Results 1 to 13 of 13
    Established Member Two Rings i8snitches's Avatar
    Mar 03 2018
    2018%20Audi%20S5
    GA
    A6 Front Control Arm - Recommendations
    Ok so did do some research via the forum search and only found a few references for the A6 platform of those replacing/upgrading control arms.
    So recently competed oil change looks like my front left control arms may need replacing... hear some creaking and appears there is a slight crack. So my question to the GREAT forum...
    I was planning to change out front & rear sway bars with EuroCode as planned to go to track for the first time... but now with control arm replacement needed looking into LYKT Adjustable Control Arm B8/C7/8R Street
    Any feedback/recommendation? I do plan to do both front left and right..
    2014 A6 3.0T
    MODs: APR Ultracharger & DP (57.75mm/187mm) | Roceuro CAI for APR Ultracharger| AWE Touring Exhaust with resonated downpipe | APR CPS | Eurocode Test Pipe | Bilstein B8 Strut | H&R Sport Springs | 036 Control Arm Kit | Eurocode Sway Bar Kit and Endlinks | Jokerz Ported Blower
    UPCOMING: Custom TCU tune
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    How many miles do you have on your car? Curious as to longevity
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Mar 03 2018
    2018%20Audi%20S5
    GA
    Quote Originally Posted by Kevin1 View Post
    Currently at 65k... never tracked... only ever had maybe three serious runs above 10mph... otherwise baby it due to daily driver.
    2014 A6 3.0T
    Oct 19 2008
    Long Island
    Quote Originally Posted by i8snitches View Post
    Wow, that is low mileage for control arms. At least I hope it is low mileage.
    RIP Audis
    Established Member Two Rings jinetics's Avatar
    Jan 18 2018
    GTR, GT4, RS7, E46 M3, Raptor
    Edgewater NJ
    I would say you had a good run on the factory if you have never changed it. Rubbers deteriorate over time and considering it's a daily, all the heat cycles and weathering it's been through, not bad at all. I plan on doing my fronts shortly as well as I too am hearing slight creaks and play while braking. I plan on going oem however as it has proven to me how long it lasted.
    RS7 DGP - Millek Straight Valve Sonic // Eventuri Intake // SRM Inlet // Forge Vented Diverter // CETE ASC // RF02 295's // 034 Motorsport Transmission-Differential-Carrier Inserts-Density Line Control Arms // Goodridge SS Brake Lines // APR Tuned
    K2 Automotive
    IG: @jinetics
    Mar 03 2018
    2018%20Audi%20S5
    GA
    Yeah everything is still factory... I only just recently changed out brake pads and rotor which were original factory... previous owner babied car so in some ways I lucked out...
    Leaning towards a full kit, instead of replacing just arms: Audi Control Arm Kit
    Any feedback on EuropaParts?
    2014 A6 3.0T
    Senior Member Two Rings 13_C7_SC's Avatar
    May 01 2016
    2011 Range Rover Sport
    Glenside, PA
    I just ordered a OEM SC bypass valve from EuropaParts. It turned out not being my issue though, and I was able to return it and get a refund less restocking fees. Customer service is good, and they respond within 24hrs.
    Sent from my LG-H932 using Tapatalk
    Feb 04 2017
    Bronx NYC
    I just did my full front end with 034 motor sports and it’s great . Cost me about 700 for the control arms top and bottom with ball joint .
    Jul 30 2013
    Colorado
    Recently did my lowers with the 034 Motorsports Density kit at 58k miles. Very happy with the results, and way less money than OEM. Uppers shouldn't need to be replaced for a while.
    Mar 03 2018
    2018%20Audi%20S5
    GA
    Appreciate the feedback... 034_MotorSports and EuropaParts seem comparable... Sent a request to both to get some more specs... and pulling the trigger soon enough...
    Going to do complete kit for front...
    What's reasonable cost for labor?!? I don't have access to a lift so leaning on EuroFed for assistance.
    Jul 30 2013
    Colorado
    Labor was around $220 for my lowers, assume double that.
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    My S5's control arms are needing replacement too, at 66K miles, I guess that's the expected life from OEM control arms. I will be going with lemforder (OEM) full front kit, it's more expensive, but I don't trust 034/LYKT/Chinese parts. Labor is not cheap in PNW, better get it right in one shot.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Mar 03 2018
    2018%20Audi%20S5
    GA
    Quote Originally Posted by wangshuo1989 View Post
    Perfect been on the fence with 034/LKYT myself due to quality of hardware. Couldn't push the button to order last night so checked "lemforder" and the difference between two appears to be $1000 vs $1,400... Is the cost indicative of the quality?
    My full list of parts are for a 2014 Audi A6
    • Position: Front Lower Forward - Audi Control Arm Bushing - Lemforder 8K0407182B
    • Position: Rear Lower Forward - Audi Control Arm - Lemforder 8K0501529L
    • Position: Front Left Lower Forward - Audi Control Arm - Lemforder 8K0407151F
    • Position: Front Right Upper Rearward - Audi Control Arm - Lemforder 8K0407510R
    • Position: Front Left Upper Rearward - Audi Control Arm - Lemforder 8K0407509R
    • Position: Front Right Upper Forward - Audi Control Arm - Lemforder 8K0407506R
    • Position: Front Left Upper Forward - Audi Control Arm - Lemforder 8K0407505R
    • Position: Front Right Lower Forward - Audi Control Arm - Lemforder 8K0407152F
    • Position: Front Right Lower Rearward, Incl.Ball Joint & Bushings - Audi Control Arm - Lemforder 4G0407694J
    • Position: Front Left Lower Rearward, Incl.Ball Joint & Bushings- Audi Control Arm - Lemforder 4G0407693J
    2014 A6 3.0T
