Originally Posted by
ahyeah
Is the metal arm touching the side of the console? I've had previous cars (hell, maybe the RS3 has this I haven't looked) that have a strip of felt attached to the side of the receiver arm. My guess is to keep it from making contact with the console plastic.
No it doesn't seem that simple. All Audis seem to have this felt on the actual seat belt buckle receiver. What i'm experiencing that when i really pull on that entire metal arm (which, at the top of is the seatbelt buckle receiver) towards my center console (by actually holding the metal part of that assembly, which is below the seatbelt buckle receiver) then the noise goes away. It seems to be something about applying torque/stress to the attachment point of the seatbelt buckle receiver assembly to the bottom of the passenger seat that fixes it. But when i crawl under the seat to look, i cannot shake anything down there that reproduces the rattle. I tried tightening the torx bolt that is at that attachment, but it was already super tight and i could not make it any tighter.
Wusty
I have this exact same rattle in mine! My cars at the dealer as I type this, they're trying to fix this.
Please keep me in the loop!!
Micronaught
Mine made a similar noise , turns out in my case it was the roof trim that met the door pillar above the adjustable seatbelt mechanism.
The service guys secured the hell out of the roof area and the noise stopped.
I think we are talking about different rattles. Yours sounds like it was coming from the passenger door-side, right? Mine is more central. Does yours go away if you pull the seatbelt buckle receiver hard against the center console?
