This is my DD and I commute 60 miles a day. Driving on this will do some damage? The system fault has been been intermittent over the last week. It goes away after I turn the car off. but now it stays on.
CURRENT ERRORS:
Code:
Mileage: 226830km-140945miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 5F-Information Electr. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CGXC) Labels: 06E-907-551-CGW.clb Part No SW: 8K5 907 551 E HW: 4G0 907 551 A Component: 3.0l V6 TFSIH07 0004 Revision: --H07--- Coding: 0A190034052600060000 Shop #: WSC 06208 000 00000 ASAM Dataset: EV_ECM30TFS0218K5907551E 001004 ROD: EV_ECM30TFS0218K5907551E.rod VCID: 387F42868392A18258-806C No fault code found. Readiness: 0000 1100 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb Part No SW: 8K0 907 379 CK HW: 8K0 907 379 CK Component: ESP8 quattro H09 0100 Revision: -------- Serial number: -------------- Coding: 281D1A Shop #: WSC 06325 000 00000 VCID: 0407E67687DA356284-8050 1 Fault Found: 01044 - Control Module Incorrectly Coded 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 160 Mileage: 226832 km Time Indication: 0 Date: 2018.09.09 Time: 23:16:24 Freeze Frame: Hex Value: 0x0000 Hex Value: 0x07A2 Hex Value: 0x0015 Hex Value: 0x1098 Hex Value: 0x0000 ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb Part No SW: 8K0 907 064 GL HW: 8K0 907 064 FL Component: BCM2 2.0 H11 0621 Revision: 00002001 Coding: 0B814000000000000000 Shop #: WSC 06325 000 00000 VCID: 000FEA6693C22942A0-8054 Subsystem 1 - Part No SW: 8K0 959 754 BF HW: 8K0 959 754 BF Component: FBSAUDIB8 IDG H71 0083 Serial number: 0512000073908011 Subsystem 2 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E Component: J764 ELV MLB H40 0046 Serial number: 2312000245815007 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: Redir Fail! Part No SW: 8K1 820 043 T HW: 8K1 820 043 T Component: KLIMA 3 ZONEN H04 0121 Revision: C1000000 Serial number: 01071120120186 Coding: 6618228000 Shop #: WSC 06325 123 12345 VCID: 39794782B098B88AA7-806C 1 Fault Found: 01207 - Control Module for Auxiliary Heater (J364) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 6 Fault Frequency: 1 Reset counter: 160 Mileage: 226832 km Time Indication: 0 Date: 2018.09.09 Time: 23:16:23 ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb Part No SW: 8K0 907 063 DH HW: 8K0 907 063 DH Component: BCM1 1.0 H16 0103 Revision: 08016001 Serial number: 00000510374702 Coding: 26004094803CAFE0240040C300003D0D4F9C9308A2090221000008000000030100000030000000 Shop #: WSC 06325 123 12345 VCID: 78FF8286CB12618298-802C Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB Component: WWS 091112 H07 0080 Serial number: SWF12110096839 Coding: 00FD11 Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB Component: G397_RLFS H06 0002 Serial number: 20717211 Coding: 02005D Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS Component: E1 - LDS H03 0031 Serial number: 00000000001109121855 Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658 Component: AQ_Hum_Sensor H03 0003 Serial number: 90B88756000000000001 1 Fault Found: 02258 - Door Opener Transmitter 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 1 Reset counter: 160 Mileage: 226832 km Time Indication: 0 Date: 2018.09.09 Time: 23:16:28 ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 8K0-959-655.clb Part No SW: 8K0 959 655 P HW: 8K0 959 655 P Component: AirbagVW-AU10 H45 0610 Serial number: 003KJD911L78 Coding: 303844354730303030304A55304C384B3053 Shop #: WSC 13901 002 1048576 ASAM Dataset: EV_AirbaECUVWAUDI010 003010 ROD: EV_AirbaECUVWAUDI010_AU48.rod VCID: 4A9B084EED7E23123E-801E Seat occupied recognition: Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C Component: BF-Gewichtss. H02 0040 Serial number: 5810000R120000BA3G Crash sensor for side airbag: driver side: Serial number: 6334MSME73204D1AD Crash sensor for side airbag: front passenger side: Serial number: 6344MSME72053023$ Crash sensor for side airbag: rear: driver side: Serial number: 6352QSME0025065C7 Crash sensor for side airbag: rear: passenger side: Serial number: 6362QSME0125174EC Crash sensor for front airbag: driver side: Serial number: 63732SME7622376E3 Crash sensor for front airbag: front passenger side: Serial number: 63832SME71224A76$ No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb Part No SW: 8R0 953 568 S HW: 8R0 953 568 S Component: Lenks.Modul H07 0171 Revision: 00000000 Serial number: 20121112000765 Coding: 000016 Shop #: WSC 06325 000 00000 VCID: 51A91F22082810CA7F-8004 Component: E221 - MFL H03 0004 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb Part No SW: 8K0 920 982 L HW: 8K0 920 982 L Component: KOMBIINSTR. H35 0556 Revision: 00000000 Serial number: UVU72UCCD Coding: 83BD09008301D705020000 Shop #: WSC 06325 123 12345 VCID: 3D715392A4B084AA8B-8068 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb Part No SW: 8R0 907 468 N HW: 8R0 907 468 C Component: GW-BEM 4CAN-M H11 0055 Revision: 1Y060027 Serial number: 2741Y12A31008A Coding: 80C303FF00 Shop #: WSC 06325 000 00000 VCID: 4A9B084EE57E23123E-801E Subsystem 1 - Part No SW: 8T0 915 181 HW: 8T0 915 181 Component: J367-BDMHella H03 8041 Serial number: 7003958401 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels: 8K0-907-163.clb Part No SW: 8K0 907 163 B HW: 8K0 907 163 A Component: 4 Wheel Drive H13 0100 Serial number: 002210120001119 ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019 ROD: EV_AllWheelDiffeQSPCAN.rod VCID: 2F6D79DA76DC663A09-807A 1 Fault Found: 0333 - Oil Pressure and Temperature Sensor C1004 F0 [008] - Oil Pressure Implausible Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 5 Reset counter: 200 Mileage: 226797 km Date: 2018.09.09 Time: 20:23:25 Voltage terminal 15: 13.75 V Voltage terminal 30: 13.91 V VPS Voltage: 13.91 V Pump for all-wheel drive: voltage: 0.00 V motor pump voltage terminal B: 3.91 V Pump for all-wheel drive: current: -4.13 A Torque distribution: 24 Nm Torque distribution: specified value: 0 Nm State KomonentenRegler: normal Control Module temperature: 40 °C Temperature output stage-Data: 33 °C Temperature QCU-Data: 36 °C Thermal load ECU-Data: 0 bar Thermal load of all-wheel drive pump: 0.0 % Oil pressure and oil temperature sensor temperature: 36 °C ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb Part No SW: 8K0 959 760 D HW: 8K0 959 760 D Component: MEM-FS H06 0076 Revision: AA000000 Serial number: 00000042048662 Coding: 00581300000000000000 Shop #: WSC 06325 000 00000 VCID: 3B755D8ABAA48A9AB5-806E No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb Part No SW: 8T0 959 793 P HW: 8T0 959 793 G Component: TSG FA H09 0304 Revision: -------- Serial number: -------------- Coding: 011C03204E00410001 Shop #: WSC 06325 000 00000 VCID: 56A3EC3E21C677F2AA-8002 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb Part No SW: 8K0 909 144 F HW: 8K0 909 144 B Component: RCEPS H37 0507 Revision: 00001000 Serial number: 0025999891 Coding: 000000010001 Shop #: WSC 06324 123 12345 ASAM Dataset: EV_RCEPSAU48X 008014 ROD: EV_RCEPSAU48X.rod VCID: 346776B69FFA45E274-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb Part No SW: 8K0 907 064 GL HW: 8K0 907 064 FL Component: BCM2 2.0 H11 0621 Revision: 00002001 Serial number: 0186605730 Coding: 0106063A00FA404482B0013200000000 Shop #: WSC 06324 123 12345 VCID: 000FEA6693C22942A0-8054 Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719 Component: GTO BF H01 0080 Serial number: 00000000000000598619 Subsystem 2 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591 Component: J245 PS050 H08 0043 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb Part No SW: 8T0 959 792 P HW: 8T0 959 792 G Component: TSG BF H09 0304 Revision: -------- Serial number: -------------- Coding: 011C03201E00410001 Shop #: WSC 06325 123 12345 VCID: 55A1EB323CC07CEAA3-8000 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake (----) Labels: 8K0-907-801-V2.clb Part No SW: 8K0 907 801 L HW: 8K0 907 801 J Component: EPB-4 H01 0003 Revision: -------- Serial number: 20000000170366 ASAM Dataset: EV_ParkiBrake 001027 ROD: EV_ParkiBrake_VW51.rod VCID: 387F42868392A18258-806C No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (R) Labels: Redir Fail! Part No SW: 4G0 035 082 E HW: 4G0 035 082 Component: Radio U SIRIU H60 0121 Revision: AB001007 Serial number: 156K/0C7663700 Coding: 020007020100000001 Shop #: WSC 06325 000 00000 VCID: 224B80EE3D0EDB5296-8076 No fault code found. ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb Part No SW: 8R1 035 746 C HW: 8R1 035 746 B Component: H-BNT-NA H44 0624 Revision: -------- Serial number: 204KW0C7542450 Coding: 110200000206E3EF45028F4E00000403140000000000000000 Shop #: WSC 06325 123 12345 VCID: 377D41BA868CAEFA51-8062 Subsystem 1 - Part No: 8R0 060 884 BA Component: NAR 2013 0703 Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604 Component: DU7 High H41 0104 Serial number: A130J.0C2578337 Subsystem 3 - Part No SW: 8T0 919 611 K HW: 8T0 919 611 B Component: E0380 Bedient H02 0030 Serial number: 00000001321966 Subsystem 4 - Part No: 8R0 060 961 E Component: CD-Database 4949 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H Component: TSG HL H07 0304 Revision: -------- Serial number: -------------- Coding: 010C03204000210001 Shop #: WSC 06325 000 00000 VCID: 59B9E70250D8588A87-800C No fault code found. ------------------------------------------------------------------------------- Address 6C: Back-up Cam. Labels: 8T0-907-441.clb Part No SW: 8T0 907 441 C HW: 4L0 907 441 B Component: J772__Rearview 0040 Revision: --H07--- Serial number: 525PA8-J2892U1 Coding: 1000006 Shop #: WSC 06325 000 00000 VCID: 387F42864B92A18258-806C No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb Part No SW: 8T0 959 795 Q HW: 8T0 959 795 H Component: TSG HR H07 0304 Revision: -------- Serial number: -------------- Coding: 010C03204000210001 Shop #: WSC 06325 000 00000 VCID: 59B9E70250D8588A87-800C No fault code found. ------------------------------------------------------------------------------- Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb Part No SW: 8K0 907 159 HW: 4H0 907 159 A Component: SAS-GEN 2 H06 0005 Serial number: 121003200308 ASAM Dataset: EV_SoundActuaGen2AU64X 002005 ROD: EV_SoundActuaGen2AU64X.rod VCID: 72EBB0AEA56E0BD2A6-8026 No fault code found. End-------------------------(Elapsed Time: 03:37)--------------------------
