Results 1 to 12 of 12
    Established Member Two Rings YMR's Avatar
    Aug 20 2018
    Charlotte, NC
    Recommended intake for B8.5 2.0T
    Hey guys, i'm looking to buy an intake but not sure which is the best for better sound & performance. My car is stock so it's very quiet. I've seen a lot of people talking about APR Carbonio and K&N Cold Air Intake. Which one is better? Or is there one that is not that well known but you believe is also as good?
    Sent from my SM-G955U using Audizine mobile app
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    IMO the ecs luft technik (non cf version) is perfect all around. Your not getting any real performance from an open intake but you can hear the turbo whine and it’s not horribly loud, radio or windows down usually covers sound. Perfect fit and all the correct hardware was there.
    Haven’t used any of the others so don’t have an opinion on those. But theoretically there shouldn’t be much of a difference besides personal preference on looks or fit.
    Quite a few ppl on here use the afe dry filter and inlet hose as an alternative to cai
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    K&N is the best bang for the buck.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Aug 20 2018
    Charlotte, NC
    Quote Originally Posted by Peter.dupuis View Post
    So pretty much if I want more performance, I should get a closed air intake? I'm not that experienced at modding cars or whatever. Learning little by little.
    Aug 20 2018
    Charlotte, NC
    Quote Originally Posted by JeriQo View Post
    I've seen videos and i'm liking the sound of the typhoon or whatever it's called. Seems like the best option at the moment unless I find something better tbh.
    Jul 21 2004
    South Florida
    Quote Originally Posted by YMR View Post
    The kn sounds terrible as do all open intakes on our cars but the kn also has a big design flaw in that it puts the maf wire under full tension. Any further engine movement which can easily happen will damage the maf wire...
    2018 Audi S5
    Gone-
    Aug 20 2018
    Charlotte, NC
    Quote Originally Posted by bhvrdr View Post
    The kn sounds terrible as do all open 8ntakes on our cars but the kn also has a vig design flaw in that itputsthe mafwire under full tension. Any further engine movement which can easily happen will damage the maf wire...
    This is extremely good info. Any closed intakes that you recommend? All im looking for is good sound & a bit of performance.
    Jul 21 2004
    South Florida
    I picked up an oem junk yard airbox and drilled two large 3" holes in it away from the hot engine and then put an afe filter in it. Youll get a tad bit of noise but not the terrible screeching you get a constant load like the open intakes that sound like a dying animal and youll eliminate the possibility of any restriction the airbix could pose though i dont think it does as i saw zero change on wastegate duty with any of the options i tested
    Sent from my SM-G935V using Tapatalk
    2018 Audi S5
    Gone-
    Veteran Member Four Rings Poodini's Avatar
    Oct 26 2015
    2016 Subaru Outback 2.5 Limited
    Fremont, NorCal
    There’s no one intake that’s decidedly better than the others per say. Certainly none are advantageous as far as hp gain is concerned. It’s just inherent with our engine/turbo design. That being said, you can check off the K&N Typhoon based on the design flaw. It comes down to personal taste in terms of sound and aesthetics really. Now, should you upgrade to say Stage 2 and up, its a must.
    Jul 21 2004
    South Florida
    Im running k04 and went back to the stock box with no holesand saw no performance reduction fwiw. The holes and afe will give you a tiny subtle noise though if that's what you're looking for.
    2018 Audi S5
    Gone-
    Aug 17 2015
    California
    Exactly what I run. Stock airbox with aFe filter and ECS inlet pipe. Not going to spend $300-400 on an inake that does nothing for performance.
    Aug 20 2018
    Charlotte, NC
    Quote Originally Posted by Poodini View Post
    I might just go with APR Carbonio if that's the case. Love the design on it. Or the ECS that was mentioned earlier. Carbon fiber looks nice. What do you think of the APR? Any opinion on that one?
