the additional display menu), but how the max Gs are graphically laid out on the chart itself. You see how Shiva's graph has the red brackets denoting the max Gs he's pulled, while Fuzzyhat's chart lacks the brackets, but contains the red area in the middle. I have not seen the red area overlay on my charts whether I put it in the left or right side.
    Veteran Member Three Rings MichiganRS3's Avatar
    Apr 30 2015
    Michigan
    Mine looks like Shiva’s while the car is still moving, and fuzzy’s once stopped.
    Thought that was normal.
    `18 Mystic Blue Pearl Effect RS3
    10.6 @ 129mph / 2.82s - 0-60 - Stage 2 e85
    Aug 16 2017
    Calgary, AB
    Quote Originally Posted by MichiganRS3 View Post
    Hmm I only get the brackets on mine whether stopped or moving. I know it hardly matters, but it was something that I wanted to get to the bottom of.
