Results 1 to 18 of 18
    Active Member Two Rings lean_wean's Avatar
    Oct 30 2017
    New Mexico
    B6 A4 Manual transmission swap
    I’m starting a build on my 2003 a4 1.8t Quattro stage 2+ apr. I blew my second auto trans so I decided I need to swap in a manual trans. I got a 1998 a4 2.8 Quattro with the 5 speed as a donor car. And ordered a new south bend stage 2 clutch kit with a single mass flywheel to go with it. I’ve done a ton of research so it all seems pretty straight forward. I know that I need to find a new rear diff to mach and use the front axels from the donor but I’m wondering if I can use the center diff and driveshaft from the donor as well. Any help would be greatly appreciated. Thanks
    Btw I’m new to the forums and this is my first post so sorry if it’s not up to par.
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    I believe the B5 rear diff is much longer than the b6s, by what looks like 12”. You’d definitely need the prop shaft. I know the b5 prop shaft center bearing uses two large washers when mounted. B6s don’t have any washers. Someone out there must have tried it already.
    First post seems to be on par.
    Jun 05 2013
    Ottawa
    https://www.audizine.com/forum/showt...Swap-DIY/page3
    That should help. Use the b6 axle flanges and the b6 rear tail to the transmission. There is no mention of proper shaft and rear diff, provided your rear diff gearing is the same.
    Jun 05 2013
    Ottawa
    Also going from auto to manual, you will need a pilot bearing adapter. The automatic pilot bearing the crank is about 1” in diameter where the manuals are about 3/4”.
    https://www.audizine.com/forum/showt...dapter-bushing
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    The rear diff ratio on your auto should be 4.11, the new tranny seems to be 3.89 so you will need to swap the rear diff. If you were to source a six speed from a 2004-2005 (GJW) the drive shaft and rear diff you currently have still work ( right length, same ratio) and you don't need to swap the rear diff.
    Oct 30 2017
    New Mexico
    Thanks for all the replies everyone. My current diff is 4.11:1 but I found another with 3.89:1 to match the gearing on the transmission and I’m getting the driveshaft with it. I’m definitely going to invest in that sweet new pilot bearing instead of the DIY method. Also I read on another swap thread that the center diff doesn’t have to be swapped out if you’re coming from the auto chassis. And I won’t be swapping the axel flanges in the front to b6 because the b5 2.8qm axels that I already have with the trans will fit from what others have said. I’ll post updates when I get all the parts and start the swap
    Jun 05 2013
    Ottawa
    Quote Originally Posted by lean_wean View Post
    I dont think there ever is a center diff swap taking place. Where did you read that?
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Oct 30 2017
    New Mexico
    It’s the tail section of the transmission that can be bolted off and it connects to the driveshaft. I’ve seen people run a b6 center diff on a b5 transmission. I can’t remember what the thread was but I’ll try to find it.
    Feb 17 2004
    Liberty Hill, TX
    both the B5 and B6 5-speed tranmissions are 01A, and the center diffs are interchangeable. Late b5 and B6's use a 1-piece diff, older B5's use a 2-piece design, but they are functionally identical. It doesn't matter which you use, but you absolutely have to swap the tail housing from a B6 transmission in order to mount the Y-bracket for the transmission mount (which sits in the crossmember support)
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Oct 30 2017
    New Mexico
    Thanks for that info that’s kind of what I had thought. But instead of trying to find a b6 tail house I’m going to use the side mounts that are already on the transmission since it came out of a 2.8 a4. I may end up trying to find the tail housing later on so I’ll keep the cross member from the tip. But since I’m coming from a massive tiptronic to a 01A I can fit the side mounts on my chassis. If I had a manual transmission already than that wouldn’t work but in my case it does.
    Oct 30 2017
    New Mexico
    Quote Originally Posted by Gosser View Post
    Do you know if any b6 axel flange will fit on the b5 01A? For example the ones of my tip.
    Veteran Member Three Rings wafi ahmed's Avatar
    Feb 03 2019
    Ny Long Island
    Did you done the swap?
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Quote Originally Posted by Matt Devo View Post
    Unless you intend to go with a Stasis or JHM 4:1 center-diff option for 40/60 torque split.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Oct 29 2005
    10speed
    San Francisco, CA
    Yeah I think the confusion here is you don't need the diff, you need the rear section for the 3rd mounting bolt on the crossmember.
    - Clint
    Feb 03 2019
    Ny Long Island
    I wish I can swap my in the future I love my b6 1.8t so much but I can’t put too much power because it’s tiptronic
    Oct 30 2017
    New Mexico
    Okay so I’ve been really busy lately but I ended up taking the parts and cars to my mechanic friend to have him do all the heavy lifting and shit I didn’t want to deal with. I’m picking it up tomorrow morning and I just need to do a little wiring, install my new pedal cluster and finish programming everything. But for the most part it’s been pretty straight forward. I’ll update when I make more progress and put up a complete parts list Incase anybody is wondering what worked for this swap.
    Oct 30 2017
    New Mexico
    Quote Originally Posted by A4SoftWalker View Post
    I wish I had looked into that before. I’d love to drive a Quattro with a 40/60 split. Maybe I’ll do it later
    Mar 17 2019
    México
    Yo estoy reemplazando mi multitronic por una manual de 5 velocidades, pero no puedo codificar la ecu
