Originally Posted by
jv_atc
Update, 9.20
Checked and rechecked plugins, fuses, connections...
Per mkv, huge thanks for the important trans pin plug info...
Findings
Battery voltage = 11.44v
Pins 14 and 9 (ignition on) are powers, 13 and 16 are grounds
Pins 14 to 13 = 11.40v
Pins 14 to 16 = 11.39v
Pins 9 to 13 = 11.31v
Pins 9 to 16 = 11.30v
There is power and ground to the trans plug. The question, that will easily be tested, is now a higher voltage affects the function of the tcm with respect to the solenoids. I have read that the minimum voltage required is near 12.6v. The battery is new 4 months ago, been sitting.
I will charge the battery and if see if any change are realized. The most important conclusion is that both power and ground are present.
With respect to the tcm, and for future reference, are there known signs/symptoms of a unit that is on its way out? How common is a faulty tcm? Are there conditions that lead to its failure? Is the failure of the tcm simply a primary function of time? Should I expect any other damage to transmission components as a result of the failed tcm? Should I be considering a used transmission?
Any recommendations on companies that rebuild?
Ok, if you have power at the plug, then I believe there are only two other options here. 1) The comms connections are bad, or 2) the TCU is dead.
Have a good look at the CAN bus connections in that plenum chamber box. From the diagram the two wires look to be orange/brown and orange/black. The same wires on the same bus from the engine ECU and the ABS controller will be the same colour.
Why would the TCU be dead? It could be dead from ESD during handling when you were reinstalling the engine, maybe touching the pins of the unit. It could be dead due to a bad ground, like if the ground straps weren't 100% and the engine and TCU was drawing potential difference through other sources, like the circuits of the TCU. I'm brainstorming here, so this all isn't necessarily what happened. If it's really dead, it could have just been its time. Although that's very coincidental considering the timing and you say there was a noise. I don't see how a noise would kill the electronics, unless something broke off and rammed itself through the TCU..
I'm pretty sure the TCU will still be active much lower than 12.6V. During cranking the voltage can drop much lower than that. Still have a go with the charger though, but I doubt the success of this.
Ok to answer your questions: Signs of a failing TCU? I haven't really heard of one electronically dying. There are plenty of symptoms for a failing mechatronic unit (valve body), which the TCU drives. But apart from maybe on the Russian or Polish forums, I've never heard of one electronically dead, unless it was the result of a failed software flash.
I wouldn't expect damage to anything else as a result of the dead TCU. As per SSP 385, the transmission is completely disengaged, even with the transmission pump turning. The TCU can only drive the solenoids to pressurise or depressurise the clutch packs.
If your trans shifted fine before the work you did and subsequent breakdown, I wouldn't be looking for a new trans, rather a new mechatronic which you can salvage the TCU off. The TCU's aren't super readily available separately from the mechatronic units, but you can get them on eBay. Swapping this will come with it's own set of challenges, namely component protection which will have to be removed either by an Audi dealer, someone with Odis and access to the Audi network, or someone with and FVDI type tool.
I know that Sonnax in the US rebuilds mechatronics, but specifically asks that you take your TCU off before sending it to them. I have seen other companies which sell complete mechatronic and TCU units. Roughly $900 IIRC. In your case, if your trans was shifting fine and you just need a TCU, I would traul eBay for a used mechatronic with TCU on it, and just swap the TCU and get component protection removed and coding done.
This all assumes that whatever caused your TCU to fail is not still lurking, be it something electrical or something that's physically damaged the TCU or the wiring. There's still the possibility of an electrical fault in the engine bay.
