Oil in Intercooler
Was swapping for Apikol SMIC. Found oil residue on intercooler outlet and a small puddle of oil came out of the inlet. I know some of this is from the PCV system, and my car just bounced around on a trailer for a week, but still, it seemed worrisome. I haven't put in the Apikol SMIC to avoid gumming up the new core. oil was clean
My turbo is old but hasn't given any other cause for alarm. Pictured is what dripped out. There is more but removing that elbow is a bitch.
Oil in Coolant
This has been an issue for fucking ages. In May (5K miles ago) I replaced the oil-to-water oil cooler, expansion tank, and flushed twice with rad-flush. 14 fills with DI water later, and the coolant drained cleaner but not clear. A lot of oil sediment came out in the first half of flushes, but not later on. When I replaced the timing belt less than a thousand miles later, I also swapped the coolant flange (was seeping slightly) and the valve cover gasket. I have been watching this for a while; usually, my oil level won't drop by a detectable level, and always drains clean, but it is currently low.
This engine's valve train looks fantastic, as does the rest of the car, but a bad turbo and head gasket would really suck. Thoughts?
