Hey Audizine, I’m in desperation mode with my s4. I’ll try to make this brief. I have a problem with getting esp/abs/brake lights off my dash. Here’s what happened. Abs module was fine. There were no codes on VagCom, I was having an issue with acceleration on my car. Under WOT the car was jerking pretty violently and my traction control light would blink. My mechanic and I thought it might have something to do with the abs module, so in a moment of desperation he basically reset the module and put it into the function test mode. The one Ross-tech demonstrates how to do on their website. Ever since then, I haven’t been able to complete the test. I try and try for hours but to no avail. So I figured I’d keep driving the car and hopefully a code would pop up, and sure enough it did. It was a code for the Yaw rate sensor. I went out and bought one and swapped it out. Tried to do the test again, but still not able to complete it. At this point I just got fed up with it and decided to leave it on. But every time I drive the car, the lights come back on. I scan it again and again and now a new code is popping up. It’s 01423 Lateral acceleration sensor (g200) 27-00-Implausible signal. I’ve researched for the last 2 weeks probably and I cannot find anything that even remotely suggests where this sensor is on the s4 or even what it looks like. Some pages say it’s incorporated together with the yaw rate sensor but I’ve seen the g202 sensor and it’s a separate unit. I don’t know what to do anymore about these lights or about this code. And I’m praying someone on here knows something about this issue. Here’s what my dash looks like on a daily basis. I start the car, have a solid esp light, a solid abs light and a solid brake light until I take the e-brake off. The e-brake light disappears, now just the esp and abs lights are on. Then I firmly press the brakes and the esp light turns off, suggesting that the system funstion test procedure has started. The abs light is still on at this point. So I go on about my day driving normally and I don’t know under which circumstance, suddenly I hear 3 beeps and esp light comes back on and brake light is flashing. Sometimes it happens, sometimes it doesn’t. But every time I get the same code. And my abs light never turns off. I’ve relayed this as clear as possible and as short as I possibly can to make my problem clear. I hope someone can help me out with this because at this point I’m ready to just give up on the car completely.
