Results 1 to 29 of 29
Thread: 4.2 vs 3.0T
    Aug 23 2016
    NoCo
    4.2 vs 3.0T
    What's everyones thought on the 4.2 vs 3.0T? Been looking for a 3.0T but found a good deal on a 4.2. About half the price. 124k but runs well. Super clean for 6k. Most 2009+ 3.0T are still north or 12k here.
    Sent from my Pixel 2 XL using Tapatalk
    Feb 15 2018
    4.2 is less reliable and less powerful
    V8 sound is indeed better, and clearly the price is as well for you
    So with that information it's up to you to decide
    Personally I would just go 3.0t and do it right the first time if I was you
    Feb 15 2018
    Unless you really like the sound of a V8 I would say that it is unwise to go with a 4.2 from a long term financial stand point as well as performance
    Senior Member Two Rings se.farrell's Avatar
    Jan 09 2014
    Los Angeles, CA
    Go with the 3.0 for longevity.
    From what I understand, it is going to be more reliable.
    Plus, the real reason for me is that it has way more aftermarket support. There is not much you can do to the 4.2. But the 3.0 has much more optionality, both performance and styling.
    Current:
    C7 A6 3.0T Prestige - Glacier White
    STAGE 1 | TSW
    C6 A6 S-line - GONE
    Aug 23 2016
    NoCo
    Correct me if I'm wrong but isn't the 4. 2 engine in the A6 belt driven and not a chain like what's in the S4?
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Quote Originally Posted by Audimatic777 View Post
    The 4.2 engine in the C6 is chain driven. It is also the major weakness in the engine. The timing chain guides and tensioners become a real problem once you pass the 9 year/135k mile marks.
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Aug 23 2016
    NoCo
    Quote Originally Posted by Kevin1 View Post
    Got cha. For some reason I thought it was belt driven. My bad. Maybe it's the older version?
    Anyways, I guess I should not do the 4.2 then.
    Feb 15 2018
    Go for the 3.0t bro the c6 a6 3.0t is the most undervalued car RN
    Nov 03 2011
    All Over!
    My choice would be the 4.2 V8.
    1986 Type 85 Audi 90 quattro
    Nov 03 2011
    All Over!
    The 3.0T and 3.2 N/A are also chain-driven, similar set-up to the 4.2 079-series.
    Same strengths and weaknesses in terms of timing gear.
    The 4.2 V8 079-series is more reliable than the 3.0T.
    Feb 15 2018
    I read the 3.0 is based off the 3.2 and that the repair for the timing chain is much different than the 4.2
    With the 3.0t as I understand it the job can be done without pulling the engine
    Whereas with the 4.2 you have to pull the entire thing and drop the tranny
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    I know little about the 4.2. I can say that the 3.0 TFSI engine can be bumped up to over 400 horsepower with one 30-45 minute pulley swap and a stage 2 tune. If you don't go crazy on the pulley ratio it remains uber reliable.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Oct 14 2017
    Erlanger, KY
    Skip both the 3.0T and the 4.2 V8. You really want the 5.2 V10.
    2008 Audi S6 (Brilliant Black)
    2002 Chevrolet Corvette Z06 (Electron Blue)
    Nov 03 2011
    All Over!
    Quote Originally Posted by NickLim View Post
    The procedure is exactly the same. The chain on the 3.0 TFSi / 3.2 FSI is at the rear of the motor, same as the 4.2 079-series. How can the chain be replaced with the engine connected to the transmission??
    Nov 03 2011
    All Over!
    Quote Originally Posted by MSq5 View Post
    Very true.
    But the 3.0T lacks the displacement of the 4.2 V8. The V8 will ultimately produce more power than the 3.0T. There’s just no substitute for displacement.
    Feb 15 2018
    Very true.
    The V8 will ultimately produce more power than the 3.0T - u sure?
    Feb 15 2018
    For whatever reason I also don't think the timing chain is as big as a problem as on the 4.2
    I basically never hear about anyone doing that repair - whereas with the 4.2 I hear about it all the time
    Feb 10 2018
    Kansas city
    Quote Originally Posted by Spaceme1117 View Post
    I came in to say the same thing lol.
    Feb 14 2017
    Gulfport, MS
    Very true.
    How much money and what hard parts mods would you have to do to produce more power than a Stage 2 or 2+ 3.0T Would the labor be more than 30-45 minutes to swap out a pulley and belt and flash a tune?
    Oh yes, you can get there with APR's Stage 3 supercharger kit for only the modest of sum of . . . $13,000. But, wait, price notwithstanding, that is displacement AND forced induction, and does not count the considerable labor cost involved.
    Active Member Two Rings BSIX-SFOUR's Avatar
    Nov 24 2017
    Crappy 2001 Ford F150
    Eau Claire,WI
    From someone who has now owned both, let me put in my 2 cents. I owned a B6 S4. Great car! Quick, agile, and that 4.2 really sings with a decent exhaust(not AWE). The biggest Achilles heel to that platform is undoubtedly the chain driven timing. As one of Audi’s first(if not THE first) production vehicles to feature a chain driven timing system, there was bound to be some problems. I’ve heard of guides and tensioners failing as quickly as 60k Miles. Unfortunately, it’s a rather labor intensive and expensive problem to have. Mine came with a 3rd party warranty, and to my surprise they covered the whole thing (totaling just north of $10k at my local Audi dealer). Even though I used JHM timing components (which I had to pay out of pocket for but was later reimbursed). The warranty cost me $3500, and it was money well spent in this scenario. I now own a B8 S4... when I purchased it was at 69k and I shelled out a little over $18k for it. It has the APR stage 2 single pulley upgrade and TCM flash which according to APR’s dynograph makes right around 455 hp and 395 ft lbs of torque. To put this in perspective for you, people have bought the JHM supercharger kit for the 4.2, had the block sleeved, done all forged internals, added titanium valve components and STILL don’t make that amount of power. The supercharger kit is $8000 on its own, then to have JHM completely do the bottom end is another $10,000, plus the cost of the car, and the $3000 for upgraded valvetrain. In my mind, it was a no-brainer. Plus with the B8, you get way better creature comforts. Although the B8 does sound like shit compared to the B6/7. Lol I always laugh when people say there is no replacement for displacement. If that’s the case, then why can a 3.5L Nissan RB28 make as much or more power than a twin turbo 5.2L v10? More cylinders doesn’t necessarily mean more power. The b6/7 s4... or even RS4 don’t hold a candle to a B8 S4 in the bang for the buck department.
    Senior Member Three Rings lumberwood's Avatar
    Apr 06 2016
    Hamilton, ON
    Amen.
    Sent from my Pixel using Audizine mobile app
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    Quote Originally Posted by BSIX-SFOUR View Post
    I completely agree with all of this. I am also an owner of both platforms (b8 4.2 S5, B8.5 S4 with Stage 2, and now B8.5 S5). Before getting my most recent S5, I toyed with getting another B8 S5 and adding a supercharger plus the supporting mods. After looking at the costs, I went back to the V6T. The cost of a clean 6MT 4.2 and doing the mods simply didn't make sense. Getting to 450+ HP with the V6T is a fraction of the cost of supercharging the 4.2. I still miss the V8 noises but I don't miss the crappy 4.2 fuel consumption.
    Sent from my Pixel 2 XL using Audizine mobile app
    Nov 03 2011
    All Over!
    Google 3.0T timing chain issues.
    Already, despite the 3.0T being a relatively new engine, chain rattles have started. The 4.2 079-series is 15-years-old, so naturally you’ll hear more issue with them.
    I’m an ex Audi Master Tech, and I still keep in touch with the boys at Audi. The 3.0T timing chain issues are starting in the same way they did with the 4.2 079.
    The repair procedure will be the same, too.
    Nov 03 2011
    All Over!
    You’re talking about a totally different issue here.
    I chimed in, because reliability was mentioned, with the 3.0T being more reliable than the 4.2, which is strictly not true.
    There are other ways to boost the 4.2, it’s just that most people take the easy way out. They want bolt-on power. Coming from an engineering background, I know how to extract more out of the V8, be it chain or belt-driven. And I will always start with the largest displacement I can commercially get hold of.
    The 5.2 V10 would be my choice, once they become more readily available used, and more cars get written off.
    It’s just a matter of time, and like the vulture sensing carrion in the distance, I’m patient.
    Aug 23 2016
    NoCo
    Thanks for everyone's input. I think what I am getting at is a 4.2 A6 could be had for significantly less. I found another one for 5k private party with 100k miles. The cheapest 3.0T I have found has been 9500 with over 100k miles. So buying a 4.2 and worst case happens, you're still all in for under 10k and the chain and tensioners are done.
    I had a 2012 A4 stage 2 APR and loved it. I do get you can get more cheap power from the 3.0T. Just weighing the options. I have also been keeping an eye on V10 S6. Have found a few for same price as a 3.0T A6. I always have the false sense of better reliability with an n/a motor due to experience.
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    S6 is great.
    I see (30) 3.0T's a day.
    Established Member Two Rings thierryfabrice1's Avatar
    Nov 17 2011
    2012 RAM 1500, 2013 Audi S4, 2012 Audi S5 facelifted, 1990 Audi CQ
    South Bend IN
    4.2fsi has been very reliable to me. About to hit 100k no problem. Timing chain is not an issue on 4.2FSI engine. Now speaking of bigger displacement. You can and will always extract more power out of bigger displacment vs smaller engine. In this case 4.2 vs 3.0. it is just a matter on how much money you are ready to drop in. The S5 is not tuner friendly because there is just no much room in the engine bay. Maybe A6 engine bay is a different story
    Sent from my Moto Z (2) using Audizine mobile app
    Feb 15 2018
    I just tuned my 3.0t and bro the 3.0t is crazy.... This the engine you want.
    Oct 09 2015
    Boston
    If you get the S6, you need one with all the options. Carbon Interior, Solar Sunroof, Etc.
    A tune on the S6 brings you right around 445-460hp, of course dependent on a few things like all other cars :) Maintenance is key not limited to an S6.
    A symphony at your right foot.
