Results 1 to 15 of 15
    Junior Member Two Rings
    Jul 16 2014
    United States
    1.8t is throwing p0507 and p0171 codes. Tried a couple things, but issue persists
    Hi everyone,
    my 04 1.8t quattro is throwing p0507 and p0171. Used a code reader at auto parts store and they diagnosed as front o2 sensor.
    I figured I would look for obvious vacuum leaks before springing for a new one. Found a damaged check valve on the airbox and a leak on the pancake valve attached to the valve cover breather. Replaced both and cleared codes. Check engine came back shortly after. Got them read again, and diagnosed as faulty CPS by another auto parts store.
    Research here suggests it may be the PCV valve below the intake manifold. I got one as well as a new j plug and thermostat, as well as needed gaskets to throw in while I'm down there.
    Any ideas before I dive in on that? Could it be the o2 sensor still?
    A couple other notes that may help - oil consumption has seemed a bit higher, and last time I changed the plugs one of them (2nd or 3rd) had oil on it on the coil side.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    The high idle code (P0507) and lean code (P0171) both indicate a vacuum leak somewhere after the throttle body. My recommendation would be to first run a boost leak test.
    Another possibility would be a cracked "L" breather hose connecting the lower block breather to the PCV valve. This would allow unmetered air to enter the intake stream.
    I doubt it's the O2 sensor.
    Jul 16 2014
    United States
    any tips for doing a boost leak test if I don't have the specialized hardware?
    Is the carb cleaner method safe for the car? would MAF cleaner do the same or is it not misty enough?
    I appreciate your input!
    Dec 28 2006
    Western Maryland
    Are you experiencing a higher than normal idle speed as your code indicates?
    Jul 16 2014
    United States
    yes.
    When the check engine first came around it was idling around 1100. Now it's closer to 1000 after replacing the pancake valve and check valve.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by joshpeck View Post
    yes.
    Try this. There are several vacuum lines connecting to the intake manifold. With the engine at idle clamp then off one at a time. If clamping one of the lines causes a decrease in idle speed you will have found your source of unmetered air that is causing the high idle and lean code.
    Once you determine the vacuum line causing the issue just trace the line until you find the leak. Let me know which line drops the idle and we can go from there.
    Dec 28 2006
    Western Maryland
    Bedtime for old guys. I'll check back in the a.m.
    Jun 09 2016
    u.k
    X2 on the pcv valve, also change the block breather pipe, its almost certain to be broken. Good access to that when you're doing the thermostat.
    Sent from my ANE-LX1 using Tapatalk
    Jul 16 2014
    United States
    Quote Originally Posted by caluma4x4 View Post
    I've already done the breather and the dipstick. Wishing I had done the PCV while I was at it back then. Hopefully they haven't gotten too brittle in the past 3 years.
    Jun 09 2016
    u.k
    Don't worry pcv valve is easily reached once coolant tank is moved out of the way
    Jul 16 2014
    United States
    Was thinking I would just do a coolant flush and pull the intake manifold and get at everything under it.
    I've been having a mystery coolant leak that might be the j plug.
    Do you think that's not worth it?
    I have all the gaskets and a new thermostat too, but I could always return them.
    Jun 09 2016
    u.k
    Well if you have everything you need there you might as well. Don't forget the o ring for the coolant pipe that's connected to the thermostat housing. Does the J plug show any signs if leaking? Another common leak point is the coolant flange at the rear of the cylinder head, it leaks onto the gearbox then evaporates so you'll never see it but you will see the pink stain from the coolant.
    Senior Member Three Rings Ol Dirty Noodle's Avatar
    Nov 30 2011
    Raccoons and Feces
    Nassau/LI/NY(the poor part)
    I just had the same exact problem, 034 PCV kit and billet injector cups with new o-rings and seals fixed it right up
    Jul 16 2014
    United States
    I replaced the coolant flange a little while back but still am getting some coolant loss (seems like it happens overnight maybe).
    Which o ring are you talking about on the coolant pipe? I should probably snag one if it isn’t included with the housing.
    Jun 09 2016
    u.k
    There is a metal pipe that is secured to the thermostat housing by a single 10 mm bolt, that's the one that has the o ring on it.
