I just replaced all of my coils with BERU replacements due to a very slight stumble noted when driving WOT and was wondering if my choice of spark plug was a contributor to the coil's failure....Specifically the resistance afforded by a spark plug and its' affect on over-stressing a coil.
I've been running NGK BKR7E (.028 gap), since early 2003, with various stage II tunes.
I know our ignition system was engineered around a spark plug with 1k ohm resistance and a coil boot with a 2k ohm resistance.
The BKR7E has 5k ohm resistance resulting in 7k Ohm on the secondary side of the coil. Since the system was originally designed for 3k ohm could this increase to 7k, coupled with an increase in boost, over-stress the coil and lead to an early failure.
I was considering changing to a PFR7Q plug which has 1k ohm resistance with the necessary heat range. Other than being 3-1/2 times more costly is this a worthwhile change or am I over thinking this....NO laughing now.....
PS- I'm changing plugs yearly---about 3,800 miles of use.
The coils failed after only some 68,000 miles of use. I don't know if it was one or several coil failures as I changed them all at the same time.
A GOOGLE search on this question didn't yield much....I did, however, learn some stuff about EMI but not much else....
