Results 1 to 40 of 53
    Oct 25 2013
    DFW
    Rotor Replica Wheels
    Anyone running either of these?
    https://www.oewheelsllc.com/AU29-19085-gunmetal-machined-wheels-set-fits-Audi-A-Series
    https://www.usarim.com/19-inch-audi-wheels/aud-325-19-gmt/
    Veteran Member Four Rings KRp220's Avatar
    Aug 23 2011
    NH
    i run a rotor rep for my winter setup but went with Alzors. check these out: https://www.ecstuning.com/b-alzor-pa...-four/628-9kt/
    most people find them to be fine from the reviews i've seen, and i certainly dont have any issues with them
    2013 S4 // ESTORIL BLUE // 6MT// RS BUMPER // GIAC STG 2 // FORGE CC // AWE+SCORPION // ECS INTAKE // BILSTEIN+H&R // VOSSEN VFS5 // PSS 265/30/20 // AK // 034 MOUNTS // SB STAGE 3 CLUTCH // CR 15
    + ECS Diffuser, BFI shift knob, tints, sports diff, j-codes, Akebono pads, SS clutch line, Ceramic Pro...
    GONE 2010 S4 // QUARTZ GREY // 6MT // GIAC STG2 // AWE TRACK // ROC EURO // 034 TRANS MOUNT // H&R OE's // AG M610 FF 19x8.5 // + random stuff
    Oct 25 2013
    DFW
    The photos I’ve seen of the Alzors look very light in color compared to OEM and lack the concave aspect. Are yours 19s? If so post a picture.
    Thanks
    Senior Member Three Rings jsilas's Avatar
    Dec 29 2015
    2016 S6, 2021 SQ5, 2016 R1M, 2004 R1
    WA, PNW
    Why not hit up Hartmann Wheels / Achtuning? They make excellent rotor wheels in a number of sizes.
    https://www.hartmannwheels.com
    2016 S6 | Mythos / Black | Prestige | Sport | Carbon | Black Optic | Bang & Olufsen | Driver Assistance | OEM RS7 Turbos | APR Stage III ECU/TCU | CoD delete | APR DPs | SRM Intakes | CETE AVC | CETE ASC V2 | H&R Sway Bars | VIM | CarPlay | Opti-Coat Pro+ | XPEL Ultimate PPF | XPEL ceramic tint
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by jsilas View Post
    +1 to this. Been running a set for 5 years, and had great luck with them. Not cheap replicas, and the quality is at least as good as OEM.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by v36sedan View Post
    Thanks
    Conversely, it always appears to me that the Hartmann version is darker in color than the OEM version, so keep that in mind based on the look you're going for.
    EDIT: Another difference I've noticed with Hartmann (and some other replicas) vs. OEM is that the OEM version has a constant smooth radius going from the wheel face into the inner barrel, whereas the Hartmann and other replicas have a sort of "corner" where the face of the gray area of the wheel starts out roughly parallel with the machined surface at its outermost point, then there is a well defined crease/corner where it turns back toward the inner barrel.
    Hartmann:
    OEM:
    It's kind of subtle, and in some respects I prefer the Hartmann style as it helps the wheel to look bigger in my opinion.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    why not get oem? i thought the whole point of oem wheels is they are stronger than cheap ripoffs. hartmanns are fine. others pass
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Mar 28 2016
    Quote Originally Posted by tar View Post
    My first guess would be cost.
    Senior Member Three Rings rvcahawaii808's Avatar
    Mar 18 2017
    Portland, OR
    Quote Originally Posted by SteveYem View Post
    Hartmann:
    OEM:
    how big of a difference is the concave-ness between the hartman and your oem s5? i honestly might prefer the hartman if they are darker, but if the concave-ness is really less noticeable from the s5's, then it would be a deal breaker for me.
    Veteran Member Four Rings if6ws9's Avatar
    Feb 08 2012
    Grand Cherokee
    Palm Harbor, Fl
    I'm interested in that also. The Hartmann's look more concave but that could just be the way the pic was taken.
    2014 A5, Gloss Boat Blue, Black Optics, Sport package, MMI+, B&O, AWE Touring, AWE DP, USP HFC, CTS CAI, APR Stage 2, ST Coilovers, Alu Kruez, 034 TX insert, ECS diff bushing, Apikol blue diff mount, VAG's, Escort Redline, ZR4 shifters, 20% tint, Sprint Booster, ECS dipstick, FB steering wheel, piston diverter valve, ECS rear lower control arm brace, 10mm & 12mm spacers, BFI shift knob, CR 15, powder coated calipers, extended paddles, Vossen CV3-R's, Eurocode F&R sways, RS grille
    Aug 17 2015
    California
    Quote Originally Posted by rvcahawaii808 View Post
    Big difference and this was the deal breaker for me.
    OEM S5 are 19x9 et33.
    Hartmann reps are 19x8.5 et 35.
    You lose 8mm of concavity which is very noticeable. Nothing beats those OEM S5 19x9 et33 specs! AFAIK there are no replicas with the same width and offset.
    Oct 14 2012
    Empty...for now...
    SE PA
    Sorry, I should have clarified that the "OEM" photo I included in my post was not of one of my S5 wheels. It was a random photo I found online of a set of OEM S4 spec Rotor wheels, just to show the difference in the geometry of the wheel face to barrel transition.
    With that said, here are some photos of my S5 spec OEM wheels (19x9 et33) showing the geometry and color, to compare to Hartmann and other replicas:
    OEM S5 Rotor 19x9 et33
    Hard to tell on the concavity. I don't know whether the Hartmann version is the same concavity as OEM S4 spec 19x8.5 et43 but with a thicker center section to make it a lower offset, or if the wheel center is the same thickness as OEM but shifted farther toward the inside rim so that the spokes have to stretch a farther distance (i.e. more concavity). Maybe the Hartmann version is somewhere in between OEM S4 and S5 spec wheels? If anyone out there with the Hartmann 19x8.5 wheels is willing to take some measurements, I would do the same on my S5 Rotors. I'm thinking to lay a straight edge on two of the machined wedges spanning the center of the wheel, and measuring from the bottom of the straight edge down to the "face" of the center part of the wheel. That distance will allow us to gauge the relative concavity of the two wheels.
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    I can tell you OEWheels (one of the OPs original links) is reputable - and decent quality - I've run their Corvette style wheels on my Camaro for years. But I believe they note the Audi Wheels on their site WILL NOT fit the V8s or 3.0T Models.... Specs line up but they must know of something that doesn't work - Brake Fitment maybe?
    If price is an issue - Hartmann seems to be the trusted source for Replica Rotors.
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Sorry for being off topic, I have a set of oem s5 rotor wheels with minor scratches for sale. If anyone is interested pm me for pics. I prefer local pickup for $1000 in LA area.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Apr 11 2012
    Love the Hartmann’s, the finish doesn’t hold up to brake dust as well as oem, but you just need to clean them more often and use a wheel cleaner with iron remover.
    May 06 2015
    Minnesota
    Quote Originally Posted by will13k7 View Post
    Can you measure the offset of your wheels like Steve has suggest in post #12 above? A number of us are curious as to how the concavity of the Hartmann's compares to the S5 rotors.
    2013 Estoril Blue S4 - gone but not forgotten
    2014 SQ5 - gone but not forgotten
    2015 Mini Cooper S
    2021 Hyundai Santa Fe
    Apr 11 2012
    They are et38.
    May 06 2015
    Minnesota
    They are et38.
    I meant the physical measurement he described in his post (distance from the wheel center cap to a straight edge placed across the outer rim of the wheel).
    2015 Mini Cooper S
    Apr 11 2012
    Quote Originally Posted by MN Blue S4 View Post
    lol, giving me work man. haha. sure, I'll do that, these are not for the concave obsessed though .
    Oct 14 2012
    Empty...for now...
    SE PA
    And I'll do the same when I get a chance this coming weekend!
    Aug 17 2015
    California
    That Hartmanns and other reps have significantly less offset than the OEM S5 rotors. Just look at the pics posted above.
    Also this:
    Quote Originally Posted by A4x View Post
    May 06 2015
    Minnesota
    Also this:
    Understood but pictures aren't always clear because it depends on the angle the picture is taken at. Width and offset will obviously impact concavity but as Steve pointed out in his post above, it also depends on where the manufacturer locates the center of the wheel in relation to the rim. Wheels made by different manufacturers have noticeably more or less concavity than each other even though both have exactly the same width and offset. The thought behind taking the actual measurement was that would be the purest indication of just how concave each wheel was.
    2015 Mini Cooper S
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Agree with the above. Offset and concavity are not directly related. Don't assume a lower offset means more concavity. All things being equal, it should, but the design of the wheel/face has a lot more to do with it than the offset in most cases.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Veteran Member Three Rings Audi_Andrew19's Avatar
    Nov 02 2016
    Washington, D.C.
    What’s your brake rotor/pad setup? Looks great.
    Aug 17 2015
    California
    Quote Originally Posted by jran76 View Post
    You guys are right, but it is also pretty clear from pictures that the OEM S5 rotors have more concavity and look better! I was in this same boat a few months ago shopping for wheels. Looked at many many pictures of these rotor styles, and none looked as good or as aggressive as the OEM S5 19x9 et33!
    Apr 11 2012
    about 30mm.
    Junior Member Two Rings
    May 25 2017
    Bartlett, IL
    Finishline wheels have a decent price on OEM
    https://www.finishlinewheels.com/AUD...14/A-58867U30/
    Oct 14 2012
    Empty...for now...
    SE PA
    about 30mm.
    Measuring the same way on my 19x9 et33 S5 rotors, from machined face to top of center cap, I got right around 45 mm. So, we know that the S5 Rotor spokes have to span ~15mm more than the Hartmann 19x8.5 et38 replicas. Now if someone with OEM S4 spec 19x8.5 et43 wheels could go out and do the same measurement, then we could see how the Hartmann and OEM S4 concavity compares.
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    I just measured my OEM S4 Rotors, it’s about 30 mm.
    2005 A4 USP (Gone)
    2012 S4
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by CardFan View Post
    Thanks! So, that must mean the Hartmann replica wheel center is 5mm thicker than the OEM version in order to have 5mm lower offset with similar face concavity.
    May 04 2018
    Midwest
    Good work guys.
    Aug 17 2015
    California
    But the OEM S5 rotors have 15mm more concavity.
    Apr 04 2018
    Is there any poke with the S5 Rotors or is negative camber required?
    Oct 26 2015
    Latvia, Liepaja
    I know this is somewhat old thread, but it helped me a lot, so I want to give my 2 cents. I ordered WSP Italy Rotors 19x9, et33 and concavity is 40mm, thats a little better than OEM S4 rotors, but far from OEM S5 rotors...
    - - - Updated - - -
    Oct 26 2015
    Latvia, Liepaja
    Junior Member One Ring SlateEd's Avatar
    Aug 17 2019
    More resurrecting an old thread. Does anyone know if the Hartmann 19x8.5 with ET25 offset are actually more concave to get the offset number? anyone with pictures of ET 25 rotors fitted to a B9 S4 or S5?
    2019 S5 Sportback, 2022 eTron, 2006 Viper SRT-10, 2017 Viper GTC (the Last TA1) | 2012 S4-6MT (sold) | 2023 RS6 Avant (almost here)
    Oct 02 2006
    Wadsworth,OH
    Most cast wheels are going to have the same faces for most offsets, width sometimes causes a difference in face concavity. Once we're back in the office (Ohio stay at home order currently) I'll measure the depth of some faces of the Alzor 628s.
    -James
    https://www.ecstuning.com/b-alzor-pa...heels-19_inch/
    Veteran Member Four Rings Ford Prefect's Avatar
    Jan 20 2017
    RS7
    New Hampshire
    Quote Originally Posted by SlateEd View Post
    They are slightly more concave than the stock rotors but nothing like the A/S5 rotors. The center of the wheel is thicker and longer bolts are required to install the 628s. I think I have picture comparisons and will look tonight.
    Jan 20 2017
    RS7
    New Hampshire
    I don’t have great pics but you see they are pushed out more. IMG_1721.JPGIMG_1722.jpgIMG_1724.jpg
    Aug 17 2019
    -James
    Awesome, thanks! Stay safe for sure... anything you can do to avoid being like us in NY.
    Quote Originally Posted by Ford Prefect View Post
    Cool - thanks! They do look like they're just about as far out as you would want. These shots are also giving me that nostalgia feeling for my B8 S4... Love the B9 but I miss the manual.
