Originally Posted by
Overbias
I thought I would provide an update here on this thread. Croltean and I have been messaging back and forth comparing notes and progress. Here is what we know about this issue:
Likely not related to fuel pumps, Croltean has replaced almost the entire fuel supply system, fuel control unit, both HPFP, lift pump, filter I have replaced one HPFP and fuel duty on my car never goes above 35% even during one of its episodes.
We both get lean codes, rough idle then stalling. Then restart takes an age and smells of fuel.
We have both had our cars smoked for vacuum leaks, nothing obviously leaking.
I know he is still battling but I may have made a breakthrough. Located under the Upper Intake Manifold are a couple of fuel pressure sensors:
06J-906-051 D (Listed as G247 in Workshop manual)
06E-906-051 K
My tech went to the effort of removing them and testing and was able to find that they were intermittently faulty. So he replaced them and the car tested fine last week and yesterday so he felt confident that I could pick it up.
So far so good. I realize I may be jumping the gun here but if this does turn out to be a fix for this issue then maybe this info will help others with the same problem.
The key here is that I don't believe that the ECU can identify this problem while its happening. It just gets a wacky reading form the pressure sensor and thinks 'oh there's a low fuel pressure problem, I need to add more fuel, oh there's still a low fuel pressure problem, I need to add more fuel' hence lean codes and then rough idle and stall as the engine is then "flooded", then it takes an age to restart because... you have to burn off all the fuel and or wait for the sensor error to pass to reset the fuel trim, or do as I was doing, clear all the codes before trying to restart and the ECU supplies the default amount of fuel at startup and doesn't add to the 'already a lot of fuel' in the engine problem.
So if you can't measure the sensors with the ECU the only way to confirm if they are faulty is to get direct access to them and scope their outputs while the engine is running to understand what signals they are sending to the ECU, when my Tech did that he identified that they were sending spurious signals and that led him to want to replace them.
I will keep this thread updated if there are any further developments.
I think Croltean can chime in here as I think he's been at a Dealership and online with AOA neither I believe understand the length that you need to goto to diagnose and resolve an issue like this one.
Hope this is helpful and I would welcome discussion or input on the diagnoses, result or method.
As Overbias has mentioned Ive replaced nearly everything but the fuel pressure sensor (G247) located on the fuel rail. I even reached out to AOA and advised them of the issue and asked if they had any TSB's or other complaints as we are now starting to creep up in mileage on these cars. They had nothing. I told them of all the work that was done / parts replaced and provided receipts, but unfortunately they did not want to take the word of another mechanic - they wanted a certified Audi tech to confirm.
Per AOA's request they advised me to drop off my vehicle at the dealership for a diagnosis. Fast forward 8 days later and countless hours spent testing and diagnosing we still have nothing on the issue. They even called in a TAC (Technical Assistance) request as their foreman and techs could not identify the issue. When questioned on the amount of hours it would take to diagnose the answer I got was an indefinite amount and once all tests pulled out they were going to start swapping parts all at my expense.
At that point I reached out to AOA and advised them of the situation to which AOA pretty much told me good luck and I was welcome to try another dealership. Not what I wanted to hear from a company I spent a fortune with. Anyways, sorry to ramble about that but I wanted to share my AOA / Audi dealership experience - which was advised by AOA to begin with.
While at the dealership the following tests were done:
ECM Capacitive Test - All passed
TCM Test - Passed
Second Smoke Test - No leaks outside and inside the crankcase
Fuel Trim Test - All within spec
Fuel Pressure Test - all within spec
HPFP's - Tested and passed (both new)
LPFP - Tested and passed (also new)
All electrics for the fueling system - tested and passed.
The tech was then able to replicate my issue by driving the car hard. As expected the car began running lean and stalled out.
At this point I am waiting to get my car back from Audi to take back to my independent shop to replace the G247 sensor which requires the removal of the upper manifold.
Hopefully overbias put an end to this adventure as it has been very nerve racking.
I will continue to update as I make more progress.
