Results 1 to 9 of 9
    May 31 2016
    Mexico
    2016 Audi Q5 Premium Plus 3.0L Cat Scale Weight
    Just an FYI for others as I just went to the cat scales in Jessup, MD to have my car weighed and the information is found below:
    Weight 1 - Full Gas, about 5 pounds of personal stuff in car, no driver:
    Front Axle = 2420 lbs
    Rear Axle = 2100 lbs
    Total Weight = 4520 lbs
    Weight 2 - Full Gas, about 5 pounds of personal stuff in car, Me in Driver seat (200lbs):
    Front Axle = 2520 lbs
    Rear Axle = 2200 lbs
    Total Weight = 4720 lbs
    Looking at the label on my driver side door, it shows:
    Gross Vehicle Weight Rating (GVWR) = 5655
    Front Gross Axle Weight Rating (GAWR) = 2866 lbs
    Rear Gross Axle Weight Rating (GAWR) = 2976 lbs
    Payload Capacity = 1047
    Some Notes:
    • Based on axle ratings I have a hypothetical rating of 5842lbs. So something else is lowering my GVWR (not the axle ratings) and not the load based on the tires or wheels. Most like suspension, but I'm not sure.
    • Being 200lbs, I'm surprised that weight in the driver seat weighed down the front and rear axles exactly 50% (100lbs each).
    • Left over total payload with me in the car is 935lbs.
    • Left over Axle weight with me in car is 346 lbs on front axle and 776 lbs on rear axle.
    • Based on seeing the axle ratings, I can somewhat understand why a weight distribution hitch might not be necessary as our tongue rating is 440lbs. Additionally, a unibody frame like ours is not built for a WDH as well.
    Figured I'd put this out there as I couldn't find exact weight ratings for our cars and since I'll be buying some toys soon, I needed this information and thought it would help others.
    2016 Q5 3.0T GIAC Stage 2, HP tuners TCU tune with help from P3U and BG SQ5, aFe 11-10121 Pro Dry S filter, 034 Throttle body hose, AWE Cold Front Heat Exchanger
    93 octane tune (0-60mph 3.90 seconds (1 ft rollout), 0-60mph 4.12 seconds, 1/4 12.31 secs @ 112.40, 0-60ft 1.90 seconds)
    Race 104 octane tune (0-60mph 3.70 seconds (1 ft rollout) , 0-60mph 3.89 seconds, 1/4 12.09 secs @ 115.34, 0-60ft 1.88 seconds)
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Thanks so much for sharing this! Always outstanding to have great information like this for reference.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Established Member Two Rings kellin's Avatar
    Nov 29 2017
    2008 Carrara White 911 Carrera S
    Northern, CA
    GVWR (gross vehicle weight RATING) is the *maximum* operating weight/mass of a vehicle as specified by the manufacturer including the vehicle's chassis, body, engine, engine fluids, fuel, accessories, driver, passengers and cargo but excluding that of any trailers. It’s common for actual/measured vehicle weight (aka GVW) to be less than GVWR.
    2016 S7 Prestige Daytona Gray Pearl / Arras Red Valcona w/ Audi Design Carbon | Black Optic | Sport Package | DAP |
    Former:
    2015 S4 Daytona Gray Pearl 6MT | Panda Nappa | Aluminum Inlay | Sport Diff
    2014 Q5 P+ SC3.0 Lava Gray | Titanium / Black Optics | S-Line+| Adaptive Suspension
    2009 A3 3.2 Quattro S-Line
    May 31 2016
    Mexico
    Quote Originally Posted by kellin View Post
    No issue with GVW being less then GVWR. Was just pointing out that the axles arent the point lowering the GVWR as combined, they have a higher ratig then gvwr
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    This is good info. I didn’t realize that the 3.0 weighs almost 400 pounds more than a 2.0T with almost all of it on or in front of the front axle.
    My 2.0T Premium Plus tipped the scales at 2110 front axle and 2020 rear axle with a full tank of gas for a total of 4130 lbs.
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
    May 31 2016
    Mexico
    Quote Originally Posted by Perry01 View Post
    Perry,
    What weight ratings (GVWR, payload, GAWR) do you have on your car,
    Nov 27 2017
    Los Angeles, CA
    What do you mean by left over axle / right over axle weights? Can we derive corner weights from this?
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Two more cylinders, the supercharger system (heavier than a turbo) twice as many exhaust manifolds, downpipes and cats will do that. But, it can make impressive power with just a tune and pulley.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    May 31 2016
    Mexico
    Quote Originally Posted by stapan View Post
    What I mean is that in addition to GVWR, our cars have Axles ratings for both front and back. Those weight limits are defined on a sticker found on the driver side door.
    Based on the CAT Scale weights for my front and rear axles, I subtracted those numbers from the Axle limits on the front and back to get 346 lbs on front axle left until i reach the max and 776 lbs on rear axle.
