Results 1 to 17 of 17
    Established Member Two Rings tastic's Avatar
    Oct 19 2014
    BC
    Ideal offset for 275/40R20 on 20x9.5 for 14 SQ5
    I have a 2014 SQ5 and have picked up some 20x9.5 wheels and 275/40R20 rubber.
    The wheels have a native offset of +35. What would be the ideal offset? Get 10mm all around and make them +25?
    Will be lowered but not slammed on H&R coils.
    Thanks in advance!
    PFA pre lowering
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    et25 should be about right. These were 20x9.5 et29 with 5mm spacers added, 275/40r20 Michelins, and dropped 2”.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Veteran Member Three Rings base14's Avatar
    Jun 01 2017
    OR
    +2 on the et25. Its pretty darn flush with that setup! 10/15mm F/R spacers on your setup would be better than 10 all around
    2018 A6 3.0t P+ Competition Package| 034 Stage 1 ECU+TCU (his)
    2015 Q5 3.0t P+ S-line | EPL Stage I (hers)
    (SOLD)2013 allroad Prestige | APR Stage II | E85
    (SOLD)2010 Q5 P+ | OEM+ Build Thread
    Oct 19 2014
    BC
    Quote Originally Posted by riceboy22 View Post
    That looks great! When you have a moment, do you have any other shots handy? Perhaps a similar angle from the front and a side shot?
    Mar 26 2015
    New York, NY
    I don’t have those wheels anymore, but here are a couple of different angles I had taken photos.
    Current
    Past
    Oct 19 2014
    BC
    Thanks! Much appreciated! Where did you source the ecodes? I’m allergic to amber as well.
    Jun 01 2017
    OR
    If it helps, these are 20x9 et25. I put 5mm spacers in the back (not pictured here) and it looked perfect to me but had vibrations so I removed them. It’s easier to space 10-20mm BC they have the hub centric lip which the 5ers did not.
    Veteran Member Four Rings buggravy's Avatar
    Jun 25 2016
    Mountain bikes and snowboards
    Calabasas, CA
    Everyone else beat me to it, but I feel like ET25 has basically become the reference point for all non OEM fitments. Works perfectly with tires from 255 to 295, with no clearance or poke issues across the board.
    Mar 26 2015
    New York, NY
    Quote Originally Posted by tastic View Post
    If you’re interested shoot me a PM and I can share info. I got them from a somewhat unique source.
    Current
    Past
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Quote Originally Posted by buggravy View Post
    Now hold on there, Wilbur. . .the 10.5" wheels do poke a little at +25, but it looks damn good on the gen.1 SQ5's.
    Established Member Two Rings kellin's Avatar
    Nov 29 2017
    2008 Carrara White 911 Carrera S
    Northern, CA
    Quote Originally Posted by SQive View Post
    20x10 et25 is probably one of the best fitments for the S/Q5. Look at Mops@Nemesis’ posts and you’ll see what I mean.
    2016 S7 Prestige Daytona Gray Pearl / Arras Red Valcona w/ Audi Design Carbon | Black Optic | Sport Package | DAP |
    Former:
    2015 S4 Daytona Gray Pearl 6MT | Panda Nappa | Aluminum Inlay | Sport Diff
    2014 Q5 P+ SC3.0 Lava Gray | Titanium / Black Optics | S-Line+| Adaptive Suspension
    2009 A3 3.2 Quattro S-Line
    Oct 19 2014
    BC
    Ended up having to go with 12mm spacers up front to clear the caliper (10mm didn’t fit). For the rears, I used 15mm. So final net offset is +23 front +20 rear. Camber is -2.0 front and -2.2 rear. Stock arms. Lowered on H&R coils.
    Jul 31 2017
    Brooklyn NY
    I did a quick calc a little while back, and an additional 1 degree of negative camber will move the top of the wheel in by 6.4mm (all else being equal). Something to keep in mind if you are running a lot of camber and comparing the look to those running a more stock camber.
    Nov 27 2017
    Los Angeles, CA
    Quote Originally Posted by Silver_Bullet View Post
    This is great info. Something many people don't think about when selecting wheels that can make a big difference in final fitment.
    Anyone have data on how much camber drops with every inch of lowering?
    Nov 27 2017
    Los Angeles, CA
    How did you get 6.4mm? Using this calculator and a 29.1 diameter, I get 0.51 inches (approx 12-13mm) per degree:
    http://www.gtsparkplugs.com/Camber-O...alculator.html
    Jul 31 2017
    Brooklyn NY
    Quote Originally Posted by stapan View Post
    I like that somebody did a calculator! But this is basic trig. I get the same number but divide by 2. If you look at their drawing they are showing the change over the diameter - from the top of the tire to the bottom of the tire. If you assume you are roughly pivoting around the drive axis/wheel centerline, then half the move is in at the top and half the move is out at the bottom.
    But this has got me thinking here, so into the rabbit hole we go! It will not pivot around the drive axis specifically because the control arms set the suspension and I assume the drive axle will float to adjust horizontally. Maybe the system pivots more around the lower control arms, which seem to attach to the knuckle maybe 4-5 inches under the drive shaft. In that case, add 4 inches to the radius = 14.55 + 4 = 18.55. Top Offset per Degree = 18.55 *25.4* sin (1 degree) = 8.2mm. So maybe a little more than 6.4mm.
    But now deeper into the rabbit hole. I'm thinking this works with the change from your original setup to your lowered setup with the camber measured PRE-ALIGNMENT. Once they align it, they will be shortening the lower control arm to pull in the bottom of the wheel to get camber back in spec as much as possible. So the post alignment top offset change would be the calculation above plus the amount shortened on the lower control arm in mm during alignment. I would use your pre-alignment camber numbers as the best estimate since the upper control arms are so high - the top of the tire will not move that much with the shortening of the lower control arm on the bottom.
    I hope my logic is on target but feel free to trash it if I'm off base here. I have no relevant domain knowledge on suspensions, just trying to noodle this out!
    Nov 27 2017
    Los Angeles, CA
    Love it! Thanks for sharing with the community. I was surprised how hard it was to find an accurate estimate of this effect.
    You seem to really know your stuff - how much does lowering an inch equate to in negative camber change? That'll help us get to the end goal lowering amount -> offset change.
