Results 1 to 9 of 9
    Aug 17 2015
    California
    Help with fault code/DTC: Steering Angle Sensor (G85)
    I've been getting this annoying DTC everytime I turn my car on. I have cleared it with VCDS but it comes right back again next time I start the car. Does anyone know how to tackle this? Some ideas I have are:
    1. Recalibrate the G85 sensor (steering angle sensor) with VCDS.
    2. Unplug the clock spring/steering angle sensor and ensure plug is not damaged.
    3. Replace the expensive clock spring/steering angle sensor ($$$)
    Or I wonder if this could be a bigger problem like a wheel bearing, or alignment off. But I don't think so. I also wonder if a low batter voltage could cause this? My battery is original, and I am due to replace it before the winter hits.
    I appreciate any help or advice you can give. Has anyone dealt with this code? Here is what Rosstech suggests:
    http://wiki.ross-tech.com/wiki/index...el_Electronics
    Here is the main code from the Steering wheel module:
    Code:
    Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
       Part No SW: 8K0 953 568 F    HW: 8K0 953 568 F
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90315JIO000FI
       Coding: 000036
       Shop #: WSC 02391 823 56573
       VCID: 3D7749B6A406C4F6B0B-8068
       Component: E221 - MFL  H02 0003
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
                008 - Implausible Signal - Intermittent
                 Freeze Frame:
                        Fault Status: 00101000
                        Fault Priority: 2
                        Fault Frequency: 41
                        Reset counter: 213
                        Mileage: 133933 km
                        Time Indication: 0
                        Date: 2018.08.30
                        Time: 08:06:29
                 Freeze Frame:
                        (no units): 44.0
                        Text: 2CFFFFFF8AFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00FFFFFFC0FFFFFFFF
                        Knock Sensor: 65.025 V
                        Raw, Index/Key Err.: 255 255 000
                        Text: 23FFFFFF930000432411FFFFFF8905
                        Inclination: 0.0 %
                        Steering Angle: 42.5°
                        Inj. On Time: 0.00 ms
    And here is the secondary code in the ABS Module, as a result of the above:
    Code:
    Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
       Part No SW: 8K0 907 379 BG    HW: 8K0 907 379 BG
       Component: ESP8 quattro  H04 0020
       Revision: --------    Serial number: --------------
       Coding: 1D0500
       VCID: 7F0B73BEEE8A16E6E27-802A
    1 Fault Found:
                013 - Check DTC Memory - Intermittent
                 Freeze Frame:
                        Fault Status: 00101101
                        Fault Priority: 6
                        Fault Frequency: 14
                        Reset counter: 172
                        Mileage: 134430 km
                        Time Indication: 0
                        Date: 2018.09.26
                        Time: 16:50:41
                 Freeze Frame:
                        Hex Value: 0x1300
                        Hex Value: 0x4006
                        Hex Value: 0x121C
                        Hex Value: 0x23AF
                        Hex Value: 0x00FF
    Senior Member Three Rings Quattro420's Avatar
    Apr 08 2015
    2003 Jetta tdi 5peed 2000 b5 a4 1.8t 5aq, 2005 Passat tdi wagon2.0l, 2000 sierra 5.3l
    Ontario Canada
    What does the g85 read at straight ahead 0deg? Will it go out if you turn the wheel and then drive?
    Aug 17 2015
    California
    Quote Originally Posted by Quattro420 View Post
    Reads 0 degrees when wheel is straight. It appears to give normal readings when I turn the wheel left or right while parked. I have not driven then car and checked this. I get the DTC IMMEDIATELY when turning the car on, or only a few seconds after starting to roll.
    So maybe I should try to check the live reading from the G85 as the code hits?
    Anyone know if it is even possible to separate the G85 sensor from this whole assembly?
    Aug 17 2015
    California
    I read the live result from VCDS as I turned the car on today. Readings were normal. The code appeared as I was turning the wheel with over 200 degrees of position, but the code always says 42.5 degree steering angle! I cleared the code while driving and it immediately comes back with 42.5 degree steering angle.
    Aug 17 2015
    California
    Quote Originally Posted by SDF1 View Post
    I don't have dynamic steering, and that seems to apply to dynamic steering.
    I did try this calibration, several times today, and the error keeps coming back with the exact same code! 42.5 degrees! Seems to be when I turn the wheel right.
    Aug 17 2015
    California
    Anyone know what a bad clock spring would look like? Could a bad clock spring be throwing this error code? I took my steering wheel off to inspect. Keep in mind, this has been making a slight squeaking sound for over a year now. I found grease outside of where it should be, even a little was on the back of the steering wheel.
    Aug 17 2015
    California
    Bump. I bought a used clockspring (still installed in entire stalk assembly) from eBay for $90. I messaged a few buyers and made sure to get one where the airbag did not deploy. I have not installed yet. I am still faithfully getting the same error code everytime I start the car. Will update once I install...
    Apr 08 2015
    Ontario Canada
    I would do a basic setting for the g85 then do a steering stop limit basic setting
