Results 1 to 40 of 76
    Veteran Member Three Rings Steelerhater37's Avatar
    May 29 2017
    BMW E36(98)M3 convertible//VW B6(07)Passat
    Bel Air Maryland USA
    Digital speedometer
    How the heck do I get the digital speedometer to come up on the center display between the tach & speedometer???
    Please HELPPPPPPPPPPP
    Apr 13 2017
    Alberta, Canada
    Steering wheel controls, left hand side, use it to scroll through the displays.
    Sent from my SM-G965W using Tapatalk
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    There's a button on the bottom of the wiper stalk that says "Reset". Press it until you see the mph.
    - - - Updated - - -
    Also you might want to head over to the "Questions you thought were too dumb to ask" thread since you've been posting some stupid questions lately.
    May 29 2017
    Only 2 selection screens
    Radio stations & miles to empty
    May 29 2017
    For whatever reason I have the only car in America without the reset button on my wiper stalk. I got nuttin
    Jul 16 2018
    Atlanta
    You don't have a big mode button on the left side of the steering wheel? This is what changes the main information in the instrument cluster display. The toggle on the end of the wiper stalk and the button on the bottom of the wiper stalk work the trip computer info. Also, if NAV is active, you can't have the digital speedo displayed. But this is all on my MMI 2G (2009). I'm sure you can find an owner's manual for your year.
    Active Member Four Rings AUDIMAN33's Avatar
    Jan 11 2014
    Quote Originally Posted by Steelerhater37 View Post
    Post a pic lets see what we're working with
    May 29 2017
    Quote Originally Posted by AUDIMAN33 View Post
    Soon as wife gets home with car. Any minute
    May 29 2017
    Quote Originally Posted by Smac770 View Post
    I have 2g (2012). No reset button on bottom of wiper stalk and don’t think there’s a toggle
    May 29 2017
    Jan 11 2014
    That’s super super strange, you’re also missing the button on the side of the stalk. I’m not even sure how you’re accessing the Miles left...
    Veteran Member Three Rings WarmFuzzies's Avatar
    May 24 2017
    b8.5 S5 cab, 200-series L/C
    Montana
    So yours doesn’t look like this?
    09 Avant here
    Established Member Two Rings B8Brit's Avatar
    Sep 27 2016
    NE Ohio
    I have the same issue on mine...mine is a “premium”...not plus or prestige which i believe has those features.
    2011 Audi A4 2.0T Quattro Auto
    IE Stage 2 tune, CTS high flow cat, EC inlet pipe and AFE dry filter, Neuspeed springs and KYB sport shocks, slotted rotors w/ SS lines, RS4 grille with CF wrapped badge.
    Veteran Member Three Rings NathanGreatScott's Avatar
    Apr 05 2017
    '16 Ford Flex Limited
    Western PA
    Mines just a premium model (though the original owner did spring for some bells and whistles like LED, NAV, and few others) and I have the wiper stalk that WarmFuzzies posted above and am able to display the digital speedo.....
    I'm B8.5 though, so maybe that has something to do with why I have it and Steelerhater37 doesn't. (Ravens suck btw )
    May 29 2017
    Quote Originally Posted by WarmFuzzies View Post
    09 Avant here
    Nope. No toggle on end
    Jan 11 2014
    You’re not looking for the end toggle. You’re looking for the button on the bottom button
    Jan 11 2014
    I took his pic and circled what you’re looking for
    Jan 03 2013
    Baltimore
    Wayne-
    You have the same trim car as mine, no reset or toggle on the wiper stalk. There is a way to code in some of the other screens and use the AMI to show you additional info on the DIS. I don't think you can get the digital speedo readout this way.
    I went the route of swapping a color DIS (used cluster), programmed the miles and put it in. Then I found the correct wiper stalk with reset and toggle switches. Recoded it all and now I have all the screens you are talking about.
    Sent from my Pixel using Tapatalk
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    That's not what he is looking for. He wants the digital speedo in the center display. He will need the toggle that is at the tip of the stalk(shown in your picture) to scroll through the trip ODOs, consumption (zero and non)...as well as the digital speedo. The reset button you point out only resets the values of each that can be reset. Both my previous 2009 premium A4 and my current 2015 A4 SLine have it....unless I've missed something...I can;t see it being any other way.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Jan 03 2013
    Baltimore
    Base models don't have the toggle at the end. Some of the functions are coded "off" because there isn't a way to use them without the toggle. You can code some of the functions on and use the center AMI button to swap what shows on the DIS (red version usually). Mine was this way until I bought a color cluster and appropriate wiper stalk and recoded it all.
    Quote Originally Posted by Crucible35 View Post
    May 29 2017
    Quote Originally Posted by elscotto80 View Post
    Wayne-
    Yeah but you’re brilliant!
    Established Member Two Rings manxx's Avatar
    Sep 06 2012
    If you really want digital speedometer, you can enable "Driving School Mode" on the AMI display via VCDS:
    [56 - Radio] [Adaptation - 10] -> Channel 02, Set to 1
    Then you need to enable it in the menu (see how in this video: https://www.youtube.com/watch?v=D1y3eFUgr-A)
    2002 Jetta 1.8T 5MT (sold), 2009 A4 6MT(sold), 2010 Golf 6 , 2012 A3 (sold), 2014 Q5 (totaled), 2015 Q5 (sold), 2016 A4 6MT (sold), 2020 Q5 Technik, 2020 S4 Technik
    Jan 03 2013
    Baltimore
    Yes, thus was what I was recalling. I think you can also enable consumption readings. It would say what systems were on and what is causing the most power use or something like that.
    Quote Originally Posted by manxx View Post
    Sep 06 2012
    You can code everything to be shown on DIS with the exception of digital speedometer. Without the proper stalk, all the options have to be turned on/off "manually" via the AMI menu.
    Jan 11 2014
    Quote Originally Posted by Nano909 View Post
    You literally don't make any sense.
    Says the guy who put a S4 exhaust on an A4...
    Jul 25 2016
    California
    So putting a quad tip exhaust on an A4 doesn't make sense?
    B8 A4 S-Line | quattro | Ibis White
    Boss500 Kit | Custom WPT Big Turbo Tune
    Rev9 IC | Fuel-It E Sensor
    Macan 345mm Front Calipers | S5 Rear Calipers | EBC Reds
    S4 Rear Valance | S4 Exhaust | RS4 Grille
    My Porsche Macan BBK upgrade thread: https://www.audizine.com/forum/showt...-on-B8-B8-5-A4
    Jan 11 2014
    Ahh but that’s not what you did exactly, Quad tip AWE or a custom one makes sense. Just getting one off a stock S4 and calling it a day is super lame
    May 29 2017
    Digital speedometer
    Elvis has left the building🤡
    May 29 2017
    I bet you’d like to know, so you can finally get a real S4!
    Oooooooooo *%#*...he gotta fake s4...hahaha
    Jul 25 2016
    California
    Well it's a good thing you don't make the rules. Haha
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    its a nice mod but when youre yapping like youre driving a 70k 6x6 A4 with ebay S4 mirrors and trashing everyones rides, not exactly a good look for you.
    your A4 is under 18k, dipshit.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Feb 07 2018
    PDX ish
    Guys. Guys. Save the negativity for smetch for sale threads where it belongs.
    Jul 25 2016
    California
    Quote Originally Posted by JeriQo View Post
    That must mean yours is under $8k for not having Quattro and not having all the options. Hahaha
    Jul 08 2015
    could be. i say less than $2k. my wheels cost more than the car itself since its technically a bicycle.
    it has manual knob windows, no ac, cloth seats and equipped with a cassette player. poor me.
    i love your A4 tho! its very nice and very super clean, nicest one ever on audizine and IG
    Jul 25 2016
    California
    No folding rear seats either. Tsk tsk.
    Jul 08 2015
    absolutely not. cmon man have to be pretty dumb to make that statement.
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    My rear seats fold down, creates a nice bed for your mom and I to enjoy.
    I'm as cool as a cucumber in a bowl of hot sauce.
    Jul 25 2016
    California
    Quote Originally Posted by BeerBrent View Post
    Great to see your maturity level is that of an elementary school student. Hahaha
    Jul 25 2016
    California
    Damn it.
