Hey all, I've been dealing with a clutch swap for months now. Finally got the motor in and gravity bled the slave, I've found the slave line is leaking where it connects to the slave cylinder. I'm using a new Duralast metal slave and the USP braided line. The line has a good amount of in/out play where it connects to the slave, I'm using the clip that came with the Duralast SC. I don't recall there being any o-rings or fittings on the USP slave line, just the tapered end.
What gives here? Do I need to try a different slave, or could this be a missing o-ring or fitting issue? I recall a thread where the OP removed the female fitting on the slave and put a larger o ring of some sort. I'm mainly concerned why the slave line is able to move so much
