Results 1 to 24 of 24
    Mar 05 2013
    CA
    Is 034 High-Flow Cat capable of passing California smog?
    Senior Member Three Rings dalazybastard's Avatar
    Apr 08 2016
    Orange County, CA
    No.
    Just a couple B5's, you know.
    Jun 30 2008
    Erie, Pennsylvania
    It does not have a CARB (California Air Resources Board) number, so it should immediately fail visual inspection. Visual inspection will check for either the OEM equipment in place or a CARB number on an aftermarket unit. Some have gotten it to pass by making it visually identical to the stock unit by welding the OEM heat shields from the stock cat onto it. Not saying you should do that, just saying some people have done that.
    As far as the actual emissions part of it - it does have higher emissions than a stock cat (even a high miles one), but many people have gotten it to pass. It's just on the upper end of the scale. Doesn't pass with flying colors - and certain variables can put it over the top. But it it is a cat and it ought to be able to reduce emissions to acceptable levels to pass a sniffer in most cases.
    My advice would be - do your homework on what they are going to check and make sure you are prepared for that. Then have a backup plan (like, swapping in the stock cat) if it doesn't work out.
    Mar 05 2013
    CA
    I thought exhaust gas measuring probes are only used on older cars?
    And that on OBDII cars, a smog testing station simply does a visual inspection and plug into the OBDII port, to make sure there is no check engine light on and that the car has fully set readiness on all monitors, reading that the car is OK and everything works fine.
    In other words,
    OBDII scan tool: Hello car? Is everything OK?
    Car: Yes.
    OBDII scan tool: Ok. Thank you.
    In which case, IF this is true, I wonder if the car has a threshold or tolerable range, that actual values have to fall within.
    For example, if an HFC would be slightly worse/inefficient, but not severely enough to trigger a CEL.
    Unless a spacer is used? I hear J-shaped ones work well.
    I'm not sure how they actually work. If it reads higher oxygen content by being farther away from the cat's exhaust emission stream, spaced with a little buffer cushion of oxygen. But wouldn't airflow passing by (exhaust) simply create a vacuum and suck that pocket of oxygen out?
    Veteran Member Three Rings Chuckster's Avatar
    Feb 18 2017
    Socal
    2000 and newer models don’t require tailpipe testing and just get plugged in. There is still a visual inspection, which this part will fail. OBDII is checking for poorly functioning emissions equipment, so typically anything that raises those values like HFC’s or catless will trigger a MIL. To work around that, people try to use those sensor spacers, which will fail a visual inspection too, so it gets tricky to mess with the oem equipment at all.
    2017 Audi TTS | Sold |
    2019 Audi Q7 | Baby seats |
    Jun 30 2008
    Erie, Pennsylvania
    I guess I'm old. As of 2010, that's correct - Cali does OBD2 check only for 2000+ cars.
    There is definitely a tolerable range. So the factory cat has room to age a bit without throwing codes. But as far as how far that range goes - these aftermarket cats are usually right on the edge and won't reliably keep the codes away without some help (like a spacer or what have you). There are a lot of variables, so it can't be said for certain whether the specific cat you get from 034 will be able to keep the light off on your specific car. So there is that hurdle as well as the visual issue.
    Feb 27 2011
    Winnipeg
    I'm 6 years in on 034 HFC and no CEL for catalyst efficiency and no 02 spacer. We have no emission testing here but it would pass obd2 I would assume as I've got no CEL.
    Senior Member Two Rings frogspit's Avatar
    Jul 15 2017
    CA
    From what I’ve read the 034 hfc won’t cause a MIL and may even set your monitor as ready but it will fail when the tech visually inspects. If it doesn’t have the CARB logo or number or something it will not pass.
    I have a CARB certified magnaflow cat that I swap in for emissions, then swap back to my test pipe after
    I think I’ve read something about them switching to a system that can check for forced readiness too, so it’s best just to get an OEM or CARB certified cat in there for inspection
    I think the real question is will they care about a FMIC
    GTX2863R Motoza Tuned E85 17psi
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    from my research the 034 high flow cat which I believe is a magnaflow 200 cell will barely not pass. this is if your engine is in tip top shape and cat is still performing well.
    but...in California it wouldn't qualify as approved for usage as a certified replacement.
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    I've ran an 034 HFC for years and I pass on all readiness checks. However, I do get a secondary O2 sensor code for being out of threshold once in a great while (most of the time it's just a soft code that doesn't throw a MIL).
    In Utah I just passed a few days ago with the soft O2 sensor code stored on the ECU with no MIL (all readiness checks showed green). I'm glad I don't have to deal with CARB...
    Bonus: The guys at the inspection station liked my car so they gave me a free carwash. Wooooo!
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    On my old '98.5 A4, the 034 HFC didn't pass the sniffer with a F21.
    On my 2001.5 A4, the same 034 HFC would trigger cat codes without a spacer.
    So everyone may have different experiences.
    2001 Corvette (C5) Z06
    Registered User Three Rings MagnaFlow's Avatar
    Jan 26 2015
    Oceanside, CA
    All good info!
    Nov 02 2007
    SF Bay Area, CA
    https://ssl.arb.ca.gov/AftermarketParts/catalysts
    APPROVED aftermarket Catalytic Converters. buy a universal and throw on the appropriate flange you need. 3 inch would be ok. V-Band probably will not pass as it probably would be considered easily removable.
    Test Group Name Application Type Part Manufacturer Manufacturer
    Part Number Cert Level Executive Order Vehicle Class Total Converters Catalyst Location Catalyst
    Part Type
    3ADXV01.8342 ALL AP Emissions Technologies, LLC 760024 LEV1 ULEV D-754-1 PC 1 Underbody UNIVERSAL
    3ADXV01.8342 ALL AP Emissions Technologies, LLC 764186 LEV1 ULEV D-754-1 PC 1 Underbody DIRECT FIT
    3ADXV01.8342 ALL Airtek, Inc. 760024 LEV1 ULEV D-280-105 PC 1 Underbody UNIVERSAL
    3ADXV01.8342 ALL Airtek, Inc. 764186 LEV1 ULEV D-280-105 PC 1 Underbody DIRECT FIT
    3ADXV01.8342 ALL Airtek, Inc. 760024 LEV1 ULEV D-798-6 PC 1 Underbody UNIVERSAL
    3ADXV01.8342 ALL Airtek, Inc. 764186 LEV1 ULEV D-798-6 PC 1 Underbody DIRECT FIT
    3ADXV01.8342 ALL Car Sound Exhaust System, Inc. 456034 LEV1 ULEV D-193-114 PC 1 Underbody UNIVERSAL
    3ADXV01.8342 ALL Car Sound Exhaust System, Inc. 456035 LEV1 ULEV D-193-114 PC 1 Underbody UNIVERSAL
    3ADXV01.8342 ALL Car Sound Exhaust System, Inc. 456062 LEV1 ULEV D-193-114 PC 1 Underbody DIRECT FIT
    3ADXV01.8342 ALL Miller CAT Corporation 310005 LEV1 ULEV D-709-5 PC 1 Front of the vehicle UNIVERSAL
    3ADXV01.8342 ALL Miller CAT Corporation 310100 LEV1 ULEV D-709-5 PC 1 Front of the vehicle DIRECT FIT
    3ADXV01.8342 ALL Valina, Inc. 207022 LEV1 ULEV D-562-75 PC 1 Underbody UNIVERSAL
    3ADXV01.8342 ALL Valina, Inc. 207030 LEV1 ULEV D-562-75 PC 1 Underbody UNIVERSAL
    3ADXV01.8342 ALL Walker Manufacturing Company 82667 LEV1 ULEV D-182-57 PC 1 Underbody DIRECT FIT
    3ADXV01.8342 ALL Walker Manufacturing Company 82667 LEV1 ULEV D-182-59 PC 1 Underbody DIRECT FIT
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Im in Cali. Ive been running JHM downpipes with HFC's for the last 3 years. I pass smog everytime.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Mar 05 2013
    CA
    Quote Originally Posted by 19jdog View Post
    Well that's 3.0, with JHM parts.
    IDK how their cat material compares to the 1.8T 034 unit.
    I wonder how the JHM DP's are passing visual in CA...
    Jul 28 2014
    SACRAMENTO
    Quote Originally Posted by Spike00513 View Post
    I had my exhaust guy tuck my cats high up. When the smog tech gets on his hands and knees with a flash light to check I get supper nervous. I'm just stating that having HFC is illegal but if done right can pass the visual and sniff test. Maybe I'm getting lucky!
    Sent from my SM-G955U using Audizine mobile app
    04 B6 A4 USP 2.7t
    Veteran Member Three Rings pablolizarraga's Avatar
    Jul 18 2014
    "Hers": SQ5 His: 1966 Ford Mustang Coupe, 1965 Ford Mustang Fastback
    Los Angeles, CA
    Interesting. Ive never had my smog guy go underneath or do sniffer test.
    Is your car louder or does it emit an exhaust smell that makes them suspect youve got HFC’s? Starting to look into these as I just got a 0431 intermittent pop up; but all readiness monitors are still green. Would love to go HFC’s as my understanding is you get increase in power. Is that correct as well?
    Mar 05 2013
    CA
    I don't get it. So you took straight-pipe JHM DP's, and had an exhaust guy install cats on them? Why not just buy the JHM HFC ones, with cats already in them? Would they not be a similar price?
    Also, I assume non-dealership shops get into smogging to make money, as with anything else, such as repairs, alignments, etc.
    The rules might say that it has to be done visually with eyes on target, meaning no mirrors
    but if they can't afford a lift or something (which also adds time), maybe they just walk around it using a mirror.
    In which case, it's kinda hard to see cats (on a 3.0L at least) from above or below, with the big engine squeezed in a small space, and then downpipes having to curve around a big heavy transmission.
    Whereas on a 1.8T, the cat is much easier to see. There's only one, and it's right there visible between the airbox and engine.
    Jul 28 2014
    SACRAMENTO
    Whoa, I bought jhm downpipes with HFCs. Spent over a 1000 bucks in 2014. I'm just giving my 2 cents on my experience. Who in the hell goes to the dealership for a smog?
    04 B6 A4 USP 2.7t
    Mar 21 2016
    69 Nova
    California
    Good to know the jhm pipes still pass smog.
    Was that with the sniffer?
    12 S4 Quattro 6 Speed
    04 A4 3.0 Quattro 6 Speed
    69 Nova with a bunch of stuffs
    19 Sportster 883
    Jun 29 2014
    America
    In Cali, 2004 car would not be inspected a sniff test.
    Mar 21 2016
    69 Nova
    California
    Yeah, my smog guy said 2000 and newer cars don't get the sniff test. I'm just scared that I'll go to get it smogged and they'll look under the car or put the thing in the tailpipe and then I'm screwed.
    I'd rather have some kind of cat, even if it doesn't have an EO number, than no cat at all...
    19 Sportster 883
    Veteran Member Three Rings 2004a4b630QT's Avatar
    Mar 30 2015
    '04 A4 3.0 QTip
    I agree. I got the catless dp's because I've got almost 2 full years before inspection again, but I have no intention of trying to get through inspection without HFCs. I'll weld them in and take out the "neck down" to stock ends when I get a 2.5inch catback.
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by DarkoNova View Post
    They won't stick the sniffer in there, because your car is a 2000+ model year and they don't waste time with the sniffer.
    Cat without EO is nearly as bad as no cat... unless you "know a guy".
