Results 1 to 3 of 3
    May 26 2011
    San Diego
    Bolt size to install 18z to B7
    Hi there. Does anybody know the bolt size that I need to install the 6 pot calipers into the B7 S4 knuckle?
    I know that the top part needs to be 16mm and the treaded part is 14mm of width.
    But does anyone know the length and the type of thread?
    I placed an order with JHM but they don’t seem to have them in stock.
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    measure the thickness of the boss on the calipers & the boss on the hub (knuckle).
    you can get these to measure with:
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
    Registered User Two Rings KillerBrakes's Avatar
    Apr 22 2016
    Bucharest/Romania
    or you can grab a set from us:) https://www.ebay.co.uk/itm/292674772668 , because you will need the sleeves also, from 14 to 16mm
