Originally Posted by
Morritse
I don't think so. It's pretty basic physics. Acceleration is in essence power to weight ratio. The large exceptions are when traction or drag is the limiting factor.
At a given power to weight ratio, the car with more traction should accelerate faster (everything else being the same). And since traction is a function of friction is a function of weight....
You are looking at traction in a vacuum, which you can't. The additional traction that comes form the extra weight is not sufficient to overcome the extra power required to move that extra weight.
As long as you're traction limited (initial hard acceleration), lighter cars of the same power to weight will accelerate faster. Once you get beyond that, the cars with the higher power will accelerate faster, since the aerodynamic drag will be a much lower percentage of the car's power (since the drag will be similar with both cars). That's why lighter cars win off the line, and high power cars run them down at speed.
