I know that there are no S4s with the CREC engine in NA, but I have seen posts from members who know about superchargers so I thought I'd post so see if I can get some insight.
Purely out of interest I have been observing the "compressor speed" of my supercharger in varying driving conditions. I have a 189mm crank pulley so a drive ratio of 2.99, and when using boost the supercharger revs are indeed about 3 times engine revs. I then observed that at idle the supercharger revs fall to around 300rpm. I have assumed that since the supercharger clutch is magnetic, (and the measured current always seems no less than 0.1A) there is enough flux to turn the rotors. I recently observed that when cruising at around 30mph with very light throttle (engine revs a bit less than 1500rpm), the supercharger revs are about 400-500rpm. But even the slightest increase of pressure on the accelerator will raise the revs. I observed that they might reach around 1200rpm with no significant increase in engine revs.
I can only think of two reasons for this. The first, which I doubt, is that even that slight opening of the throttle increases airflow enough to spin the rotors faster. The second which I tend to favour, is that the supercharger clutch is not "open/closed" as I had presumed, but in fact has a progressive action, with variable magnetic flux and therefore variable drive ratio.
Any thoughts?
