Results 1 to 2 of 2
    May 31 2011
    moore
    CTS Turbo SAI Breather Filter
    I need help finding where I can buy the breather filter since the one in use is rusted. Is this the correct part number, CTS-AS-250-BK?
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by hiwasss View Post
    The filter looks roughly correct but I recommend measuring the inlet diameter on your existing filter to ensure that it is in fact 1". The adaptor that comes with the part you linked does not look like it should be used on the 3.0t, though, as there is no place to connect the barb fitting coming off that base. But if all you need is the filter, just throw the base away.
    SOLD 2015 Daytona Gray S4
