Fixes: Tried ATP-G205 as well as Blue Devil liquid fixes and has actually slowed down the leak considerably!
Also initially did the PCV diaphragm repair kit which seemed ok at 1st but then started to idle roughly and would throw multiple fault codes, most notably P0171 (fuel trim too lean), P2279 (leak in air intake system), & P2015 (intake manifold flapper sensor implausible)...
I’ve replaced all 4 R8 coils, new plugs w/ correct gap for K04, cylinders look to be ok with no excessive crud or oil and replaced the PCV unit along with double checking intake hoses/connections. STILL throwing same codes.
In terms of the IM, does P2015 typically signal its time to replace outright or can replacing the flapper sensor and installing new gaskets an option?
Secondly, if I need to replace, what’s up with the disparity in price between a direct replacement ($550 via ECS/ OEM part # 06H-133-201-AT) vs the latest revised TSI IM ($140 via Deutsche Auto/ OEM part# 06J-133-201-BH). I realize they’re differentiated as far as for the type of engine (TSI vs TFSI; transverse vs longitudinal). That said, visually, they’re near identical and the BH is commonly used on VW platforms along with our A3 and TT models.
Member Spawne32 confirmed that he’s using the TSI/ BH version on his B8 with no significant modification needed.
Has anyone else run into a similar dilemma and have any of you guys gone this alternate route?
