Results 1 to 11 of 11
    May 15 2018
    Nova Scotia
    Performance Upgrades B8 A4
    Hello hello, I'm new to the website and fairly new to the car scene. I'm a quick learner though and have been doing plenty of research so I have some ideas as to what I would like tp upgrade next. I just wanted to get the opinion of some more experienced people. So far I've owned the car 5 months and haven't done any real performance upgrades, more or less working on a few small aesthetic things first. It's a 2.0T 2011 A4 Quattro with a diverter valve spacer, sport springs, 18 inch rims on low profiles, and a RS4 hex grille blacked out.
    Hit me up with suggestions for next PERFORMANCE upgrades. I was thinking of going for a stage 1 tune with either an intake or exhaust upgrade at the same time. Thoughts?
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    First thing first if the tensioner hasn't been replaced get it done asap.
    2011 A4 Avant Prestige S-Line
    Jun 03 2018
    Bismarck
    Go stage 2 right away rather than going back to the tuner for it later.
    Sent from my VS988 using Audizine mobile app
    May 10 2015
    Pittsburgh PA
    As NovaRider said, definitely take care of your timing tensioner to avoid a very costly repair bill down the road.
    As for mods, if you plan on doing an exhaust upgrade of sorts, get a high flow cat. That will allow you to jump straight to a Stage 2 tune.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    A cheap and easy mod is the silicone turbo inlet hose and MagnumFlow Pro-Dry Air Filter. Will give you a little bit more turbo noise and a little better turbo response.
    https://www.ecstuning.com/b-ecs-part...00672ecs01a~a/
    https://www.ecstuning.com/b-afe-part...lter/31-10181/
    I'm as cool as a cucumber in a bowl of hot sauce.
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Aug 15 2015
    Prosper, TX
    Quote Originally Posted by ramey.schatz View Post
    Exactly what I was going to say. Go straight to Stage 2 for maximum smiles/mile. The difference is night and day.
    2009 Audi A4 Quattro / Prestige / Phantom Black Pearl / APR Stage II / GFB DV+
    Nov 05 2009
    '09 B8 A4 2.0t quattro '15 Q5 3.0T
    Chicago, IL
    Depending on your budget, I would do your intercooler (lots of good options here, CTS turbo, APR, Eurocode if you can find it since it's discontinued) and a K04 kit.
    I went with CTS K04 (includes HFC for minimal $), CTS intercooler, did the timing chain, carbon cleaning, and replaced the water pump. It's a good opportunity to do everything b/c
    1. They'll likely give a deal on the job since you're doing so much at once.
    2. Lots of the labor overlap
    3. Audi will likely cover the labor for the timing chain (which is a double win given #2 above).
    So my audi indie shop ended up installing the K04, magnaflow HFC, exhaust, APR intake, CTS intercooler, water pump, changed all timing chains+tensioners+guides, carbon cleaning for 3000 in labor. Audi is going to reimburse me 1300 for the labor portion of the timing chain replacement, so I'll have had all the above installed for 1700 total in labor.
    Senior Member Two Rings archangel.308's Avatar
    May 30 2011
    2022 Audi SQ8 /2018 Audi SQ5
    Chandler, AZ
    I can provide you a list of what I have done with my car..... although I am in the process of selling it in hopes they Bring the RS Q8 to market.... in two years.
    Side Blades Color Matched
    18" Style 620 Wheels - Set Of Four ET35
    Error Free Bright Reverse LED
    LED License plate Lights
    H11 - DAMA Kanji Lux Vision Fog light Kit (8,000 lm)
    RS4 Style Grill With Quattro Chrome Frame
    Glossy Standard Style Fog Light Cover Grille Grill
    S4 Style Rear Diffuser Quad exit
    ECS Front Big Brake Kit - Stage 1 - 2-Piece Cross Drilled & Slotted Rotors (345x30)
    Rear V4 Cross Drilled & Slotted Brake Rotors (300x12)
    StopTech Stainless Steel Brake Lines - Kit
    Eurocode Silicone Turbo Inlet Hose
    Eurocode Alu Kreuz Billet Aluminum Drivetrain Stabilizer B8
    EuroCode Tuning Front Mount Intercooler Kit B8 2.0T
    034Motorsport Billet Aluminum Rear Differential Carrier Mount Insert Kit
    034Motorsport Transmission Mount Insert
    APIKOL AUDI REAR DIFF MOUNT
    Milltek Sport Audi B8/B8.5 A4 2.0T Tiptronic Cat-Back Exhaust System - Resonated - Quad GT80 Polished Tips
    APR Cast Downpipe
    42 Draft Designs O2 Sensor Spacer
    GFB+ Diverter installed
    R8 Oil Cap
    R8 Expansion Tank Cap
    AFE Dry air filter
    Ultra Racing Front Upper Strut Tower Bar
    CTS Turbo K03/K04-0064 Turbo Blanket
    Billet Engine Oil Dipstick - Polished
    Luft-Technik Intake Air Scoop
    Sprint Booster V3 Power Converter
    Canyon Run CR-15 Front Strut Tower Brace, RHD
    Eurocode PowerPully
    ClearBra
    Silver Aluminum DSG Paddle Extensions
    AUDI Genuine OEM iPhone 5, 6, 7 - AMI Lightning Adapter Cable 4F0 051 510AL
    Integrated Backup Camera
    APR Dongle
    Shift Knob and Boot | Post-Facelift S-Tronic
    Audi B8 - P3 Boost gauge
    BlendMount Radar Detector Mount for Beltronics/Escort, Specialty 2025 Series
    Center Console Organizer
    AUDI under Door Logo lights
    Turbo: Exhaust gasses go in, witchcraft happens and you go faster. - Jeremy Clarkson
    MODS:
    • SQ5: (B9) IE Intercooler and Carbon Fiber Intake Kit w/ Inlet pipe., 034 Transmission and Rear Subframe Mount Insert, 034 Billet Oil Filter Housing,
    • SQ8: (4M) 034 Transmission Mount Insert, and Billet Oil Filter Housing
    • R8 V10 (MK1) Stock
    Feb 12 2017
    easton/PA
    Pics?
    Sent from my SM-G965U using Audizine mobile app
    Jun 04 2016
    A
    Quote Originally Posted by BeerBrent View Post
    Do the intercooler hose kit help improve under loads also, over the OEM rubber hoses?
