Results 1 to 9 of 9
    Nov 10 2013
    annapolis, md
    What kind or size battery for my B8 S4 key fob?
    Hello all, I’ve changed the battery in my remote key before, but I forget what size and kind of battery I need. Can anyone help me what battery do I need for my key fob. Thanks so much in advance.
    Mar 28 2016
    CR2032
    - - - Updated - - -
    Why didn't you just pull the battery out and look at it? That's what I just did to find the answer for you.....
    Established Member Two Rings audi_403's Avatar
    Mar 04 2017
    2015 A6q 3.0 1993 Urs4 1987 4000q20vt 2003 a4q avant 2004 a4q avant 1972 100LS
    Columbus Ohio
    I replaced mine while reading this...
    Nov 10 2013
    annapolis, md
    Mine was blank and I saved the box so I could remember the name and model but it’s been misplaced. Thanks for the help
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    I just replaced mine in my spare key tonight. My son had to drive the car briefly today and came back with a dead fob battery.
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Mine began dying very quickly while I was in a Best Buy. Barely was able to unlock the door and start the engine. Would have been nice if a message had appeared on the info screen a week or two before it went out.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Feb 15 2018
    Walk into audi and they will replace battery for free
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    My 2015 had a message, replace key fob battery. But when I used a cheap Chinese bsttery , it did not. I now only use Panasonic battery, made in Indonesia, which is the eom battery! yes Dealer will replace if car still under warranty, but trip back & forth use more gas than buying 5 of them on Amazon
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Aug 02 2018
    Illinois
    CR2032. I just keep a pack of them with my owner's manual in the glovebox.
    I usually get the low battery warning on startup for a good month before the keyfob starts having intermittent problems.
    Sent from my SM-G955U using Audizine mobile app
