Results 1 to 22 of 22
    Senior Member Two Rings Emericasktr1's Avatar
    Sep 28 2018
    Buffalo, NY
    Exhaust suggestions!
    Hey everyone! Just purchased my first Audi which is a 2015 Audi A3 2.0T. I'm looking to get a cat-back exhaust system installed on it but I'm not too sure which one I want so I'd like some suggestions/advice. I'm looking for a very aggressive and deep exhaust note. The two I was looking at were the Milltek or the Borla cat-back exhausts.
    Let me know what you think! Thanks!
    Veteran Member Four Rings ralphie_43's Avatar
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    This is my A3 with Dinan Exhaust
    First 2 are with apr downpipe
    https://youtu.be/kboBMemm0Yc
    https://youtu.be/axuZkRHTBmc
    Third is just the cat back
    https://youtu.be/S7F5upVOcZQ
    Sent from my SM-G930V using Audizine mobile app
    Jul 26 2018
    Seattle/Washington/USA
    Quote Originally Posted by Emericasktr1 View Post
    I just recently got the same vehicle. Looking at the Milltek, Dinan, or AWE myself.
    Sep 28 2018
    Buffalo, NY
    Thanks for the replies guys! I'm gonna check out the Dinan when I get home from work tonight. Those videos sound great!
    Sent from my SM-G955U using Audizine mobile app
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    I can upload a cold start video of the dinan with an apr downpipe if you're curious
    Veteran Member Three Rings INYAUDI's Avatar
    Feb 21 2016
    Southern New Hampshire
    I have the milltek dont do it. It’s an old man exhaust. I have a decat 3.5” downpipe no resonators and the milltek suitcase still makes it quiet. I’ve welded up exhausts from straight pipes before so I can “fix” it. But unless you’ve got that skill set I would advise against. My car sounds a little more exotic than everyone else’s but I’ve spent too much time under my car to get there. Go with the awe track set up. Best loud exhaust out if the box
    Instagram: TonyConQuattro
    Sep 28 2018
    Buffalo, NY
    Quote Originally Posted by INYAUDI View Post
    Would the S3 AWE Track Exhaust fit the A3? Plan on getting a new diffuser for quad tips anyways.
    Feb 21 2016
    Yes, diffuser is the only part that is different. Tips slip on so you could run duals from magnaflow for around $50 in the meantime too
    Sep 28 2018
    Buffalo, NY
    Excellent, thank you very much! The exhaust sounds great!
    Aug 23 2014
    Philadelphia, PA
    Def would recommend AWE systems for the A3/S3. Make really nice quality systems
    This would be the A3 Quattro setup
    https://www.moddedeuros.com/products...-quattro-sedan
    Sep 28 2018
    Buffalo, NY
    Quote Originally Posted by ModdedEuros View Post
    My only issue is the touring exhaust sounds very quiet imo. I'm looking for an aggressive and mean note and not a ricer note. I can't seem to find the perfect one yet!
    Sep 28 2018
    Buffalo, NY
    How is the AWE downpipe along with it?
    Aug 26 2018
    Montoursville PA
    check out the new APR exhaust
    Sep 28 2018
    Buffalo, NY
    Quote Originally Posted by Madspeed View Post
    Will do, thanks!
    Aug 23 2014
    Philadelphia, PA
    A downpipe is really going to change things and what I personally would recommend really. Does not have to be the AWE downpipe as I know thats more $
    I ran the CTS Turbo catted downpipe for the AWD A3/S3 on my 2015 S3 a while back. Loved the sound. I paired it with the Remus catback though to mix things up. If I had to do it again I honestly would just start with a downpipe and see what you think from there. As this way you get the power out of the mod. But that is assuming you will tune it at some point at it will throw a CEL from the downpipe
    Established Member Two Rings PINGERS's Avatar
    Oct 17 2018
    Cape Coral, FL
    I agree a little with Modded Euro’s or just go full Turbo-back so you know what sound you’re getting with downpipe and catback togther.
    I have my Dinan Exhaust sitting in my garage Like-New with flat-black tips. I LOVED the sound when paired with the stock Downpipe. However, when I installed the Catless CTS 3.5” DP, it sounded like a raspy Civic exhaust and way too loud over 2500 rpms. I was forced back to the stock catback and now there is almost no noticable change in sound from stock.
    The A3 and S3 stock catbacks are very different sounding when paired to the CTS DP. If you are looking for a good sound with the stock downpipe the Dinan is amazing and I’ll sell you mine cheap :)
    Having to do it all over again which I am...I’ll just go full turbo-back. Likely Unitronic, resonated.
    Oct 17 2018
    Cape Coral, FL
    Quote Originally Posted by ralphie_43 View Post
    That first one with the APR DP and Dinan Catback sounds terrible. Super raspy as you're driving by. This is exactly why I had to remove my Dinan. It's pairing is terrible to any DP. Just the cat back alone sounds amazing, just like mine did before I upgraded Downpipes.
    CTS Catless Downpipe | ECS Kohlefaser Luft-Technik Intake | APR Turbo Inlet | JB4 Map 6 | E85 3 Gallons | BMS Intercooler | CTS S3 Catback | Bilstein B14s
    Oct 17 2018
    Cape Coral, FL
    APR only makes a GTI\R\S3 exhaust. Nothing for the A3 Quattro (yet)
    You could do the S3 exhaust on an A3 Quattro and upgrade the valance, but IMO that's a lot of money should you decide on a full turbo-back with new rear S-Line Bumper\Valence.
    Junior Member Two Rings Chevyguy2021's Avatar
    Mar 24 2018
    Kannapolis NC
    I got my Becker exhaust from eBay for like $400. Fatback and I love it
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Quote Originally Posted by PINGERS View Post
    Yea it was definitely raspy but nothing too bad imo was reallly only bad when you were off throttle at near redline other than that it was ok
    Oct 17 2018
    Cape Coral, FL
    It’s worse with my CTS 3.5” catless. At least your APR is catted. I do like the APR S3 exhaust note-I may go that route, but that’s a lot of dough.
    Aug 18 2017
    2015 S3
    Inland Empire, CA
    Yea but I think with like 99% of exhaust systems paired with any aftermarket DP will rasp I mean at the end of the day we have 4 cylinders. If it's a thing that you dont necessarily want then there's always resonators that can be welded in to tone down the exhaust. For myself being young I like the fast and loud stuff but I understand that even some young guns like me dont want loud. I think if you got 2 of the magnaflow bottle style resonators the sound will be a bit more bearable and less raspy. I know a guy that has an s3 with a downpipe and full exhaust that put a resonator because he thought it was too loud and raspy. To each their own. No one is right or wrong, it's all in our own personal tastes.
