Results 1 to 11 of 11
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    2018 SQ5 air actuator Noise when opening the drivers door.
    Hello all,
    I hear this air noise every-time I enter the car, if overnight it's much longer maybe twice the time. It 's just as if the air suspension is loading up. My question is does everyone else that has OEM air ride have this?
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Jan 01 2015
    Yup happens to me too.
    Sep 10 2012
    DFW
    Thanks, imagination gone wild, thought it was getting louder LOL. I was going to take it in but now I will wait.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings JD S4's Avatar
    May 07 2016
    '18 S5, '94 Integra DB8 JDM, '20 Highlander Hyrbid
    Citrus Groves, Arizona
    Happens to me as well.
    The other oddity - is that every "first drive" in the morning - about a block from my house I get a couple of click "adjustments" in my gas pedal. Not sure what it is - feels like it's some sort of "adjustment" (perhaps in MMIS settings).
    '18 S5 - BBS / EPL
    Senior Member Three Rings A4_n00b's Avatar
    May 27 2007
    Pittsburgh, Pa.
    Quote Originally Posted by TexasDfwS4 View Post
    Hello all,
    It’s more than likely the fuel pump priming as opposed to the air suspension. I haven’t heard this suspension as of yet, but if it sounds anything like the system on my old ar, it’s a very distinctive “whoosh” noise that you probably wouldn’t mistake for anything else.
    Either way, totally normal.
    Current: 18 Audi SQ5, 18 Audi S3, 16 VW Tiguan R-Line 4MO
    Retired: 15 VW GTI PP, 14 Audi S4, 12 VW GTI, 10 Audi S4, 08 VW Jetta Wolfsburg, 04 Audi allroad 4.2, 04 VW Jetta, 03 Audi A4 3.0
    Current:
    2022 Audi S3, 2023 Audi SQ5
    Retired:
    2003 Audi A4 3.0, 2004 Audi allroad 4.2, 2004 VW Jetta, 2008 VW Jetta Wolfsburg, 2010 Audi S4, 2012 VW GTI, 2014 Audi S4, 2015 VW GTI PP, 2016 VW Tiguan R-Line 4MO, 2018 Audi S3, 2018 Audi SQ5
    Jan 01 2015
    Quote Originally Posted by JD S4 View Post
    Yes this freaked me out at first too!
    May 27 2007
    Pittsburgh, Pa.
    That sounds like the ABS system recalibration. Also totally normal.
    Current:
    Retired:
    Senior Member Three Rings Qumag's Avatar
    Dec 11 2014
    18'GLC63 AMG, 17' VW Golf Alltrack
    Darien, IL
    Totally normal for equipped with air suspension. My Macan Turbo with PASM does it too, but its very subtle. It compensate for the load and when you lock the car it lowers the car down. Now, my GLC63s it's loud when it airs out you can actually hear it and it sounds pretty cool.
    May 07 2016
    Quote Originally Posted by Qumag View Post
    Feels like you’re bragging and I support that.
    Sent from my
    '18 S5 - BBS / EPL
    Senior Member Two Rings Flieger's Avatar
    Aug 15 2013
    1969 VW Kombi, 1983 VW Rabbit GTI Sport, 2012 Golf R, 2015 Audi Q5 3.0T
    Colorado
    Audi/VW are set to prime the fuel system after setting for more than 30+/- min without running. If this happens every time you open the door regardless of drive time, then likely a suspension prime for the bags. If it's only first thing in the morning or after the vehicle has sat an extended period then likely the fuel pump prime.
    1969 VW Kombi | 1983 VW Rabbit GTI Sport | 2002 Audi Allroad 2.7T 6MT | 2012 VW Golf R OEM+ | 2021 Audi RS6 Avant
    Instagram: @fahren_rs6aom and @waterwerksmotorsport
    Sep 10 2012
    DFW
    It happens every time, but first time of the day it is longer. but if I open the drivers door and grab my cigarettes smoke one outside of the car and then open the door again it will do it again but not as long.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
