Results 1 to 8 of 8
    Established Member Two Rings jpjmustang's Avatar
    May 23 2013
    2014 Audi Q7 TDI - 2011 BMW 328I
    Missouri
    Scan Tool - Schwaben by Foxwell
    Professional VW/Audi Scan Tool
    Developed for VW/Audi vehicles. Has many OE-level diagnostics including EPB, Airbag, ABS, A/T, Instrument cluster, Oil service reset and more.
    https://www.ecstuning.com/b-schwaben...868sch01b~scf/
    Has anyone used this "read tool" - is it better than others
    Im in the market for a reader
    TB
    [B]JPJMustang[/B]
    2014 Audi Q7 TDI 3.0 Prem +
    2012 Audi A6 3.0T Prem +
    2011 BMW 328i
    2004 BMW X3
    Veteran Member Three Rings Low and Behold's Avatar
    Feb 21 2015
    Rip City
    I own this. Its a good tool
    But honestly, I would suggest spending a bit more and getting VCDS.
    Casey | @cshore | B7 A4 Avant 2.0T | B8 Q5 2.0T
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Portland, OR
    I second that.
    This works great for reading codes, resetting codes, small programming, and maintenance/repair stuff like throttle body calibrations or rear parking break release, but is far from the diagnostic capabilities that VCDS has. Plus, support is lame and takes a while from China. ECS does not support it, it’s just their sticker basically.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    3 vin Ross Tech is $199 shipped... that should be a no brainer.
    Oct 13 2017
    Kegums/Latvia
    No-brainer is this tool - Obdeleven
    https://obdeleven.com/en/
    Does everything what VCDS does, except costs about 65€ (for full version ). I have one, and I sold my VCDS cable after I bought Obdeleven. It's portable, always in my car when I need it, don't need a laptop to use it.
    Sent from my E5823 using Tapatalk
    Senior Member Two Rings OliNix's Avatar
    Oct 22 2014
    London, UK
    +1 for OBDEleven it’s nearly everything VCDS does but portable. Only downside is that it is only Android not iOS
    Veteran Member Three Rings B8Buckeye's Avatar
    Mar 14 2005
    2011 Audi A5 Cabriolet - Ibis White and 2016 Mercedes Benx Metris conversion van - Obsidian Black
    NW Ohio
    Quote Originally Posted by Sibmets View Post
    the OBDEleven looks like a great option. i have an iphone but have an android head unit in the car so this should work. thanks for the link and suggestion...
    Veteran Member Three Rings deusilan's Avatar
    Aug 17 2012
    '89 E30 325i; 2011 Police Interceptor
    Stinky Island, NY
    This is the one I purchased from ECS (I believe) and it's been great for me, however the Ross Tech VAG-COM has a better user interface.
    http://www.foxwelltech.com/product/item-125.html
    If you want to be a pro, Foxwell released the GT80 mini/pro series scanners which looks legit for all cars.
    Currently: 2005.5 A4 2.0 (Red)TQ 6-spd, WORK IN PROGRESS 2011 Police Interceptor
    Previously: E30 325i, donated for track purposes
