Results 1 to 13 of 13
    Mar 19 2014
    Toyo R888R vs. Bridgestone Re-71r
    Greetings Gentlemen !
    Im on the quest for the best track tire that can also be used on the street.
    If anyone has experience with these, please chime in
    Toyo R888R
    Bridgestone Re 71r
    Thanks
    I will be running 18x9 in 265/35 r18
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Another good one that ranks high is Yokohama Advan AD08R. Not race rubber, but very sticky. It is in the "Extreme Performance" summer street tire category with Tire Rack. I've been running them on a modified Mazdaspeed 3 that is about 360 horsepower. That's about all a 3000 lb FWD can handle.
    It is not a true R compound tire, but is an extremely competent street tire that can handle some track duty.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Sep 22 2013
    Hankook Ventus RS4 is absolutely brilliant.
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    I have RE-71r's on my stage 1+ TTRS, and they won't hook up at all using launch control, but the road noise is bearable and the R888 has really loud road noise, and will perform better from a launch and more than likely will also perform better in the turns.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Mar 19 2014
    Are you referring to the older R888 or the new R888R?
    - - - Updated - - -
    Quote Originally Posted by Trent212 View Post
    Jul 14 2011
    Rye NY
    I'd guess the R888Rs will be better on track, re-71s better on street. what about a pilot sport cup 2 which should be pretty good on both?
    Mar 19 2014
    I would like to add that this will be my dedicated track set of wheels and tires. I dont want slicks as ill be driving to the track, just want a bit of tread in case it rains. Racetrack is a short drive from my home
    Jul 14 2011
    Rye NY
    R888R
    Mar 19 2014
    Anyone else ??
    Sep 10 2015
    AL
    I'd try the R888r if it is only going to be used driving to the track and on track, but if you are using it for track and street I would probably try some Sport cups 2s.
    SRM TB Inlet
    SRM GTX3582
    Veteran Member Three Rings Huey52's Avatar
    Dec 22 2010
    New England
    Although I haven't tried these specific models, over the past 10+ years I've found Toyo to be superior to Bridgestone for both track and street. btw: I still love the tread pattern of the Toyo T1R which I got when first introduced as many years ago.
    For street use I'll be very soon ditching my OEM Bridgestone for always appreciated Michelin.
    2016 TTS Sepang blue/rotor gray Tech B&O
    Prior: 2013 allroad; 2011 A5
    Sep 10 2015
    AL
    Quote Originally Posted by Huey52 View Post
    The road noise is horrible on the R888, only reason I would not recommend it for daily driving.
    Senior Member Two Rings big residual's Avatar
    Mar 30 2014
    RE71Rs work well as a non-slick track tire. Imo, they respond/recover better when the car tries to understeer (compared to SC2s or Trofeo Rs). Don't mind driving them 2-3 hours to the track and they're actually find around town. Wear fast, so no highway.
