Results 1 to 11 of 11
    Jun 23 2011
    Toms River, NJ, USA
    Vibration While Braking After New Pads & Rotors
    I just completed the replacement of the front rotors and pads on my 2013 S6 with Disc Italia pads and rotors. Overall, the process wasn't horrible once you learn the little tricks to get the new pads in.
    The good news: the brakes are finally quiet. Zero squeal when stopping.
    The bad news: I now have a vibration / pulsing when stopping, noticeable in the brake pedal feel. It occurs with moderate to hard braking and is quite substantial. Braking seems strong, however.
    I did everything by the book and followed this guide: https://www.audiworld.com/forums/s6-...6-7-a-2889241/
    Some thoughts:
    1. I cleaned every mating surface thorough with a wire brush and brake cleaner.
    2. I lubricated the pins that hold the pads in place.
    3. I applied anti-squeal compound between the back of the new pads and the new circular shims. I'm wondering if its possibly this, but the vibration only seems prominent on the front left wheel. I applied the compound to both sides. I simply didn't want to risk squeal after a couple thousand miles again.
    4. I performed a proper bedding process. 30-0 mph stops, then 60-0 mph stops, then some light driving.
    5. Wheels were not changed in any way. I put the same wheels back on the same hub. Didn't appear to lose any weights.
    6. I put on new caliper hardware and torqued to proper spec.
    7. I checked the rotors for any deposits, but they seemed fine. Also didn't notice any warping.
    Any input, guys? I'm eager to get this issue resolved and get my car back on the road by tomorrow.
    Veteran Member Three Rings bonafyd's Avatar
    Nov 27 2008
    New Jerz
    The rotors are probably not true/ perfectly round.. i’d go over the job again maybe something is loose who knows.
    If nothing is loose then it’s more than likely it’s the left rotor or both of them. maybe a local shop can check to see if they’re true or not.
    Hopefully you’ll get it sorted.
    Bagged C7.5 aka FISHBOWL
    |Airlift Bags|Accuair E-Level|Endo-CVT|I-Level|Aluminum Mirror covers|Aspherical Mirrors|Full 40% Ceramic Tint with Windshield|
    |AWE Touring Exhaust|RS7 Airbox|Flat Bottom Wheel|S7 Wheels|S-Line Sport Pkg|LED Headlamps|Frameless Mirror|
    |S6 Oem Trunk Spoiler|RS Pedals| RS Door Handles|S6 Diffuser|RS6 CT3 Carbon Fiber| RS6 Shift Knob|IE Intake|IE TCU Tune|
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    You can get a cheap runout gauge to see if the rotors are out of round. Or try and rebed. You did everything correctly. This happened to me and a rebed fixed it..0-60 and back to 5 or 10 mph 5 times with 5 mile cool down. Biggest problem was finding a spot to do the rebed.
    Good luck.
    2016 S6 Mythos Black Metallic, B&O Sound, Sport Package, Driver Assistance, Comfort Seating, Black Optics, Audi Exclusive Interior.
    My wife said its golf or her, gosh I'll miss her!!
    Aug 12 2015
    Minneapolis MN
    During the bed in process did you notice the vibration?
    2017 Audi RS7 Glacier White w/ Black Optics
    2014 Porsche Panamera Turbo Executive Amethyst
    Established Member Two Rings jinetics's Avatar
    Jan 18 2018
    GTR, GT4, RS7, E46 M3, Raptor
    Edgewater NJ
    How is your steering wheel under braking? Any shaking? Did you clean the brake rotors with the brake cleaner? (the friction surface) Through a visual check, do you see any dark spots on the rotor face?
    Sounds to be it's more like a suspension issue if everything checks out. Under load, your control arms flex, but once it flexes too much, it "bounces" back in a sense. I am currently going through the same thing (no pad or rotor change) but with new stainless lines.
    RS7 DGP - Millek Straight Valve Sonic // Eventuri Intake // SRM Inlet // Forge Vented Diverter // CETE ASC // RF02 295's // 034 Motorsport Transmission-Differential-Carrier Inserts-Density Line Control Arms // Goodridge SS Brake Lines // APR Tuned
    K2 Automotive
    IG: @jinetics
    Veteran Member Three Rings bpd's Avatar
    Feb 01 2017
    Seattle WA
    Think rear brakes need to be done?
    Jun 23 2011
    Toms River, NJ, USA
    The vibration started the first time I braked in the bedding process.
    I did clean everything quite thoroughly with brake cleaner. Didn't notice any unusual wear pattern or deposits on the rotors.
    I think the backs were fine.
    Jun 23 2011
    Toms River, NJ, USA
    Forgot to add, the vibration is only in the pedal. None in the steering wheel during braking or normal driving.
    Jan 18 2018
    Edgewater NJ
    Quote Originally Posted by gimpgutter View Post
    Your rears are definitely the culprit if it's just your pedals. I would change your rear rotors and pads out as this is a clear indicator of warped rear rotors.
    K2 Automotive
    IG: @jinetics
    Jun 23 2011
    Toms River, NJ, USA
    Update:
    I had my mechanic check it out today. He is confident it's a manufacturing defect in the rotor, a so-called "hard spot". He thinks during the tempering process, something didn't get heated properly, resulting in different material properties in parts of the rotor. Nothing is detectable visibly or with with a run-out gauge, but he was adamant it must be the rotors.
    He didn't think that this would cause any premature wear on the pads and said it shouldn't get any worse over time. I still want to replace it, since it's not particularly hard to do and the pulsing is even more annoying than the squealing.
    I guess I'll be reaching out to Disc Italia / Brakeworld for a new rotor.
    Apr 13 2014
    RI
    If you still have old rotors try swapping one at a time to isolate..
