Originally Posted by
A4SoftWalker
Yeah Seerlah my research into the SPC failures turned up that thread as well.
I'm assuming the boot got compromised and the rest followed from there.
All SPC needed to do was sell the dude a half-arm at cost and all that could have been avoided.
IF I go with SPC I would have to increase my scrutiny during regular inspections of the boot. Photos and dates documented.
As fR3ZNO and DarkoNova mentioned it is my guess that SPC since they deal with so many makes of cars might have their design "for sale" perhaps like a franchise chain. Just my guess of course seeing that it is so closely mimicked as to be virtual twins.
If a tire rotation and oil change is every 5k, I guess that adds control arm boot inspection. I wonder if it's possible to re-boot them with a better quality boot, or to install better quality joints into the arm. Or swap on different outer part halves.
Making your own might not be cheap or easy, and choosing a material different from aluminum might be more damaging in the event of a crash, where aluminum is chosen to be the first point of failure. That way it's strong enough to function as a suspension component, but still weak enough to bend and be replaced by a collision repair facility.
Otherwise, I'm not sure what a different metal part would do, such as iron. If it'd bend the bolt holding it, the holder parts, and tweak the body it's attached to.
Not to mention reducing crumpling effect, and adding weight.
Or what about drilling holes into the other side, to install grease fittings? Even if the boot tears, maybe using a grease gun would push out any contaminating dirt, and re-lubricate any grease that might have escaped from the torn boot.
