I thought I got rid of my ABS problems but it seems another problem has surfaced. I’m getting a code for the brake pressure sensor. I’ve done a little bit of troubleshooting but I’m willing to bet it is the sensor itself.
Now if I replace this sensor I’m going to need to bleed the ABS module. What order do I do this in. Would I bleed the ABS module first and then the brake lines or vice versa?
Any other info on this topic would be helpful as well.
Troubleshooting I’ve done:
-scan with VCDS; brake pressure sensor code, will not clear
-check function of brake pedal switch; activates while pressing brake pedal
-check function of brake pressure sensor; receives pressure value while holding brake pedal
-perform abs system test; assuming test cannot be completed because of stored code, or quite possibly I’m just doing the test wrong.
That’s all I got, looking forward to hearing some of your responses!
Sent from my iPhone
