Results 1 to 15 of 15
    Sep 08 2012
    Mass
    What wiper blades? 2002 A4 B6
    What windshield wiper blades do I need:
    2002 A4 B6
    Vin: waulc68e32A296309
    They are 22". I am having difficulty finding them for sale.
    Thank you!
    Mar 05 2013
    CA
    I think there's two kinds at least,
    aero vs. non-aero
    aero is solid, while non-aero uses old school metal spring pieces (looks different)
    beyond that, I'm not sure if there's more differences/options, such as lengths.
    I'm not sure what the preferred companies are for good quality. If it's Valeo, it might also be a bit pricey. Especially considering some say to replace wiper blades as often as yearly.
    IDK if it depends on how the car is used. If it rains a lot, and if it gets garage-kept over night and parked in a shaded garage during the day, if the workplace or school, etc. has one so that the sun isn't heating the blade rubber and glass.
    You do have your parts stores, Costco, etc. with a stock supply of various size blades; I'm not sure if they can be made to work, and if it's cheaper that way. Maybe Costco has Bosch ones.
    Sep 08 2012
    Mass
    I have the non-aero. Will the aero fit the non-aero?
    Veteran Member Three Rings Brens's Avatar
    Jan 07 2012
    B5 S4, MK1 TT 225, 3rd Gen Tacoma, 3rd Gen 4Runner
    Charleston, SC
    Quote Originally Posted by MPDesignAudi View Post
    Nope.
    -Brendan
    Brilliant Black B6 A4 Avant - 5spd 1.8T - Recaro - RNS-E - VMR - Daz - Woody Insides - Clutch/ Tune - Pink Coolant
    Jul 14 2009
    Pasadena
    i would upgrade to aero wiper 100000x better and not very expensive. its a 30 min job.
    IG: @matthewee
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    Refills for the regular ones can be had just by getting the correct length walmart wipers and stealing the refills from them.
    The Audi arms can be refilled; you just need to open up one of the crimped ends that keep you from removing the old refill blades.
    yup.
    TRICO 47-700 REFILLS WORK--but have been discontinued!
    They can be found on ebay...sometimes.
    Don't waste you time with the ebay China crap..
    But again..Walmart 22” wiper refills also fit and are equivalent to 47-700
    These may work as well...but I have not verified.
    Anco U-22R
    ANCO N22R
    Generally any 7-8 mm refill will work.
    Most say 7mm..I say 8mm.
    Keep the metal splines from your oem refills,; they are handy to have when you get only rubber refills.
    The Walmart ones are plastic splined.
    2002 Audi a4 B6 Q 3.0 6MT
    Feb 12 2008
    Michigan
    That’s some good info there
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Now you tell me, after I went to the junkyard an picked up several sets of B7 wiper arms.
    This car is what I look like on the inside
    Jun 12 2014
    Tampa FL
    Quote Originally Posted by ZERO FRAME GRAB View Post
    your point?
    Mar 03 2015
    Easton PA
    Was going to swap out the factory B6 wiper arms for the B7 ones to avoid buying the overpriced blades.
    Jun 12 2014
    Tampa FL
    The b7 blades are coming down in price for sure..but still too pricey for me. I found some on ebay for $16 a pair...of unknown quality..and also new arms wiper arms for $39!!
    But my 2002 straight blades still cost me $8 total at walmart to replace and I am quite poor right now.
    If you can afford the money needed up front to swap over, it might be worth it, but again the areo blades still cost more than the straight blade refills at this point.
    Times are still hard for some folks.
    It is a mod on my list.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    If you convert to aero: Valeo blades worked great for me.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Mar 03 2015
    Easton PA
    I have never changed the bladed on mines, but I was reading the factory blades were like $40 a piece so guys were putting the B7 wiper arms on because you could buy regular aftermarket blades for them. I got a set of B7 wiper arms in the junkyard for like $8 a piece, still sitting in the backseat of my car.
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    i prefer refills...they're much cheaper in the long run if you plan to keep your car more than 2 years
    Veteran Member Three Rings 9744RR's Avatar
    Sep 01 2005
    2016 A6 3.0T, 2003 A4 1.8T Tip, GTRS Elim, REV0, 440 injectors, ASP front mount, etc Porsche 356
    Buy from Amazon. $24
    2016 A6 3.0T Stock
    2003 A4 1.8T Q TIP not stock
    Porsche 356 Stock
