Results 1 to 40 of 58
    Established Member Two Rings quillonvu's Avatar
    Feb 22 2011
    Las Vegas/Nevada
    Motor mount failure on 2013 S6
    Just brought in my 2013 S6 for 35k mile maintenance and the mechanic discovered that my mounts needed replacing. Problem is that I bought an extended warranty through Endurance in May but the adjuster came and determined through the ecu that it was damaged/leaking in March... how easy of a diy is this or is it ok to just drive it without replacing them right away? Just need some options cause this job is costing an arm and a leg when I literally just bought an extended warranty for problems like this 🤦🏻*♂️
    Registered Member Three Rings DoughBoyFreshLV's Avatar
    Apr 01 2014
    Las Vegas, Nv
    Get use to it!! Lol, these Audi motor mounts go all all the time no matter what model. I have a 2012 a7 and have replaced both sides maybe 3 times with less then 50k miles, a decent shop will change them out for less then 400 bucks, sometimes you just have to bite the bullet my friend.
    Sent from my SM-G950U using Tapatalk
    AKA: Yoshi123
    Feb 22 2011
    Las Vegas/Nevada
    I wish it was 400! The shop is charging me about 1600 for parts and labor.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Quote Originally Posted by Yoshi123 View Post
    ...a decent shop will change them out for less then 400 bucks, ...
    I thought S6 mounts were around $600/ea? Either way I think they are at least twice as expensive as A7 mounts.
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    wow...i must be lucky..im at 80K miles and i'm not sure that they've ever been replaced. def not in the last 50K miles.
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Mar 06 2016
    Knoxville, TN
    88K on my 2012 A6 and they have never given me any issue, no codes, never replaced. However, As preventative maintenance, I am installing the 034 Density line mounts since I will be dropping the subframe for a test pipe install. I'm Not sure if 034 offers these for the S6 but it may worth looking into as an upgrade and to save $.
    2018 Q7 Prestige, APR Stg2, Airmatic Links, Vossen HF-4T 22x10.5
    SOLD / '12 A6 3.0T Prestige / Uni DP 93/e30 tune / p3u tcu tune / Iabed Fluidampr 3.2 PR / Jokerz ported SC / Iabed Porsche TB / Merc HX / 034/AEM intake / JHM v2 test pipes / AWE Touring with modified AWE DPs, Vibrant/GESI cats & MF 11386 / 20 x 9 VMR v702s / Yokohama Advan Sport A/S 275/35/20 / EC sways & Alu Kreuz / 034 LCAs, motor mounts & inserts / LYKT UCAs / RS6 Grill / rear lip spoiler / Bose + Bazooka 10" Sub
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    72k miles here and have replaced the mounts twice (once it's driver side only, other times are both sides).
    Also, it never throw any codes or anything, car was in for service and dealer noticed and replaced under warranty.
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Mar 26 2010
    US
    Quote Originally Posted by MacFady View Post
    That's about right for each S6 active motor mount: https://genuineaudiparts.com/parts/2...E&group=MOUNTS
    4H0199256T - FRONT MOUNT S6 right
    4H0199255T - FRONT MOUNT S6; Left
    MSRP = $628.18, Online Price = $467.37
    BMW M3 Competition X-drive
    Oct 20 2016
    Los Angeles/CA
    Just finished up 35k maintenance under audi care on my 2015 S6 as well (cars only at 26k today) - my service advisor did a great job in identifying any issues and replacing which included the motor mounts. The invoice noted a bunch of customer statements (which i didnt make) for each diagnosis. Thought i would share in case anyone needed to use at their dealership to get something looked at:
    Replaced Transmission Pan Gasket - "Customer states oil leaking from under the engine area, oil burning smell from front of car when engine is warm"
    Replaced Engine Mounts - "Customer states engine runs rough at idle, front end of car vibrates at idle" (this one I did ask him based on the RPM test noted in forums)
    Replace Lower Control Arm Links - "Customer states in and out of driveways, front end suspension clunks and makes a popping sound when wheels are turned"
    Hope that helps!
    2022 RS6 Daytona Gray
    Aug 08 2018
    Clearwater, FL
    i send you a PM. i am located in clearwater and i have a shop i go to you can take it and he doesn't charge much.
    Feb 22 2011
    Las Vegas/Nevada
    Thanks for all the advice and input guys! I just decided to get the work done... the shop is charging me 620 for each side and 820 for the labor which totals a bit over 2k just figure I have to bite the bullet this time but any other major work will be done under warranty at least
    Mar 28 2014
    The Big Apple
    It's frustrating seeing all this complexity over what should be a simple motor mount. All because of 4-cyl mode that saves what, maybe 0.1 mpg? No way in hell the minuscule amount of fuel saved is worth it.
    Jul 30 2013
    Colorado
    Audi should have recalled these, German engineering at it's finest.
    Junior Member Two Rings
    Mar 07 2018
    Pacific NW
    To all the repetitive failure posters: Do you use your engine start/stop feature often?
    I am trying to correlate if the high failure rate can be due to the frequent cranking during these on/off cycles.
    Mar 26 2010
    US
    Quote Originally Posted by vector78 View Post
    Most likely due to 4 cylinder mode which happens quite often.
    Mar 17 2017
    Redondo Beach, CA
    Quote Originally Posted by quillonvu View Post
    Wow, I'm surprised the adjuster actually scanned the car for fault codes.
    Word of advice... get an OBDEleven or VagCom cable and scan/delete any old codes, so if they reappear now, it'll be stamped with today's date before you engage your warranty company for future claims :)
    2013 Phantom Black S7 | Bang & Olufsen | Driver Assistance | Night Vision | HUD | Comfort seats | LED headlights | 20" 5-arm-rotor design | Carbon atlas inlays | Cold weather package | EPL Stage 1
    Sep 12 2014
    2015 A6, 2010 Q7, 2010 Camaro, 2004 350Z
    Las Vegas, NV
    C7 A6, both engine mounts collapsed, and all upper control arm bushings torn (probably due to vibration) at 30k miles. Ridiculous.
    $1500 to replace motor mounts, $900 for control arm bushings. No codes thrown, but car vibrated like a diesel truck. This sort of "engineering" is complete idiocy.
    Thank God for warranty.
    2015 A6 3.0T, Phantom Black / Black, Prestige, Driver Assistance, Black Optic / Sport, Cold Weather
    2010 Q7 4.2, Orca Black / Black, Prestige, S-Line, Adaptive Air, Pano Roof
    Aug 04 2019
    Add me to the list. Started noticing a clunking noise and thought it was suspension, not confirmed yet, but was informed me or mount leaking. Luckily both are getting replaced under extended warranty.
    2014 RS7
    51k miles
    Sent from my J9110 using Tapatalk
    Veteran Member Four Rings digdah's Avatar
    Dec 11 2017
    DFW
    Be aware that the front end clunk is usually diagnosed as a motor mount issue or control arm issue incorrectly. Well the motor mounts do go way too fast and a scan will prove that however make sure the cross brace under the plenum is checked. I chased my clunking issue for a long time which was fixed after speaking with the lead tech within 15 mins...for free.
    Check out this thread for reference:
    https://www.audizine.com/forum/showt...ront+end+clunk
    Aug 04 2019
    Quote Originally Posted by digdah View Post
    Thanks will check it out. The mechanic is pretty good but I'll mention it to him.
    Oct 08 2012
    Bloomfield Hills
    No issues on my 2016 A7 with 55k miles. I think they changed the motor mounts on the facelift A6/A7s.
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    Anyone know if there is a updated part number for these mounts? My driver side just broke and I'm about to replace both of them but just wanted to confirm the part numbers before I order the parts. Also stealership was recommending to replace both sensors as well, is that true or can you re-use the old ones. Thanks.
    Sent from my SM-N950W using Audizine mobile app
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Senior Member Three Rings wangao0316's Avatar
    Apr 03 2019
    2014 S7, 2017 Q7
    Las Vegas, NV
    Quote Originally Posted by ichi d View Post
    Left engine mount:
    4H0199255T (Current part # on all S6, S7 and RS7 models)
    4H0199383B (New superseded part # as of July 1st, 2020)
    Right engine mount:
    4H0199256T (Current part # on all S6, S7 and RS7 models)
    4H0199384B (New superseded part # as of July 1st, 2020)
    2014 S7 Prestige - | DS1 ECU Custom Stage 3 | BE TCU | RS7 Turbos | RS7 inlets + airbox | SRM E85 Sensor & LP Lines | RM Motors DPs | FL Taillights | RS Grille | OEM Key Fob Remote Start | Custom Carbon Fiber Steering Wheel | Uniden R7 | VCDS Mods | More to come ..
    0-60mph: 3.05s , 1/4 mile: 10.89s @ 128.37, DA~6000ft, full weight.
    2017 Q7 Premium Plus - Stock for now, Family Car
    2015 S3 - APR Stage 2 (Gone)
    2015 A3 - APR Stage 1 (Gone)
    May 10 2013
    Toronto,ON
    Thank you for this info. I'll be ordering the new part ending with the letter B. Do you know if you need new sensors as well?
    Quote Originally Posted by wangao0316 View Post
    Left engine mount:
    Right engine mount:
    Sep 17 2010
    Left engine mount:
    Right engine mount:
    Good to see there's been a revision. Do you happen to have any info on whether there have been updates to the C7 A6/A7 mounts? I'm getting ready to replace mine and would consider sticking with OEM if there's a revision, otherwise may try the 034 mounts.
    Jun 19 2018
    21 Jeep Gladiator / 05 Tahoe Z71
    NH
    Mounts come with the sensor attached as a singular unit
    2013 Q7 / Prestige / Mugello Blue Pearl
    2014 S7 Phantom Black on Black / B&O / DS1 ECU Stage 2 / SRM TCU tune / RS7 Inlets & Airbox / JXB Carrier / 034 Drivetrain Inserts / Cooling mods coming - SOLD
    2016 A6 3.0T / Premium + / Glacier White on Black / S-line / Sport Package w/ 20" wheels / No Mods - TOTALED
    Jan 06 2020
    Tokyo, Japan
    Hi guys,
    I suspect my engine mounts are also gone. Could you guys let me know if my symptoms are the same?
    - At idle, there is a slight jerk when changing to Manual or Sport mode from Drive mode
    - At start up, the car jerks forward
    The jerk or bump I am referring to does not happen while driving or when gear changing. I only notice this while stationary. Interestingly, there is also no or very little jerk if the car is on an incline. I think this is because the weight of the motor is pushing against the mount.
    Thoughts please?
    FYI I own an 2013 RS6 Avant but I believe the mounts are the same as an A6 and RS7.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    My 2012 A7 has the original mounts at 205,000 miles. I have the motor out for timing chains at the moment so I will be changing them when the engine goes back in. Neither is leaking but the passenger side is showing signs of dry rot and the driver side is starting to tear. I don't want to go after them later when I have the perfect opportunity now.
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    Quote Originally Posted by RS6_Tokyo View Post
    Hi guys,
    Thoughts please?
    Most folks report having a rough idle just sitting at rest when one of their mounts gives out. If you have a vagcom cable and vcds, you can test the motor mounts by making them vibrate with the engine off in accessory mode, and with the windows down. You should hear a fairly loud vibration from each side separately. If one of them is much quieter than the other, then the quiet mount is malfunctioning, likely due to fluid loss. You can of course check for any codes, but lots of folks with defective mounts som’t seem to have any error codes.
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Jan 06 2020
    Tokyo, Japan
    Quote Originally Posted by OlyS6 View Post
    Very helpful thank you.
    May 10 2013
    Toronto,ON
    Rough idle when the car is on. Im still waiting for the new revised motor mounts to come in I ordered them 3 weeks ago and it still hasn't arrived yet. They said it will take up to 3 to 6 weeks as they are on back order.
    Nov 27 2018
    Valparaiso, IN
    I bought mine from Europaparts for $150 each. Got here in a matter of days
    Jul 12 2013
    8V S3 and B5 S4
    Old Bethpage, NY
    Just an fyi, FCP Euro has lifetime warranty on parts they sell. People have been returning engine oil and filters and have been reimbursed (may not be worth it if shipping is too expensive). But, for a more expensive part(s) it might be worth a look.
    Sent from my SM-G965U using Audizine mobile app
    2018 Carrara White Audi Q7 3.0T P+, Cold weather package, Vision package, Warm weather package, Driver Assistance package and towing package
    Stock
    2016 Mythos Black Audi S3 P+, Black Optics Package, Tech Package, LED Lighting Package, B&O, Red Calipers
    Modded
    2001.5 Brilliant Black Audi S4 Sedan 6MT
    Stage 3
    Established Member Two Rings Ro7's Avatar
    Nov 07 2017
    Somerville, MA
    Including this thread, there are so many others regarding motor mounts. How the hell weren't these recalled and given a warranty for this specific issue?? Would the complaints be sent to the NHTSA? I have 2017 A7 and anticipating the mounts to go between the 60-85k mark, only time will tell.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Ro7 View Post
    You could try but it is maybe not really considered a NHTSafetyA thing. Since failed mounts do not cause any safety related issue. Many drive for long periods with them completely broken and some don't even know. If the mounts somehow separated causing the motor to fall out or if their failure stopped the car cold on the highway then maybe the NHTSA would sit up and take notice. Sadly weak motor mounts have been issues on Audi's long before this. It is up to Audi to address, but in my 20+ years with Audi's they have not. Some people get 200k+ miles, others (myself included), get less than 30k so of course it will be blamed on the driver and driving style. Audi likely has better stats than just an enthusiast forum and of course will say there is no need for a voluntary recall if their stats indicate that most drivers do not have a failure. Plus if fails outside of warranty they may not care at all. IMO Audi uses soft mounts to allow for the smoothness associated with a Premium luxury brand, but then advertise Sport and if you drive in a sporting fashion you risk damaging the soft/weak mounts. It is a shame, I understand, but sadly part of Audi ownership. Thankfully there is an aftermarket that recognizes these types of issues and sometimes offers solutions. (Ex: 034 solid mounts)
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Nov 07 2017
    Somerville, MA
    Def understand Audi's point of view, why fix it if we don't have to. Regardless, still a shitty situation for guys who end up having to replace them.
    Established Member Two Rings Euconect's Avatar
    Jun 15 2009
    Queens NY
    I will be ordering 034 mounts once they are released.
    2018 SQ5, 2013 S6, 2012 A4 sedan, 2010 A4 avant, 2007 S6, 2003 Allroad, 2003 A4 avant, 2003 A4 sedan, 2003 S6 Avant, 1995 A6,1990 coupe quattro
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Euconect View Post
    I'm still curious to see how that will work on an S6 motor mount without a re-code to disable CoD. I don't think 034 answered that question when asked.
    Speculation on....If they completely remove the magnetic motor structure or encase it in rubber either way when CoD is active without the active mounts I can only foresee issues varying from a mildly annoying vibration to the occupants to an outright nauseating experience that would generate far to many complaints to not address or abandon the product altogether. If the resistors/connectors to prevent errors also automatically disable CoD then I could see that as a viable option or perhaps simply a disclaimer stating they must be used in conjunction with a CoD disable tune otherwise higher levels of NVH may occur. I don't know, just speculating. Not trying to knock 034 (I own several of their products) but the teaser was made as "almost here" 3 months ago on a now 7-8 year old platform. Where is the latest update...even if good or bad news?
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    May 10 2013
    Toronto,ON
    Quote Originally Posted by Valpo A7 View Post
    U have a A7 or S7? They are different mounts for the A and S cars. I could've bought the old revisions which were in stock but why do that when they when the latest mount for the S6 came out on July 1 2020.
    Nov 27 2018
    Valparaiso, IN
    2012 A7
