Results 1 to 6 of 6
    Sep 10 2015
    VA
    Codes I can’t remove!
    I’m getting these codes
    Mode 3: emission related codes
    Address 7E8: no fault code found
    Address 7E9: no fault code found
    I can’t delete these codes so any advice on what to do to remove them or stop them or what they are.
    Nov 11 2010
    2023 S8, 2020 Range Rover
    Minnesota
    Perhaps you should do a scan and visit the Ross Tech forum.
    Sep 10 2015
    VA
    I used VCDS to find the codes but it’s not removing them. It cleared a bunch of other codes but these 2 stay permanently.
    Nov 11 2010
    Minnesota
    Again, since you are getting no replies here maybe go to the Ross tech site and see if they can help. They will want you to post an auto scan of your car. http://forums.ross-tech.com/showthread.php?101
    Established Member Two Rings budda's Avatar
    Mar 10 2010
    2000 S4 6M GT25 SOLD, 1990 Accord H22 GT35R w/JRZ RS Pro's, 2013 S4 GONE, 2016 S6
    Any emmisions related codes are considered permanent codes. Can't be cleared other than getting rid of the check engine light. Codes will go away after 3 drive cycles and the ecu confirms the fault that initally set the code is not set again. Drive it a few days and check again, they should go away if the problem was fixed.
    Sep 10 2015
    VA
    Thanks guys 👍🏻
