Originally Posted by
rand0mher0
A stab in the dark here but maybe a blown fuse? Wish you were local so I could scan it with VCDS.
Ok, so thanks to @autobeast for letting me borrow is VAGCOM, I now have a scan to upload. Any help is GREATLY appreciated. I removed the sections with "no fault found to make it easier to read.
Saturday,06,October,2018,19:11:06:32677
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WAUBGAFL5FA044605 License Plate: 2015S4
Mileage: 60520km-37605mi Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 07 08 09 0F 10 15 16 17 19 20 22 30 36 37 3C 40
42 44 46 47 52 53 56 5F 62 6C 72 7F 8C A9
VIN: WAUBGAFL5FA044605 Mileage: 60520km-37605miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0F-Digital Radio -- Status: Cannot be reached 1100
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
20-High Beam Assist. -- Status: Cannot be reached 1100
22-AWD -- Status: OK 0000
30-Special Function II -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
3C-Lane Change -- Status: OK 0000
40-AC Compressor -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7F-Inform. Electr. II -- Status: Cannot be reached 1100
8C-Hybrid Battery -- Status: Cannot be reached 1100
A9-Struct. Borne Sound -- Status: Not registered 0001
Address 07: Control Head
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 10: Park/Steer Assist
Cannot be reached
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0060
Revision: 1Z120030 Serial number: 3041Z148190AA3
Coding: 80C303FF00
Shop #: WSC 06325 000 00000
VCID: 4C9C99B7EFB4B22A79-8018
Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181
Component: J367-BDMHella H03 8041
Serial number: 4148414303
10 Faults Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:06:50
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
03423 - Control Module for Vehicle Positioning System Interface
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:06:51
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
03395 - Control Module for High Beam Assistant
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:06:54
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
03408 - Control Module for A/C Compressor
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:06:54
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
03713 - Control Module for HV Battery Management
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:06:54
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:19:35
Freeze Frame:
Bin. Bits: 11111
Voltage: 12.00 V
Count: 6
00459 - Control Module for Display and Input; Front (J523)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:07:49
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
02230 - Digital Radio (DAB) (R147)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:07:49
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:07:49
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
03163 - Control Module for Information Electronics 2
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 60517 km
Time Indication: 0
Date: 2018.10.06
Time: 13:07:49
Freeze Frame:
Bin. Bits: 10111
Voltage: 12.30 V
Count: 6
Bin. Bits: 10000
Address 20: High Beam Assist.
Cannot be reached
Address 30: Special Function II
Cannot be reached
Address 37: Navigation
Cannot be reached
Address 40: AC Compressor
Cannot be reached
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T1 035 223 A HW: 8T1 035 223 A
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813034141906
VCID: 2D5AF433746E9B224E-8078
1 Fault Found:
03029 - Subwoofer (R157)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 131
Mileage: 60521 km
Time Indication: 0
Date: 2018.10.06
Time: 18:54:26
Freeze Frame:
Voltage: 12.40 V
Temperature: 16.0°C
Temperature: 16.0°C
Bin. Bits: 00000100
Address 7F: Inform. Electr. II
Cannot be reached
Address 8C: Hybrid Battery
Cannot be reached
End-------------------------(Elapsed Time: 05:03)--------------------------
Address 19,8R0 907 468 P,channel 4,adapted from,8K0915105F JCB 14090774E3,to,8K0915105F JCB 14090774F4,
